Question about Brother XR-65t Mechanical Sewing Machine
Sewing machine sews only in reverse.
The reverse lever does not work. the machine worked in both directions the last time I sewed a month or 2 ago. The machine is a Brother XR-65. I have never had a problem like this in all the years I have been sewing. I am presently trying to contact someone locally to get it fixed. Is there a way I can do it myself?
I am taking the machine to a local repair shop. Thank you.
Posted on Jun 23, 2009
  • 46 Answers
To all the people with this problem. What has happened is the reverse mechanism has stuck, this is often due to not being used for a while or the machine has not been oiled properly, which is hard to do for a user as you virtually have to remove all the covers.
If this particular machine has a screw on cover at the end where the handwheel is, remove it and look inside, you will see the mechanism, what you need to do is push it back out, then oil it but make sure you work the reverse button in and out while you oil it and check it works freely, then just refit the end cover.
Posted on Jul 02, 2009
Machine will only sew in reverse
You wrote,
"Machine will only sew in reverse - Sewing Machines" A: I'm just a tinkerer, hobbyist, who did run across this same problem before. I can give a general non-model specific remedy based on my limited experience with mechanical sewing machines that get locked into sewing backwards, that is "they only want to sew in Reverse":
1. Verify what is the normal direction of the fly wheel in forward sewing for your machine. Most sewing machines, including Singers, always sew with the top of the flywheel moving toward the operator, regardless if sewing forward or backwards; but older friction-wheel White Rotary (RF) sewing machines, have the flywheel running in the opposite direction (top of Hand-Wheel turning away from the operator when sewing.
2. If it has Reverse Lever/Switch; check that it is in the correct position; if still only sews in reverse, change positions of the Direction Control lever (or Button, etc.), and see if it changes direction to correct the problem.
3. If this does not help, then jiggle the Reverse Lever and follow the linkage inside the machine and see if there is anything broken, loose or out of adjustment. Some machines have reverse control linkage elbows in the top part of machine, and by poor design are prone to accidentally pop backwards, causing sewing in the opposite direction of the position of the Reverse Lever/Button (Backwards when you want to sew Forward). On occasion, a Kenmore 158.1787180 got locked into the backwards sewing mode (the dog-gone' est thing), but by following and analyzing the linkage, I found where it was going wrong, and popped the indecisive linkage elbow back the way it was supposed to be and fixed it. [ I had more detailed notes, on this fix, but when I read them, without the machine in front of me, made no sense to me today so I can't share that till I revisit the conundrum again.]
4. If all else fails, you may be able to hold or clamp the Reverse Lever/Button in the Reverse position, so it sews Forward (I've done this before too (as a short-term fix) until I figured out how to adjust it back the way it was supposed to be.
5. If this post helped you, don't be afraid to indicate so, so Fixya will know. If it was useless, "ouch", but I'd like to know that too, so I'll be more selective on what I really know more about. I try to help, though this is probably a trade secret that anyone who knows is discrete about who they share the information with.
Sincerely
-- Amender. (2016 FEB 24)
Feb 06, 2016 | Sewing Machines
My machine will only sew backwards! What do I do?
sewing machines sew in one direction
the reverse sewing direction is achieved by reversing the direction of the feed dog under the material
this is achieved by a lever or knob on the front of the machine
IN your case I suspect that it has been changed unknowingly
Jan 10, 2016 | Kenmore Sewing Machines
My machine has not been used since 2004 and is stuck in reverse How do I fix this?
If it is a mechanical (NOT computerized) sewing machine, it most likely needs a good cleaning and oiling after not being used since 2004. Mechanical sewing machines need to be cleaned & oiled every time a bobbin is changed, every 8 hours of constant sewing, or every six months when not in regular use. Use only good quality sewing machine oil (NOT stale old oil, 3-in-1, WD-40, or cooking oil) and oil only 1 or 2 drops each spot as directed in the owner's manual.
Sewing machine oil tends to degrade over time and will eventually glue moving parts together. Keeping it maintained is a simple way of insuring it will work the next time it is used.
Sep 12, 2015 | Sewing Machines
Necchi 535FA is stuck in reverse, no matter what adjustments I change. I oiled and cleaned it and properly threaded it. Everything seems to work and move fine, except the reverse button was stuck.
A part of the Reverse Button mechanism is probably frozen.
This may work:
Direct heated air from a handheld hairdryer into the internal mechanism and let the metal parts get pretty hot. (Don't burn your fingers!) Then try the reverse button to see if it has loosened. Repeat and hopefully it will begin working. If you figure out where the reverse button mechanism is located, you can try lubricating the metal joints--ONLY 1-2 drops of GOOD quality sewing machine oil (do NOT use 3-in-1, WD-40, cooking oil, or OLD sewing machine oil). Then try the hairdryer again. Do NOT oil plastic parts or belts unless directed to in the owner's manual instructions.
Vintage Sewing Machines
To keep your machine sewing well, be sure to clean and oil on a regular basis--about every 8-12 hours of continuous sewing, every time you empty a bobbin, or if it's not in frequent use, every six months. Oil drying out is a frequent cause of machine moving parts freezing.
Sep 01, 2015 | Sewing Machines
My machine is sewing backward, would go forward what to do
there is normally a small lever on the front of the machine near the drive end that is up to go forward and down to reverse
It is a great help when starting to sew that you sew about 1/2 inch then reverse the direction and then go to forward again and continue sewing
actions anchors the start of the sewing and the thread will not come undone
do the same at the end of the sewing and when you cut off the threads they will not unravel
Apr 12, 2015 | Sewing Machines
Brother AE2500 reverse sewing lever is too stiff to move , how does this work please, bacause in the CD provided with this sewing machine , this lever (plastic) for doing reverse is being moved down t
Try turning the flywheel and operate the reverse lever at the same time. Some machines need to be at a certain point in the stitch cycle for the reverse lever to be used.
Dec 26, 2014 | Brother Sewing Machines
Brand new Singer 4423 won't go in reverse ?
Your reverse lever may have become disconnected inside the machine. Return it to the dealer if you don't want to fix it yourself.
Jul 29, 2013 | Singer 4423 Sewing Machine
My reverse doesn't work either :(
Check the spring inside of the sewing machine. You have to take it apart and look at the spring where the reverse lever is located.
Jul 11, 2009 | Kenmore 16622 Mechanical Sewing Machine
Stuck in reverse
The reverse button is attached to link that moves a lever to make the machine sew in reverse. The lever is spring loaded so it returns to forward sewing when the button is released. Either the spring has come off or there is a bind in the lever(oil it). In order to solve the problem, the covers must be removed.
Oct 26, 2007 | Kenmore 15208 Mechanical Sewing Machine
Brother XR-65t Mechanical Sewing Machine Logo
489 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
