Question about Electric Mobility Health & Beauty
My invacare pronto m41 is very hard to turn on and off. Do I need to replace the keypad or the joystick?
  • 175 Answers
The back of the keypad has a flexible metallic coating that comes in contact with a non-flexible metallic circuit under it to activate the switch. With thousands of pushes, this metallic coating wears off and must be replaced by replacing the entire keypad. Sometimes, debris can get underneath the keypad which interferes with the contact, and cleaning with alcohol will clear the problem.
Posted on May 08, 2014
  • 175 Answers
SOURCE: I have a invacare The joystick mk5 will not lite up batt. are new
Some chairs, like the M91 are a real bear to replace the batteries and connectors can get knocked loose in the process. First, using a voltmeter you need to see if the controller is getting power. On the DC setting, use voltmeter at the three-pin female connection at the joystick that is the charging port. The two pins that are opposite each other are the "hot" pins, and your meter should read about 25 volts, +- 2 volts. If its 0, there is a connection that isn't made from the batteries through to the controller, or the controller or joystick is shot. If you do have power to the joystick, then it's probable that the joystick is shot. A new one from Invacare is pricey, around $1,000.00 I have found a new site that can repair most makes. I have not used them, so cannot vouch for their work, but give them a call and see what you think.
http://www.flightsystems.com/cart_controls/wheelchair_powered_scooter_market_cart_controls.htm
If you don't have power, start at the terminals from the battery, and follow each wire back to the power control box, unplug and replug firmly as you work your way back. Check all fuses on the way. Then check all of the other connectors inside the chair, unplug, and reconnect again. Unplug and reconnect the wires leading into the power control box, and then restart chair. If no lights still, then the power control module is probably the culprit, but the address above fixes those too. The joystick and the power control module work together to make the chair operate safely. Good luck
Posted on Jul 08, 2009
  • 11 Answers
SOURCE: Invacare Pronto M51wheelchair just stopped;
I believe that indicates a left motor fault
Posted on Oct 16, 2009
wcdoc1953
  • 280 Answers
SOURCE: How do i know when my invacare pronto m5 is fully
With an M51, a full charge will be indicated by all three joystick indicator lights lit- red yellow green. The green far right LED is the full charge light. Also the charger has indicator lights that go from red/yellow to full green at full charge. Hope this helps
Posted on Oct 24, 2010
wcdoc1953
  • 280 Answers
SOURCE: I NEED A WIRING SCENATIC FOR AN INVACARE PRONTO m6
I assume you need a wiring schematic for an M61. The circuit board schematics are proprietary and not available. The component schematics and interconnects for switches and wiring harnesses are available, as are the parts diagrams and drawings. Please clarify your specific need and issue.
wcdoc1953
  • 280 Answers
SOURCE: i have invacare pronto m51 with surestep the spjis
The 9 flash error code indicates a communications fault. The communication fault relates to the communication between the joystick and the control module. The joystick on the arm mount is connected to the control module in the base. When there is a break in the wiring of this wiring harness, also called a bus cable, a fault occurs. This trips the computer and the computer sends out a flash code to the joystick. Simply stated there is a broken or pinched wire between the joystick and controller. Look physically at the wire and check for cuts, breaks or pinches. The best short term repair is to repair the broken wire with solder and heat shrink or tape. You can also use **** splice connectors and tape. The best long term repair is to replace the harness with a part available from Invacare. The most definitive way to diagnose this problem is to read the fault log of the controller using a hand held programmer available to dealers and certified technicians. The number and type of fault codes logged in the controller is another indicator of which
component(s) has failed. Hope this helps.
Posted on Nov 20, 2010
Can a joystick be programmed to not be so sensitive on a pronto m41?
There are adjustments that can be made with a programmer, a good technician can set these quickly for you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 29, 2016 | Electric Mobility Invacare Pronto M41...
No lights on joystick
Here is a parts catalog for the M41. http://www.invacare.com/doc_files/06_108.pdf
If it was working fine before you swapped the batteries then you did something to interrupt the current flow. Pages 49/50 show the location of the controller with a picture. Unplug the connections here and make sure they are clean and in good shape. Make sure all other connections are clean and tight.
If you have 24V coming off the batteries into the controller, and 24V going out to the joystick from the controller and still nothing is working, then you will probably need to get ahold of an Invacare service tech to replace the joystick. Before he does that he should swap out the old joystick with a new one to see if that is the issue. Invacare parts are pretty pricey...joystick by itself is over $500.00. If the controller is shot, then you can double that cost. Sometimes, both need to be replaced as they can kill each other.
If the chair is old or has a lot of hard hours on it, you can usually shop around on Craigs List, etc and find a good newer/near new chair for about the same price as a new joystick replacement.
Feb 23, 2015 | Electric Mobility Invacare Pronto M41...
Unlock a spj+ joystick on a pronto m41
Lets make sure this is just the joystick lock mode. When you turn the chair on and it is in joystick lock mode all the battery level lights will chase across several times and then the joystick will turn off.
When you turn the chair on and you see the battery level lights chasing from right to left push and hold down the power button till the lights turn off. Only the first year that the M41 was made had this option.
Jan 23, 2015 | Electric Mobility Invacare Pronto M41...
I had a wrench showing on my wheelchair. Now the wrench is gone and the unit will not turn off..
Hello, If the joystick won't turn off it is a joystick problem. You can unplug the joystick cable from the joystick to save battery if you need to. This kind of problem means your joystick will need to be repaired at Invacare or replaced by a dealer of Invacare chairs.
Jun 01, 2014 | Electric Mobility Invacare Pronto M41...
What does 7 times flashing mean is wrong on pronto m91
Seven blinks is most often the joystick. A Invacare Remote Programmer can be plugged in to the joystick to verify this.
May 28, 2014 | Electric Mobility Invacare Pronto M41...
How do I turn off the pronto m41 speed limiter
The Pronto M41 does not have a speed limiter per say. If the chair used to go faster than it does now then you may have some kind of problem with the chair. If the chair has always driven' slow, that is slower than the maximum 3.5 to 4 MPH then a Invacare Remote programmer is needed to program the chair to go it's full speed.
Seek a Invacare dealer and ask them if they can check the programming.
May 16, 2014 | Electric Mobility Invacare Pronto M41...
Make it go a little faster
Problem with Invacare Pronto M41 Power Wheelchair - Office Style Seat
Make it go a little fasterPermalinkReport Abuse
Jul 26, 2013 | Invacare Pronto M41 Power Wheelchair -...
Mothers m41 has locked missing the increase speed button and can not get it unlocked
Your looking at just getting a new joystick,After a short period in time dirt and trash will build up in the joystick which will cause you joystick not to turn on at all .Do your self and mother a favor just replace it.
Good luck
The Tech
Jan 21, 2011 | Electric Mobility Invacare Pronto M41...
One of my residents has a Pronto M91 Sure Step and it turns on, the horn button works, the speed buttons work, but it WILL NOT turn off. Please help me. Would that mean I need to change the joystick...
just replace the keypad or if you are mechanically inclined remove joystick take the top off and glue a small piece of foil to the bottom of the on/off button reassemble and try that if that doesn't fix it order a new pad from a provider in your area
Jul 30, 2010 | Invacare Supply Group Invacare Pronto M91...
Health & Beauty Logo
88 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
