Question about Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair
Have an Invacare pronto m41 will not turn on button worn out. Can we replace the face plate? or have to get a new joystick?
3 Suggested Answers
  • 692 Answers
SOURCE: I have an Invacare Pronto
mad check the freewheel levers under the front of the seat on the base make sure that they are in the drive mode turn the chair on and you should be good to go. Have the power off move the levers back and forth and leave in the drive mode then turn the power on and you should see normal lights and operation Hope this helps
Posted on Apr 07, 2011
wcdoc1953
  • 278 Answers
SOURCE: Where can I get a manual for the Pronto M41 Electric Power Wheelchair
You can download the M41 manual at the Invacare website:
http://www.invacare.com/doc_files/1143206.pdf
Posted on Jul 06, 2012
Can a joystick be programmed to not be so sensitive on a pronto m41?
There are adjustments that can be made with a programmer, a good technician can set these quickly for you.
Mar 29, 2016 | Electric Mobility Invacare Pronto M41...
No lights on joystick
Here is a parts catalog for the M41. http://www.invacare.com/doc_files/06_108.pdf
If it was working fine before you swapped the batteries then you did something to interrupt the current flow. Pages 49/50 show the location of the controller with a picture. Unplug the connections here and make sure they are clean and in good shape. Make sure all other connections are clean and tight.
If you have 24V coming off the batteries into the controller, and 24V going out to the joystick from the controller and still nothing is working, then you will probably need to get ahold of an Invacare service tech to replace the joystick. Before he does that he should swap out the old joystick with a new one to see if that is the issue. Invacare parts are pretty pricey...joystick by itself is over $500.00. If the controller is shot, then you can double that cost. Sometimes, both need to be replaced as they can kill each other.
If the chair is old or has a lot of hard hours on it, you can usually shop around on Craigs List, etc and find a good newer/near new chair for about the same price as a new joystick replacement.
Feb 23, 2015 | Electric Mobility Invacare Pronto M41...
Unlock a spj+ joystick on a pronto m41
Lets make sure this is just the joystick lock mode. When you turn the chair on and it is in joystick lock mode all the battery level lights will chase across several times and then the joystick will turn off.
When you turn the chair on and you see the battery level lights chasing from right to left push and hold down the power button till the lights turn off. Only the first year that the M41 was made had this option.
Jan 23, 2015 | Electric Mobility Invacare Pronto M41...
I had a wrench showing on my wheelchair. Now the wrench is gone and the unit will not turn off..
Hello, If the joystick won't turn off it is a joystick problem. You can unplug the joystick cable from the joystick to save battery if you need to. This kind of problem means your joystick will need to be repaired at Invacare or replaced by a dealer of Invacare chairs.
Jun 01, 2014 | Electric Mobility Invacare Pronto M41...
What does 7 times flashing mean is wrong on pronto m91
Seven blinks is most often the joystick. A Invacare Remote Programmer can be plugged in to the joystick to verify this.
May 28, 2014 | Electric Mobility Invacare Pronto M41...
How do I turn off the pronto m41 speed limiter
The Pronto M41 does not have a speed limiter per say. If the chair used to go faster than it does now then you may have some kind of problem with the chair. If the chair has always driven' slow, that is slower than the maximum 3.5 to 4 MPH then a Invacare Remote programmer is needed to program the chair to go it's full speed.
Seek a Invacare dealer and ask them if they can check the programming.
May 16, 2014 | Electric Mobility Invacare Pronto M41...
Joystick controller
McGiver would be proud if you could find the wires attached to the horn button and install a different pushbutton. The real problem will be to find a way of mounting the pushbutton in such a way that it can be accessed without interfering with joystick motion.
Jun 11, 2017 | Electric Mobility Invacare Pronto M41...
Make it go a little faster
Problem with Invacare Pronto M41 Power Wheelchair - Office Style Seat
Make it go a little fasterPermalinkReport Abuse
Jul 26, 2013 | Invacare Pronto M41 Power Wheelchair -...
Mothers m41 has locked missing the increase speed button and can not get it unlocked
Your looking at just getting a new joystick,After a short period in time dirt and trash will build up in the joystick which will cause you joystick not to turn on at all .Do your self and mother a favor just replace it.
Good luck
The Tech
Jan 21, 2011 | Electric Mobility Invacare Pronto M41...
Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Logo
50 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
