Kenmore washer 110 fills with water but does not wash or advance to next cycle
Should I hear a click when manually depressing the lid switch?
    Problem Solver:
  • 5 Answers
Sounds like the timer, can you advance the timer yourself? If you need to see if will run with the lid open, just use a screw driver to see if that door switch is working properly..
Posted on May 06, 2014
What could be wrong with our washer So our washer filled up with water and then will not go into the next cycle even if we try to manually do it Do you know what could be wrong
  • Does Your machine have a little switch button activated by the top door? (You can hear it click as you open and close the door.). If that switch is not working, the control click can not let the machine advance to the next step in the cycle.
  • Let US know what you find. M B
Jul 08, 2014 | Kenmore 24032\24036 Top Load Washer
Why does my kenmore washer 110 fill with water but won't wash or spin?
Do you happen to hear a humming noise coming from the machine after the tub fills? This might indicate that the motor is spinning, but the belt that connects the motor to the rest of the machine works is broken. It is located underneath the washer. Tip the washer a bit and have a look. If it's broken, you'll probably find the belt laying on the floor. Take that to an appliance parts store where they can match it up with a new one. Installation is not too difficult. The belt will go around the motor pulley, the transmission pulley, the water pump, and in some cases, a spring-loaded tensioner. I hope this helps! :) -Jason
May 06, 2014 | Kenmore 22422 Top Load Washer
Machine fills up with water, goes through the agitate cycle then stops and wont go into next cycle
Your Lid latch switch is most likely broken, you will need to replace it, you can not bi pass this switch. you can order it from your closest appliance distributor.
Unplug or turn off breaker to washer.
Replace by removing front panel, should be 2 screws at the bottom of washer.
Slide and depress lid latch down to release.
unhook wires and reinstall the same.
May 07, 2011 | Kenmore 22422 Top Load Washer
The washer will fill up but will no go through any of the cycles, this was after the washer was shut off during the filling period, restarted water filled washer and the nothing
I would check out your lid switch. You can look at the lid and see where the actuator pin would go down to depress the lid switch. See if your switch is broken off. You could also take a flat head screwdriver and manually depress the switch and see if you hear a click from it. It should run if your getting a click. Hope this helps _MJ_
Aug 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The washer filled with water, But it stopped and would not go through any of the other cycles. No circut breakers triped, and power to a three pronged plug available. Sears Kenmore Washer 110. 25862400
try opening and closing the lid,you should hear a clicking sound just before the lid closes,if you don't you havea broken lid switch.let me know what you find
Jul 25, 2010 | Kenmore 25862 Top Load Washer
Kenmore washer want go thru spin cycle
If it sits there with water and doesn't drain or spin, it thinks the lid is open. Try depressing the lid switch and see if you hear a click. Try replacing the lid switch.
Sep 01, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite Model 110 washing machine will not stope the agitate cycle
If the washer fills but does not agitate or spin, this is usually a symptom of a bad lid switch. The switch will either be located on the right hand side of the washer tub opening, or in the rear on the left hand side under the console. If you have a right hand model, examine the lid and make sure the plunger that activates the switch when it is closed is still intact. The plunger is a plastic piece that is physically mounted on the lid. Sometimes they break off. If the plunger is intact, try taking a small object (like a screwdriver or popsicle stick and push down on the lid switch contact while the lid is open and the timer knob started. You should hear a distinctive "click" when you push on the switch and the washer will agitate. Sometimes the switch can become loose and no longer make good contact. If this is the case, simply tighten the two mounting screws on the tub opening. If the switch relay is not clicking you may need to replace it. The part runs about $35.
If you have the left hand style switch that is enclosed under the console, the contacts are closed by a small metal bar on the back of the lid. Sometimes this bar becomes bent or loose. Open and close the lid and listen for a distinctive "click". If you don't hear anything, you may need to adjust the metal bar, or replace the switch. This style of switch tends to cost a bit more.
If you can provide me with your model number (located under the wash lid along the tub opening), I can research the part number for you and let you know where you can get it and give you step-by-step instructions on how to replace it. This is a simple repair job that the average consumer can perform with simple instructions and a few household tools. First, determine if this is the cause of your problem. Post back with comments and let me know if this helps you.
Nov 23, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
