Question about Scag SFZ52-26BS Freedom Z Zero Turn Rider
What is wrong with scag freedom z when it cranks you mow the lawn switch it off to cool, when you try to start again it just clicks? If you leave it alone for a day or two and try it again it cranks right up. I have replaced battery and solenoid switch.
  • 182 Answers
Could be something with the starter could be getting hot
Posted on May 06, 2014
Testimonial: "Clicking sounds like it is coming from the bottom of carbarator. Two wires attached one ground wire and one green wire."
  • 1 more comment
  • banklady46 May 07, 2014
    Clicking sounds like it is coming from the bottom of carburetor. Two wires attached one ground wire and one green wire. Ant ideas??
  • curtis chappel May 11, 2014
    The carburetor shouldn't do anything like that. I think it maybe the starter. Check all wire connections make sure there tight.
  • banklady46 May 11, 2014
    Ok I have taken handle switches off and put them back on. Took battery connection off put back on and it cranked. Ran a little while turned it off then wouldn't crank again. It seems that when you take the battery connection off and put it back on it reboots everything and it will crank. It has been raining so haven't got to mow with it to see it f it will crank after getting hot then trying to recrank.
I need a diagram to remove a housing on a scag freedom z
you need to figure out what you are trying to ask... if you mean dis-assemble the transaxle then you're looking in the wrong place. Scag doesn't build those. Hydro Gear does
Oct 20, 2014 | Garden
Key will not work in scag ztr
Go through your safety switches to make sure they are all being engauged proparly first.
Jul 28, 2014 | Scag SFZ48-600FS Freedom Z Zero Turn Mower
What is wrong when a Scag freedom z will not crank replaced battery and solenoid switch it ran and cut the yard switched off now will not crank. Clicking noise coming from the bottom of carburator. Two...
Recheck your connection at the battery and the solenoid. The clicking noise is probably the solenoid. The starter may have a shorted out field coil or armature. This will cause a starter crank over sometimes but it will have a bad spot where it will not crank. Check connection at starter as well.
May 07, 2014 | Scag SFZ52-26BS Freedom Z Zero Turn Rider
My freedom z will not start
1. Be sure the fuel shutoff valve, located behind the
operator's seat, is completely open.
2. Sit in the operator's seat, fasten seat belt and place
the steering control levers in the neutral position.
3. Engage the parking brake.
4. Place the PTO switch in the disengaged position.
5. If the engine is cold, choke the engine as needed.
6. Move the engine throttle control to about half engine
speed.
7. Turn the ignition key to the START position and
release the key as soon as the engine starts. Do
not hold the key in the START position for more
than 15 seconds at a time. Allow at least 60
seconds between each cranking attempt to prevent
overheating of the starter motor. Prolonged cranking
can damage the starter motor and shorten battery
life.
8. Allow engine to warm before operating the mower.
Apr 05, 2014 | Scag SFZ61-730FS Freedom Z Zero Turn
Won't start
The click means the starter solenoid is acting. Most starters are like GM autos where this solenoid is on the starter. Often heat adversely effects these parts. Try tapping the solenoid and try to start it. If that works then a rebuild is indicated.
Mar 26, 2014 | Scag STWC48V-25CV Wildcat Zero-Turn Rider
Huskee LT 4200 Lawn Tractor I had to jump my mower today and mowed for 45 minutes, turned it off, added gas, started mowing again for 30 minutes, turned it off and now it won't start, turn over or...
A couple of possibilities, either the main fuse has blown, they are normally an auto motive design and located undrt the the hood of the machine, or the start solinoid has burnt out.
Jun 18, 2013 | Garden
Scag wildcat STWC61V-26KA-LC backfiring
check for loose carby or failed carby to manifold / head gasket as it appears that you have a lean mixture problem xcheck for blockage in main jet.
Jun 12, 2013 | Garden
Blades will not engage but will remain running
It is most likely the switch. I had the same problem and that fixed. I found the switch on Amazon for less than $20. Stens 430-798 PTO Switch Replaces Scag 483957
Apr 05, 2013 | Scag SFZ52-26BS Freedom Z Zero Turn Rider
No forward or backward movement
change your drivebelt
shack
Apr 18, 2009 | Garden
Scag SFZ52-26BS Freedom Z Zero Turn Rider Logo
341 people viewed this question
Top Scag Garden Experts
JP Services
JP Services
Ted Maxwell
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Scag Garden Expert? Answer questions, earn points and help others
