THE CHARACTERS TYPED DOES NOT MATCH WHEN APPEARS ON THE PAPER ?
  • 328 Answers
What model typewriter do you have? Most have a setting key on the keyboard, usually on the left side to change keyboard or printwheel settings.
Posted on Jun 22, 2009
Sydellemollie@gmail.com
Unfortunately that is the default behavior of Gmail. Here are 2 suggestions:
1. After typing the first initial continue typing the name and the list will be update to match the typed characters.
2. http://productforums.google.com/forum/#!topic/gmail/iNgXoMJVC8Q%5B1-25-true%5D
Nov 07, 2013 | Google Gmail
My pound sign comes up as # and my @ as "
Windows 7 or Windows Vista
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, type intl.cpl in the Start Search box, and then press ENTER.
  2. On the Keyboards and Language tab, click Change keyboards.
  3. Click Add.
  4. Expand the language that you want. For example, expand French (Canada).
  5. Expand Keyboard list, click to select the English(United States) check box, and then click OK.
  6. In the options, click View Layout to compare the layout with the actual keyboard.
  7. In the Default input language list, click English(United States) - English(United States), and then click OK two times.
  8. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  9. Click the Language bar, and then click English(United States).
Windows XP
  1. Click Start , type intl.cpl in the Run box, and then press ENTER.
  2. On the Languages tab, click Details.
  3. Under Installed services, click Add.
  4. In the Input language list, select the language that you want. For example, select French (Canada) .
  5. In the Keyboard layout/IME list, click English(United States), and then click OK .
  6. In the Select one of the installed input languages to use when you start your computer list, click English(United States) - English(United States), and then click OK.
  7. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  8. Click the Language bar, and then click English(United States).
How to make sure that the selected layout matches the keyboard Windows 7 or Windows Vista
  1. Click Start, type osk in the Start Search box, and then press ENTER.
  2. Match the keyboard on the screen with the physical keyboard to make sure that the layout matches.
  3. To check the uppercase characters, click the shift key on the keyboard or on the screen, and match the characters printed on the keyboard.
Windows XP
  1. Click Start, type osk in the Run box, and then press ENTER.
Jan 07, 2011 | Dell Computers & Internet
The characters printed do no match the ones typed. I have taken the print wheel out and put it back several times.
Check the pitch slide switch on the L. of the keyboard, it should be in 10 or 12. If it is push down and slide it up and down a few times they do get dirty.
DickyO
Jun 14, 2010 | Swintec 7040 Typewriter
ML-300 Typewriter: different characters appear than what is typed...
To resolve this issue, you will need to replace the daisy wheel.
May 17, 2010 | Brother ML-300 Typewriter
Hi, I have a 1967 Smith Corona Corsair portable typewriter with case. All works fine except that the ribbon does not lift when keys hit the paper. So the keys end up hitting the paper directly (not through...
Is the ribbon selector lever located on the right side of the keyboard switched to either red or black? If it's on white, the ribbon doesn't come up.
Michael
Jan 11, 2010 | Office Equipment & Supplies
ML 100 Brother - Standard
If the characters are showing up different than the ones you pushed then your wheel is probably bent. First, open the clear cover on your ml100. Second there is a black lever that you pull towards you. Next, you pull the wheel out and if any of the arms on it are bent than straighten them out, and make sure none of the arms are over lapping. Next, return the wheel, push the black lever back into place, close the clear cover and then hold down the code button and press the reset key (the "q" key). If that does not work then you need a new wheel. This is what just worked for me, I hope it helps.
Jul 31, 2008 | Brother ML-100 Typewriter
Toshiba tecra s2 keyboard starts skipping typed characters and stalling
there may be a pressed key in your key board, but pls chcek the key board with keyboard tester free software to identify pressed keys.
pls remove the key board cap carefully and clean
Apr 29, 2017 | Toshiba Tecra S2 Notebook
Scanner
seems to me you havent inserted the paper to the scanner correctly, i have f380 right next to me and never had such a problem.
Apr 01, 2008 | HP DeskJet F380 All-In-One Printer
Critical technical help needed
Open the top cover and you will see a switch on th right side that allows you to select alternate keyboards. Make sure it is set to the #1 position
Aug 09, 2007 | Brother GX-6750 Typewriter
46 people viewed this question
k24674
jasbo
jasbo
