Question about Panasonic Televison & Video
Have Panasonic plasma mod TH-58PZ850U . Have picture but, has a lot of green. What could be the problem?
Picture comes in fine, but is all green. Comes and goes intermittantly. Using the remote I tried ajusting the color and the picture with no change. John.
  • Official Brand Answer
  • 350 Answers
Your cable box or satellite receiver could be causing the green screen. We recommend you ensure the box's 4:3 Override has been changed to Stretch or Off and Color Space has been change to RGB.
Posted on May 06, 2014
techman
  • 3130 Answers
SOURCE: Panasonic 42 " TH-42PWD8BK
Sounds like a main board or a sustain board problem. This is most definantly not a repair job for the consumer to attempt. Please call in someone who is experienced with Plasma TV sets, as these boards can be very very expensive. Too expensive for you to guess and buy and then have to order the other one. Oh this model also has some power supply issues as well. Good Luck Please do not forget to rate this thread.
Posted on Nov 27, 2006
AvioriX
  • 689 Answers
SOURCE: Panasonic TH-42PD50Uscreen colors all appear pink and green
Issue occurs due to malfuntion of LCD Module matrix. Seeking assistance from a qualified hands on technician adviceable. There are 2 major possibility First LCD module connectors might stained/loosen due to environmental causes such as humidity. Secon important possibility one of the driver Chip on LCD has stopped working. First possibility usually lower cost for repair. A further hands on diagnostic on LCD module will clarify best better.
Good Luck
Posted on Jan 02, 2008
SOURCE: The green light on for 2 seconds and off again (Panasonic TH-42PWD5UY)!
My plasma tv ONLY show green light for maximum of 2 seconds and off Itself again which means NO PICTURE, NO SOUND !
Posted on Jan 27, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
tvguy171
  • 106 Answers
SOURCE: Blinking Red Standby Light - No picture
The six blinks indicates that an internal fan is either bad ot blocked by dust or debris, You should be able to look in the back of the unit and see some cooling fans. Chances are one on them is not turning and will need to be replaced
Posted on Nov 26, 2008
Green tint in picture
Are the lines completely through the screen or just the upper or lower part of the screen? If through the whole picture, lines in the picture of a plasma can be caused by a defective Main Logic Control board or a bad plasma panel. The panel, if available would be very expensive (cheaper to buy a new TV). If the lines are just on the upper or lower part of the screen then it is the upper or lower scan drive board. Here is a list of the parts for your TV.
https://www.tristatemodule.com/t-Search.aspx?q=TH-42PX60U
Nov 04, 2013 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Panasonic TH-58PZ850U, red LED light blinks 6 times..TV will not turn on
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 08, 2013 | Panasonic TH-58PZ850U 58 in. HDTV Plasma...
Panasonic TH-C42HD18 42 In. Plasma TV inputs not working
yes. you find the main board for you panasonic plasma tv from shopjimmy.com.. good luck!
Sep 03, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
Th-58pz850u
It is Your Y-Sus Board,Looking at the back of the Television with the Back off it the Big Board on the Right
Dec 30, 2011 | Panasonic TH-58PZ850U 58 in. HDTV Plasma...
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Jul 25, 2011 | Panasonic Viera TH-50PX80U Plasma TV
The pictures are mostly green - like instead of black it shows green
It's called Cyan and it's sound like you are having a problem on your D-board. Look for capacitors bulging out and replace first if not then order D-board
May 01, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have a Panasonic th-42pw5 plasma screen
most likely it is the buffer boards and the z sus
Feb 12, 2018 | Panasonic Televison & Video
No picture power button blinks
We cleaned the dust off the fans and TV now works fine. Hardest part was getting the TV down and the back off to get to them. Thanks.
Dec 26, 2009 | Panasonic Televison & Video
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Jan 23, 2008 | Panasonic TH-42PWD5UY 42 in. Television
Televison & Video Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
