Question about Kenmore 22422 Top Load Washer
Why does my kenmore washer 110 fill with water but won't wash or spin?
The lid switch is fine and machine will fill at wash and rinse cycle if manually advanced.
  • 254 Answers
Do you happen to hear a humming noise coming from the machine after the tub fills? This might indicate that the motor is spinning, but the belt that connects the motor to the rest of the machine works is broken. It is located underneath the washer. Tip the washer a bit and have a look. If it's broken, you'll probably find the belt laying on the floor. Take that to an appliance parts store where they can match it up with a new one. Installation is not too difficult. The belt will go around the motor pulley, the transmission pulley, the water pump, and in some cases, a spring-loaded tensioner. I hope this helps! :) -Jason
Posted on May 09, 2014
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 686 Answers
SOURCE: kenmore washer,mod# 110 26292694/wash cycle only
CHANGE THE LID SWITCH
Posted on Apr 09, 2009
  • 240 Answers
SOURCE: No Spin No Drain
Lid switch is most likely the problem, if lid switch is visible under lid on right side then this is older design and common problem switch.
if you have console frame covers on front sides, snap off from top, a screw is at bottom front corners of console, remove and pull console forward and fold back. If lid swich is hidden then you will see it at left on top of cabinet with console folded back. a 5/16 screw holds a green ground wire to cab. remove and switch will unclip with lid up. If lid switch was visible under lid then you need to remove 2 brass clips holding cabinet on top of base to back, pry with screwdriver to unclip. undo harness connection on cabinet top, this is your lid switch connection. sw body is held by 2 phillips screws, harness tube held by clips on underside of cabinet top. ground wire with 5/16 screw present at sw body. New versions of this switch have metel shield attached.
Posted on Apr 26, 2009
  • 119 Answers
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Posted on Aug 21, 2009
lancaster5
  • 245 Answers
SOURCE: Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Posted on Aug 23, 2010
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Kenmore 110 washer fills and does the wash cycle but wont drain or spin. Totally shuts down after wash cycle. What do I need to replace
sounds as though the lid switch has gone bad, either that or the motor has lost the reverse winding on it.. most likely lid switch tho.
the lid switch is only "seen" by some older kenmore "110" series at the end of the wash cycle, or end of the rinse cycle. it purpose is to keep the unit from spinning if the lid is opened so no one looses an arm, etc.
generally the console on those machines hinges over backward so you can remove the cabinet top and 3 sides as a unit together..
the lid switch is under the machine top and isn't easily accessible without removing the cabinet.
May 20, 2010 | Washing Machines
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
Mar 27, 2009 | Kenmore 24032\24036 Top Load Washer
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer 110
hi thanks for the question i would check the lid switch very common for that make thanks the appliance doc
Sep 27, 2008 | Kenmore 22422 Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
62 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
