Question about Mitsubishi WD-60638 DLP TV
Blinking amber light on Mitsubishi WD-60638
Picture on the Tv went out then the entire Tv shut off. THe power light started to blink amber colored and wont turn on at all.
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
SD Tech
  • 14553 Answers
SOURCE: Power went out now the tv wont turn on, there is just a blinking
Does the power light just blink? Some of the Mitsubishi sets have a receiver built into them; if the power is removed the power light upon return of power should blink for 70 seconds and then go out--then the set should turn on---if the light never stops blinking---2 possible things--set should have a recessed button on the front keyboard(reset) that you can depress with something not sharp and see if after 70 seconds the light will stop blinking; if no, the set now has a damaged receiver(from the back of the set it is a large metal box on the far left side-----the blinking power light is the receiver trying to boot up like a computer---only should happen if power lost---let me know what you find----the receiver if bad is usually no longer available and can only be repaired by removing it and sending out for repair/rebuild.
I do this here for free so if this information helped you take a minute and give me a vote here......ALSO IF YOU HAVE ANY QUESTIONS OR NEED HELP REPLY TO THIS POSTING.
SD TECH
Posted on Sep 07, 2009
Slinteriors
  • 8617 Answers
SOURCE: blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Posted on Dec 25, 2009
  • 8 Answers
SOURCE: Blinking green light Wd-C657
sell it
Posted on Apr 16, 2010
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
WD-62526 shuts off
The power supply is failing. Your TV is able to start but the power supply can't continue operating and shuts down.
Dec 12, 2013 | Mitsubishi Televison & Video
No picture with sound tv turns off. Mitsubishi model WD65837
are any lights lit up when it shuts down? If so which light what color is it and is it blinking or a just stays lit without blinking?
Apr 05, 2013 | Mitsubishi WD 65837 TV
I had to replace my lamp bulb in my mitsubishi wd-60638 tv and now i have a picture again but it is fickering and greenish tint to the screen
If you tried a cheap bulb then that might be the problem as some of the bulb carrage may not be complete4lyto spec. I had one that was close but there was a gap between bulb and where it fits. I went with a bulb dealer that had I believe a 1 year warrante and I have had no problems. I had a 73838 tv set.
Jul 26, 2017 | Mitsubishi WD-60638 DLP TV
WD-60638 COLOR WHEEL PROBLEMS
Usually the wheel is not available except with a Light engine.
Aug 31, 2012 | Mitsubishi WD-60638 DLP TV
Getting a message that hdmi is blocked?????and have several blinking amber/green light turns red and tv shuts off....help please WD-65737
Hello!
Please, read my previous solution for WD-65.....
you'll find the answer to your questions.
good luck,
thanks,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-60638 DLP TV Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
