Question about Vutec 01-HD3072-128MWW HD III Deluxe Manual Front Projection Screen (72x128) 01-HD3072-128MWW 147" 16:9 Projector Screen
How do I get my screen to retract if it has been pulled down too far?
We have a projector screen that was pulled out to far. It is a wall mounted one. It will not retract
This could be one of two things.
1. The coil spring in the housing is wound so tight it wont release the pawls and allow it to retract.
2. The coil spring has come loose and has no tension on it.
Take it down from the wall and see if the end caps come off to show the pawls. You may be able to release them with a screwdriver.
Jan 17, 2016 | Office Equipment & Supplies
Pulled out the Holman hose out too far..now won't retract at all...hubby is going to kill me!
yeh i pulled mine out too far now wife wants to kill me!!
anyway opened it up and spring was broken!!
Apr 13, 2013 | Kitchen Appliances - Others
I pulled the screen down all the way and am not able to release it to make it go back up. It seems to be stuck.
csbala,
In most cases when the screen is pulled too far you can get it to release by giving a quick tug and releasing it quickly. It could take several tries to get it to retract but it should. Remember to give it a sharp, quick tug, more like a snap and release.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 06, 2011 | GrandView Elegant Pull Down Screen...
Da Lite projector screen will not retract. It is pulled all the way down
After pulling the screen down to the desire length, The mechanism will lock itself once you stop pulling.
To retract it, you need to pull the cord down again and allow the screen to retract on its own. The screen will retract rapidly at first but will slow down to a gentle stop when it reaches the case.
Try it.
Jan 30, 2011 | Da-Lite Model B with CSR(Controlled Screen...
Good morning my plummer put in my new 980t sd -dst touch 20 faucet....it works so far....however my pull down hose i have to some what push it back up for it to go in......on the video it looks like it...
If you can, look up under sink for hose attached to faucet. There should be a weight on the hose, to assist in retracting it. Usually just a bolted on round lead weight that wraps around the metal sleeve of the hose. Perhaps he forgot it, or it needs to be moved/adjusted by loosening off the bolts that hold it together and sliding it up or down the hose. He may have even routed hose wrong. Have someone pull it out and slide back in while you watch it.
Jan 22, 2010 | Delta 989-SSSD Allora Kitchen Pull Down...
The front seatbelt apparently has been pulled out too far, possibly twisted and won't retract. Is there an easy way to fix this?
can you pull it any more just to straighten it to retract it,or can you remove the trim on the pillar to see whats going on as you may need to do just that if you cant persuade it to retract,make sure the car is on level ground as angles and sudden movement effects them,but you may need to pull the trim off,worst case scenario,replace unit
Oct 26, 2009 | 1992 Nissan Maxima
I have a grandview elegant electric projection screen and when I retract it, it stops about a foot below the case and won't retract entirely into the casing. Help please.
Electric screens are just about the same as a garage door opener. They have a up and down limit setting. Usually screens will have the motor on the left as you look at the sceen, this is where the limit switch ajustment screws are. If they are labeled great, if not hopefully they are obvious to see on the motor or roller. Hope this helps.
Aug 05, 2009 | GrandView Elegant Electric Plug-In Screen...
The pull out faucet is loose, wobbly, won't stay attached.
Make sure that there is a weighted ball connected about halfway down the retracting hose. If not you need to go to a supply house and purchase one and its a simple install.However if there is one attached you can loosen the 2 screws and slide it up closer to faucett but not so far that you can't pull out the sprayer as far as you need. Also make sure nothing is obstructing it under the sink. bottles, cleaners, etc.
Jun 04, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Vacuum wand won't retract fully into it's compartment.
HI,
FIRSTLY DETACH WAND FROM UNIT AND SLIDE HOSE DOWN AS FAR AS IT GOES, SPRAY A LITTLE WD40 OVER WAND AND SLIDE HOSE UP AND DOWN, AS FOR THE CAP, TAKE A PAIR OF PLIARS, GRAB HOLD OF END OF CAP AND PULL CAP FULLY OUT OF THE HANDLE,AT THIS POINT CHECK THE SPRING OR REMOVE THE SPRING IF YOU PREFER AND PUSH THE CAP BACK INTO HANDLE AND THAT WILL DO IT FOR YOU.
REGARDS
DAZ
Dec 12, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vutec 01-HD3072-128MWW HD III Deluxe Manual Front Projection Screen (72x128) 01-HD3072-128MWW 147" 16:9 Projector Screen Logo
89 people viewed this question
Top Vutec Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Vutec Office Equipment and Supply Expert? Answer questions, earn points and help others
