Question about Kenmore 25,000 BTU Room Air Conditioner
New kenmore 25,000 won't cool only fan
Brand new straight out the box
    Problem Solver:
  • 19 Answers
Sounds like bad wiring job or didn't get charged with Freon at the factory. Return for a new one.
Posted on May 06, 2014
  • guyburcha603 Jul 15, 2014
    Should have a one year warrantyor at least 30 days
You probably have an electrical problem inside the unit. Since it is brand new it would be easier to just take it back to the store and get a new on. If you had a company install it then call them, I am sure they will come out and switch it no problem. If you did the job yourself you may want to consider hiring a professional to do the installation this time. Good luck!
Posted on Aug 18, 2014
I have a 2002 Lincoln town car and I just put a brand new fan in and its not coming on my car runs hot when I have it in park with the ac on
Did you check the fan relays ? There are two, cooling low relay an cooling fan high relay . The relays are turned on by the vehicles PCM - engine computer , when an input from the coolant temp. sensor indicates a certain temperature ! When you turn on your A/C the cooling fan should turn on an stay on .
Relay Box
Left center of engine compartment
Cooling Fan High Relay
In relay box
Cooling Fan Low Relay
In relay box
Do you know how to test a computer controlled relay ? Go to you tube an search relay testing . Does the temp. gauge work correctly ? I know you probably don't have a factory scan tool , but this is the where I would start , checking temp. sensor input to the PCM . An with a factory scan tool I can do bidirectional testing , see if I could turn the fans on will scan tool .
Mar 17, 2016 | Lincoln Cars & Trucks
New coolant fan and new control module but coolant fan does not work on my 2002 ford escort zx2
Try checking the fuse box under the hood. It should have a fuse marked cooling fan or cooling system. If the car does start, that means the computer isn't out, but maybe there is a bad relay by the fan or in the circuit or even the temp sensor may be bad. The fan won't run until the temp is high enough; usually by the time the thermostat opens.
Aug 11, 2012 | 2002 Ford ZX2
KENMORE REFRIGERATOR WON'T COOL ON BOTTOM BUT FREEZER WORKS BUT HAS ICE ON BACK WALL
needs fan replaced, there are a couple of plastic strips down the sides of the bottom plate, remove those to expose screws remove bottom pan then back wall fan will unclip from wires local appliance store should have one avaiable
Jul 04, 2012 | Kenmore Refrigerators
1985 new yorker cooling fan won't operate.
could be a bad coolant tempurature sensor if radiater cooling fan does not work, or a bad relay for fan in fuse box for the fan.. if all is ok ! disconnect fan at the connectors. on the motor side, run a wire from positive on battery, to pos itive fan motor. ground other wire to negative on battery. if the fan works its ok. good-day ! check relay and fuse for the fan first.
Feb 01, 2012 | Dodge Vehicle Parts & Accessories
I have a GE Monogram ZIBI240 Bar Refrigerator with Icemaker. This unit is brand new out of the box. We purchased it 5 years ago and it was never installed (for reasons I won't go into). Installed i
is the compressor running if so it is out freoin or compressor is bad or want start may be relay compressor should start after the fan starts
Dec 12, 2011 | GE Refrigerators
I have a 1999 Alero 3.4 V6 the cooling fans won't run. I checked the fans they both work if I unplug the harness for the temp sensor,the relays and fuses are fine,I replaced the coolant temp sensor and...
CHECK MODE RELAY IF BOTH RELAYS GOOD YOU CAN CHECK RELAY BY REMOVING IT FROM FUSE BOX HOOK RELAY TERMINAL 85 TO BATTERY POSITIVE AND GROUND TERMINAL 86 IF CLICKS RELAY GOOD. IF RELAY GETTING POWER GOOD AND THE 30 AMP COOLING FAN FUSE OKAY.EITHER THERE IS A SHORT IN COOLING FAN WIRING OR THE PCM HAS FAILED.THE PCM HAS LOST OR COMMAND RUN CIRCUIT IN PCM SHORTED OUT DUE TO PCM FAILURE.LET DEALERSHIP OR GARAGE USE DIAGNOSTIC EQUIPMENT TO ACTIVATE THE PCM SEE IF IT HAS FAILED.DONT SPEND MONEY ON NEW PCM COULD BE SHORT IN THE WIRING CIRCUIT
Sep 06, 2011 | 1999 Oldsmobile Alero
A friend gave me a dimension 8400 desktop that he said was broken. i know some about computers and tried to see what the problem was. everytime i turn the computer on, the cpu cooling fan goes crazy...
Thanks for the information, pretty detailed, I recommend you get all the specs of the Dell dimension 8400 motherboard and buy a compatible one, of course check the CPU first at a friend's home and if the CPU is fine, go ahead and buy and install a new one.
May 03, 2011 | Dell Dimension 8400 PC Desktop
Cooling fan 94 corsica
Replacing the fan is a straight nut and bolt job.
The fan is going to be the expensive part.
I would suggest a local wrecking yard for the part.
Oct 18, 2008 | 1994 Chevrolet Corsica
Kenmore 25,000 BTU Room Air Conditioner Logo
102 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
