Question about Saniflo & Saniplus& Macerator Pump
My sanivite is not pumping the water out or its extremely slow
  • 148 Answers
Make sure the vent on top of the unit is not obstructed. Did someone flush something that isn't supposed to be flushed? Baby wipes or feminine napkins are an absolute no-no. If the macerator blades have been tangled from something like these items, it will have to be taken apart to be cleaned. DW
Posted on May 15, 2014
Can you tie into a common dscharge pipe when plumbing a sanivite and saniplus?
I think it can be done , but it may be against the local code for your area. The obvious concern is back up of sewage in the sink, and washing machine.
Feb 01, 2013 | Home
Saniflow problem
My Sanivite has packed up again (humming no pumping) for the third time, (7years old!) always the capacitor, don't buy from Sanivite get off ebay half the price.
May 29, 2012 | Saniflo & Saniplus& Macerator Pump
Sanivite 3 makes humming noise and no longer pumps water out
Jonathan: You need to remove the pump from the shell and make sure the grinding impeller is not cloged up with hair or other junk. Also, is you drain line out of the unit completly clear?
Dec 12, 2011 | Saniflo & Saniplus& Macerator Pump
Purc'd 4/25/10, just recently cold or cool water is extremely slow fillimg. WHY?
Thanks for choosing FixYa and welcome to the site. You may have a pump going bad or the water pump may be clogged. Try taken it out and cleaning the pump. More then likely, this will solve your problem. Articles can get down there and clog the machine up.
Apr 11, 2011 | Whirlpool Washing Machines
Motor will not shut off unless disconnected from the electrical outlet. Unit is connected to toilet - tub & sink. Unit model is: Sanivite EN 12050-2 FF0V30 120v 60Hz 5,7A 4/10 HP age 4 yrs.
The Sanivite is a gray water pump, does not have a connection for a toilet. It has a pressure chamber inside the pump casing and a float switch at the bottom of pressure chamber. You will find a black rubber membrane which water pressure pushes up on the membrane and turns the unit on and off. It could be that something is stuck at the bottom of the membrane keeping it in the on position the whole time or the membrane might be warped. Also the micro switch may be stuck on the on position. Pry open the lid with a flat head screwdriver and inspect the pressure chamber.
Sep 04, 2010 | Saniflo & Saniplus& Macerator Pump
Cold water flow is extremely slow. have checked
REMOVE THE COLD WATER HOSE FROM THE WASHER, AN LOOK INSIDE THE VALVE, AN CHECK THE SCREEN, FOR BLOCKAGE, SPECIALLY IF YOU HAVE HARD WATER IN YOUR AREA.,
I HOPE THIS FIX YOUR PROBLEM LEAVE SOME FEEDBACK!
Feb 03, 2010 | GE Profile WPRE6100G Top Load Washer
I have a 3 year old Sanivite 3 macerator that has stopped pumping. It is used under the kitchen sink for removing water and soft food waste. Yesterday I removed the unit and cleaned the inside which was...
if the unit is properly clean and you have checked the fuse - then i suggest it is the microswitch that needs replacing. these tend to go (break) within 5 years on the sanivite 3 models. If not the swich then it could be the capacitor (try this first - although as the swich is located next to the capacitor you can test this for operation at the same time). if none of this works then its time for a new unit.
Nov 09, 2009 | Saniflo & Saniplus& Macerator Pump
Water is coming out but extremely slow
You have a sock or a small item of clothing blocking the inlet to the pump.
Lay the drain hose down into a bucket to get all of the water out of the machine.
Take the back panel off and undo the clip holding the hose to the pump inlet from the drum make sure you have a shallow dish underneath to catch any water remaining in the hose.
Remove the hose and retrieve the clothing
Aug 03, 2009 | Whirlpool Washing Machines
Water dispenser is slow
There is no pump in this refridgerator to provide cold water. Water arrives via pressure from the household cold water line that has to be provided to the rear of your fridge. Two possible solutions:
1. The filter in the upper right of the refrigeration (not the freezer) is clogged by normal minerals, etc. It should be changed at least every year, unless you have major sediment in your household water lines.
2.) The amount of water being delivered to the rear of the refigeratior is being restricted somehow. Trace from the connection on the back of the fridge to see where the water line (either thin plastic line or a small, flexible copper pipe) travels to a cold water line in the house. Look for kinks in the pipe and also look for any shutoff valves that are turned almost closed.
Mar 13, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Slow draining water and leaking
It needs to be inspected by an appliance repair guy. Your water pump may have a loose coupling causing low pump pressure, or the path water takes out of the machine is blocked.
Kev
Feb 24, 2008 | Washing Machines
Saniflo & Saniplus& Macerator Pump  Logo
229 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
