Question about Frigidaire FEF336BC Electric Kitchen Range
How to disconnect beeping hotpoint stove digital timer/clock?
How can I disconnect it?
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Patti,
I understand that your Hotpoint stove digital timer/clock is beeping and you are wondering how to disconnect it. I suggest resetting your stove by either unplugging it or disconnecting the power at your home's circuit breaker for 3-5 minutes. When power is restored, if your stove is still beeping, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what the cause of the beeping is. They will also be able to assist with repairs, if needed. Hope this is helpful.
-Best Regards-
WP
Posted on May 12, 2014
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 19, 2014 | Thermador Ovens
I have a hotpoint electric ignition gas stove...digital clock is acting funky so I want to diconnect it....how?
If you disconnect it, you will loose functions to the oven so you will need to replace the clock/control board. Here is the part to order.
Feb 09, 2013 | Hotpoint RB757 Electric Kitchen Range
I have a hotpoint older stove don't have the model # at this time. the digital display on my oven stopped working { stovetop works fine). After about 2 months of nothing all of a sudden it lights up...
The beeping indicates to me that the clock has power to it and it's the problem and needs to be replaced. ya need model number to order part it usually can be found on rim around door or inside of the bottom storage drawer, when ordering parts its call by 4 names, all are the same part its either clock, eoc,oven control,or relay board
Gene
Aug 03, 2011 | Hotpoint RB790SHSA Electric Kitchen Range
Hi there. Our Moffat stoveModel 24K60 has been in service since 1966, and, with a few minor service calls is still ticking along. No pun intended, but that's the problem. The clock is not only...
Hello there schematics for your unit will be next to impossible to find on the internet. My guess is that your unit uses a manual type timer as units that old usually have the timer independent of the other functions of the unit.therefore you wont be able to find any wires which power the unit. Mostly the timer will run on its own as a result of sensors on the unit. Both options which you have considered are gud but lubricating the bearings seems more likely although getting at it might be a bit difficult what you need is a watch expert usually they have methods of loosing out the entire clock mechanism taking it for servicing and fixing it back on your unit this way the bearing noise will stop. Also if you decide to take of the clock completely the same procedure applies.
Hope this solution has been helpful?
Apr 15, 2011 | Kitchen Ranges
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Hotpoint stove with f3 code.
Replace the oven control module.It controls the bake and broil including clock and timer functions.
Jan 28, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Range clock/timer broken
That type of clock is highly failure prone.
May 25, 2017 | Kitchen Ranges
Setting Clock on Hotpoint Stove
push in on the center one I think
Mar 10, 2008 | Kitchen Ranges
Frigidaire FEF336BC Electric Kitchen Range Logo
203 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
