Question about Kenmore Grilling
Fuel gauge not reading full tank. How does the work?
New kenmore grill model 146.2367.4310. Installed new tank and the gauge still reads empty. The grill works fine. The gauge does not. There is no instructions on how this works. It's the black box one with a brass colored needle.
burzerko
  • 254 Answers
SOURCE: Gas Grill regulator freeze
yes you need to replace the regulator it sounds as if the vent is plugged.
Hope this helps
Posted on Jun 22, 2008
SOURCE: propane grill
I had this problem when I turned on the burners before I turned on the tank, to fix it I had to turn everything off. Then turn the tank on and wait about a minute for pressure to build in the lines then turn on the burners. Hope this helps
Posted on Sep 03, 2008
TheMobilian
  • 8220 Answers
SOURCE: Loss of pressure on Kenmore 16322
I can tell you EXACTLY what is wrong. Remove the tank and open all valves to the grill. Reconnect the tank and turn it on just slightly. Relight the grill.
Ther is a safety device in the tank that needs to be reset. The only way to do it is removing the tank.
Posted on Dec 17, 2008
  • 13 Answers
SOURCE: 1993 Jeep Grand Cherokee gas gauge reads empty but tank is full.
Fuel level sending units are known to go bad on these.
Posted on Jun 22, 2009
  • 497 Answers
SOURCE: 2002 Chevy Suburban: Fuel gauge reads empty, tank is half full
Youre gauge is controlled by a plunger in the fuel tank which is attached to the sensor and the fuel gauge. it sounds like when the plunger goes down half way its either getting stuck down lower then it should. Needs replacing. Any mechanic can do this install for you.
Posted on Aug 27, 2009
Installed fuel pump and sending unit on 94 park avenue now fuel gauge doesn't work it was fine with old unit. Now it reads empty
Buick gas tanks are shaped so when full they take a while before the gauge comes off full. After 1/2 then the gauge will move towards empty quicker. When on an incline it will show more gas than is actually in the tank, so when you're cornering, it's reading will be indicating the moving level. I wouldn't worry about it
Sep 11, 2017 | Cars & Trucks
Fuel gauge not working
You will need to test a number of things, the fuel gauge is part of a rather simple circuit.
Battery -> gauge -> tank sensor -> chassis ground to battery
If the circuit is broken at any of the steps, your gauge will read "empty". If the tank sensor is bad, it could read empty, or if the float in the tank has sunk, it will read empty.
I start at the gauge with a "test light" that glows when it sees battery voltage. Get a light at the connection to the gauge? Good. find the sensor connection, usually on top of the tank, accessible in the trunk. Probe with test light. Light on? Good. Connect wire to ground, gauge should read "full". If all that is as I said, then the tank sensor is bad. If you don't read battery at any step, you know where the problem is.
Nov 13, 2015 | Cars & Trucks
I changed fuel pump. Now the gas gauge does not work
year/make/model?? Does the gas gauge read empty or hard full? If it reads hard full, suspect a ground problem at tank. If gauge doesn't work at all, make sure there is power to the plug at the tank. It is also possible the float arm may have become disconnected as some of these units are tight to get back in the tank. I have also seen new pump/gauge assemblies with defective sending units resulting in non working fuel gauges.
Oct 12, 2015 | Cars & Trucks
Why does my crysler 1996 reads fuel gauge full when it is empty
The fuel level sending unit inside the fuel tank is bad or the gauge is or there is a wiring problem This video is for a mercury vehicle , but all makes an models are the same . Repairing Fuel Gauge Problems 2004 Mercury Marquis EricTheCarGuy
Mar 17, 2015 | Cars & Trucks
My gas gage reads empty but stays lit up on 2005flht
The fuel gauge sender is mounted internally in the fuel tank. There is a three pin connector that will have a Yellow/White wire in it (the middle wire) under the center console. This is the sender wire. Connect an ohm meter between this wire and the black wire and check for the following readings:
If fuel tank is full, the reading should be 7-14 ohms. An empty tank should have a 74-95 ohm resistance. A half full tank will be approximately 30-38 ohms.
If you ground this wire that comes from the harness, the fuel gauge should read full. If not, then fault may be in wiring or the fuel gauge itself.
Remove the front fairing to gain access to the gauge. You should have 12 volts across the orange/white and black wires. If not, check accessory fuse. If 12 volts present ground the yellow/white wire at the gauge. Gauge should read full scale. If not, gauge faulty. If gauge reads full scale, check wiring from gauge to three pin plug under tank console.
Jul 27, 2014 | Harley Davidson Motorcycles
Put in new fuel pump and sending unit. but my gas gauge doesnt always work. sometimes is does and sometimes it doesnt
if it worked for a short period of time after doing the pump/sending unit the check the connections going to the pump/sending unit they would have been moved around doing the pump
Aug 11, 2012 | Cars & Trucks
Fuel gauge reads past full all the time
when the tank is full the resistance is low so the power through the gage make is read full
as the tank empties , the resistance increases so the less current means the gauge reads less until empty there is little or no power , the gauge reads empty
simple check , turn the ignition off, no power , no gauge reading
Sep 09, 2017 | Chevrolet S 10 Cars & Trucks
I have a 2004 pontiac montana. for about two years the fuel guage would fold over and read 125 degrees when the tank is full. it woulld stay there until tank was empty and the needle would drop to empty,...
It could be a bad fuel gauge in the dash unit, but....
Usually it's "The bad".
The fuel level sending wipe arm and windings on the fuel sender wear and send erratic readings.The only cure is a replacement fuel gauge sender.
The check engine light should not be related to the erratic fuel readings.
"The good".
If you have over 200,000kms or 120,000 miles on your van you need a new fuel pump anyway,so have a complete assembly put in which will have a new fuel sender on it.
May 21, 2017 | 2004 Pontiac Montana
Gas gauge doesn't work changed out the fuel pump or the fuel card and still don't work it's a 1999 chevy malibu
Just had a new fuel pump installed in 2002 Chevy Malibu. Worked great for about a week and then the fuel gauge started reading "empty" when the car has a full tank of gas. What happened?
Jun 13, 2010 | 1999 Chevrolet Malibu
Fuel gauge not working all the time.
This is a normal concern.
The instrument cluster uses 4 different operating modes to calculate the fuel level:
Anti-slosh (default mode)
Key OFF fueling
Key ON fueling
Recovery
After a fuel fill up, the time for the fuel gauge to move from empty (E) to full (F) ranges from 2 seconds to 55 minutes depending on which operating mode the fuel gauge is in.
The default fuel gauge mode is called the anti-slosh mode. To prevent fuel gauge changes from fuel slosh (gauge instability due to changes in fuel sender readings caused by fuel moving around in the tank), the fuel gauge takes approximately 55 minutes to go from empty (E) to full (F).
The key OFF fueling mode (2 seconds to read empty [E] to full [F]) requires 3 conditions be met:
The key must be in the OFF position throughout the entire refueling of the vehicle.
At least 15% of the vehicle's fuel capacity must be added to the fuel tank.
The instrument cluster must receive a valid key ON fuel sender reading within 1 second of the key being put into the RUN position. The key ON sample readings are considered valid if the fuel sender reading is between 15 ohms ± 2 ohms and 160 ohms ± 4 ohms.
If these conditions are not met, the fuel gauge stays in the anti-slosh mode, which results in a slow to read full (F) event.
The key ON fueling mode (approximately 90 seconds to read empty [E] to full [F]) requires 3 conditions be met:
The transmission is in PARK (P).
The key is in the RUN position.
In key ON fueling mode, a 30-second timer activates after the transmission is put into the PARK (P) position (automatic transmissions). When the 30-second time has elapsed and at least 15% of the vehicle's fuel capacity has been added, the fuel gauge response time is 90 seconds to read from empty (E) to full (F). When the transmission is shifted out of PARK (P), the fuel gauge strategy reverts to the anti-slosh mode. The key on refueling mode prevents slow to read full events from happening if the customer refuels the vehicle with the key in the RUN position.
Recovery mode is incorporated into the instrument cluster strategy to recover from a missing fuel level input during a refueling event. Missing fuel level inputs result from intermittent opens in the fuel sender or its circuits. Recovery mode (empty [E] to full [F] approximately 20 minutes) is initiated when the following 2 conditions are met:
The instrument cluster is in the anti-slosh (default) mode.
The actual fuel level in the tank is greater than what is being displayed by the fuel gauge
Feb 18, 2009 | 1983 Mercury Grand Marquis
Grilling Logo
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
