Question about Cameras
My Canon Pixma ip6000d printer is printing my pictures with a red hue.
My Cannon IP6000d printer is printing all pics with a red wash to them. I deep cleaned, nozzle checked and everything my printer would do. I even took out ink cartridges and let them sit on a warm wet paper towel to make sure ink was not clogged or whatever. My pics are still coming out red. Please help.
  • klwis2004 Nov 06, 2007
    I'm having the same problem . I have cleaned the pads inside the printer and the well that holds the excess inks. Still no solution
SOURCE: Canon A640/A630
hows the memory on the computer and is the system recent
Posted on May 17, 2008
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
Tech Jenkins
  • 359 Answers
SOURCE: red verticle lines
the redish hue usually mean that the camera doesn't have enough light to take a good quality pic. If daytime pictures taken outside still look the same take it back or get a new camera.
Posted on Aug 13, 2008
  • 31 Answers
SOURCE: Kodak EasyShare Printer Dock Series 3
If the boundary between the blank half and the printed half is a sharp line, a wire to the print head may be broken or disconnected. If the boundary is irregular (wanders up and down an 1/8 inch or so), the problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
Posted on Mar 20, 2009
SOURCE: canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Posted on Apr 03, 2009
My printer Canon PIXMA iP6000D stopped printing and ERROR 5200 appeared.
Error 5200 is print head temperature rise,you need to change the print head.The part number is QY6-0050.If a have been useful please give me a vote :)
Mar 11, 2011 | Canon Pixma iP6000D InkJet Photo Printer
Ihave a canon pixma iP6000D want to mirror image
Download some free software, the "GIMP" (Graphic Image Manipulation Program) from and use it to "flip" your image.
May 30, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Printing black pictures green
check all inks replace as required run test first check leads
Oct 03, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Printing wrong colors
you might be running out of the red ink.
Whenever a printer prints the whole image but with different colors it means that the printer uses the available color with enough amount.
Try replacing it with new ink cartridge.
Jul 28, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Photos are smearing - mostly green and yellow
Can I install printer iP1880 use Cd installer ip1800
Jan 29, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Won't print
Hi - You can download the manual by clicking the link underlined in blue below:
Pixma iP6000D
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Sep 15, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Streaky pictures
hi, your head has damaged/need replacement. Try to clean it once again
Aug 15, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Cameras Logo
81 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
