Question about Amana PTH123B25AJ Heat Pump Air Conditioner
My air kicks off in a very short time
My heat pump runs constantly but my air kicks on for a moment then kicks off repeatedly.I had a alarm system installed & I believe one of
installers removed a small box from under my intake vent. I believe it was conected to the thermostat.
  • 3,267 Answers
Well that is why it is behaving abnormally. The correct temp for it to start and when to stop are guided by the thermostat sensors, so If one is missing, its disrupting the entire cycle. Please have it replaced.................sodeep
Posted on Jun 22, 2009
On a water cooled scotsman ice machine, should the water be running out of drain line contiuously as its making ice? be cause it just runs all the damn time and thats a huge water bill ...
On a water-cooled system, by design the heat from the machine is being transferred to running water that carries the heat away. Some installations pump this "waste" water to a heat-exchanger or cooling tower (typically on a rooftop), where the heat is transferred again, this time to the air. The water with the heat removed is then recycled back to the machine, where the process is repeated continuously. There is thus no "wasted" water.
If your cooling water is just running down the drain, that's a terrible waste of water and money. Try to find a way of recycling the water by removing the heat and re-using it. Think of ways to use the "free" heat in the water.
Alternatively, buy a proper rooftop heat exchanger and pump the water through it, or, get an old car radiator or air conditioning condenser and a decent blower, and make your own.
Remember that your machine needs constant cool water in order to avoid overheating the system.
Oct 31, 2013 | Kitchen Appliances - Others
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Fan running constantly in the house
Check t-stat and make sure fan is set to "Auto", that might be why fan is running all the time, or it could be a fan relay that is stuck closed. It sounds like you A/C is over charged or you have a bad high pressure switch, this was a common problem with this manufacture especially in the heat mode.
Apr 24, 2009 | Ruud Central System Air Conditioner
Fan is still running in house constantly
Check your wall thermostat to make sure the "fan" switch is in the "auto" position. If it is set at the "on" position, the indoor fan WILL run continuously. Not really enough info as to what type of split system you have. Gas? Electric? Heat pump? Oil? Wood? Newspapers? See what I mean? Is it variable speed? Do you have a "special" thermostat for certain operations? Does your system incorperate inverter technology?
Ruud 12 seer heat pump not heating
It sounds like the unit is tripping off from high pressure. Check you filter and indoor coil. You may have low air flow inside that is causing the refrigerant pressure to be to high.
Mar 22, 2009 | Ruud Central System Air Conditioner
No heat new thermostat
you have a short in the wireing.disconnect at air handler and hook-up short t-stat wire to t-stat,ifok chk wire to condenser
Jan 10, 2009 | Heating & Cooling
Heater comes on and go off when it wants to.
What you're likely referring to is the blowing air starts and stops erratically. Since the heater uses heat circulated from the engine, if the air is constant and the heat comes in and out then that's a different issue.
Firstly, if the airflow starts and stops, you'll find a loose connection between the the fan switch and the blower itself. If the connections are sound, then look for a loose ground connection to the blower. If all electrical connections are good, and it still starts and stops erratcially, then it's time for a replacement blower.
Secondly, If the air is constant and the heat comes in and out, the the options are a faulty water pump or partial blockage in the colling system or heater core. If the water pump is failing and working erratically, then when the heat dissipates in the cabin airflow (it has used all the heat in the heater core and no circulation to replace the cooled water with hot water) the dash temp gauge should start to climb, indicating that the coolant is no longer circulating, the heat has left the heater core but the engine is not being cooled. You'll need to replace the water pump. If this is the case, take care of this ASAP as you run the risk of a an engine overheat.
If the dash temp gauge looks normal, then you're likely looking at a partial obstruction in either the cooling system or the heater core that blocks the flow and then works its way loose erratically. Limescale and crud buildup in your cooling system (especially in a 15-ys-old car) can cause this when flakes of buildup brake loose from the walls of the larger channels and get caught up in the smaller ones. Your local parts store will have additives to clean out the cooling system, but if they don't work (they can only do so much) then you're looking at a professional cooling system flush. If the issue persists after that then you're likely looking at a heater core replacement.
Also check to see that your a/c is not kicking in erratically. It shouldn't completely cool down the full-hot airflow, but it will cool it. You can tell if the a/c unit is kicking in as you'll hear the compressor clutch kick in and the engine revs/sound will change under the load. If this is the case look for a short in the a/c wiring.
Hope this helps, and please rate my answer.
Dec 31, 2008 | 1994 Geo Tracker
Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Nov 20, 2007 | Ruud Central System Air Conditioner
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
212 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
