Question about Platinum Memory Bsa Platinum Riflescope 32x44 Ttmd Pt832x44ts
My scope is broken
I have a bsa platinum scope 8-32x44 and after firing 12 shot the scope got bler, the lence of the zoom inside the scope moved from its position, how can i fix it? thank you
  • 4 Answers
Return the scope to where you purchased it and ask for it to be replaced. Or check out BSA's warranty page at: http://www.bsaoptics.com/returns.aspx . At any rate, DO NOT DISASSEMBLE YOUR SCOPE! This will void any chance of returning it and make it into a poor baton.
Posted on Jul 07, 2009
I have a BSA sweet 17, 2X7X35 all The black paint on the Tube has turned really sticky, when you touch the scope the paint gets all over your hand.
The coating that BSA used on their scopes reacts badly with certain airborne oils and softens rubs off and looks scabby
Only thing to do is to rub the rest of the coating off with high acetone nail polish remover
Apr 20, 2015 | BSA Optics
My bsa sweet 17 6-18 is shooting about 2 inches high at 100 yards. on the adjustment turret it has an arrow that shows which way to turn for up. What is moving up? the point of impact relative to the...
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Hope this helps Fix ya up.
Jun 02, 2011 | Bsa Optics Sweet 17 Target Riflescope...
We cannot get the scope to zero in
you may have a faulty scope,,so,,,clamp your rifle into a jig so it cant move about first,,,then bore sight it,,,without moving it test fire it and set the scope up to were the shot hit, ,fire it again the shot should hit the same spot or very close to it, if it keeps moving about mark were the cross is pointing jam the gun down and fire it off a fuw times if its still jumping around its your scope,,go buy a new one? but you must jam the gun so it cant move about,,,,
Nov 27, 2010 | Tasco WC 416X40 MBLK TADWC416X40
Cross hairs sideways?! BSA scope HM39X50RGBD Only 50 shots threw new Gamo Socom Extreme. Gun came with scope pre-installed.
If you are seeing an X you need to loosen the scope rings, re-level your scope and re-tighten the scope rings. 10-20 in/lbs on the ring screws, 15-30 in/lbs on the mounting screws. Typical configuration of the turrets is one on the top, one on the right side.
Mar 21, 2010 | BSA Optics
My elevation and windage adjustments aren't moving my scope. I shot 4 times and my group is 1 inch. Problem is I adjusted my scope between all 4 shots. I'm consistently shooting 7 inches high and 3 inches...
This can only be due to a "broken" scope. To be sure, you can put your gun in a vice (cushion it) and put the crosshairs on a fixed point. Without moving the gun, crank the adjustment knobs a good 10-15 clicks in one direction each, and see if the crosshairs move from where you had them pointed.
If they do not, the scope must be replaced. If they do move, perhaps you should try adjusting the scope quite a bit more between shots.
The best way to sight it in requires a helper. Fire one shot with the crosshairs on the bullseye. Then, without reloading, put the crosshairs back on the bullseye, and have a friend adjust the knobs until the crosshairs move to the ACTUAL point of impact of that shot. It is essential NOT to move the gun while doing this.
This method allows me to sight any gun in with only 2 shots (and a few for confirmation, of course). Best of luck!
Nov 23, 2009 | BSA 3-9x40 Deer Hunter Riflescope
Bsa superten problems firing
Give BSA a call at: 01494 676740 If you're not in GB, it's an overseas call.
I know it's a dumb question (maybe), but are you sure the bolt is fully advanced and locked and the safety's off?
Mar 26, 2009 | BSA Air Gun Scopes
BSA 3-12 x 50 Rifle Scope
But a new scope. Having the crosshair reseated will cost you more than getting a new BSA scope.
Feb 16, 2018 | Science & Laboratory
Platinum Memory Bsa Platinum Riflescope 32x44 Ttmd Pt832x44ts Logo
195 people viewed this question
Top Platinum Memory Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
Are you a Platinum Memory Optic Expert? Answer questions, earn points and help others
