My washing machine works went it wants to its not drawing water ive cleaned the filter but dont know what else to do,
  • 221 Answers
99 out of 100 washers tend not to drain water out due to blockage inside either waste water pipe (also called waste hose, drain hose and etc.) or circulation hose (the one between pump and drum). To check this lay the machine down on one of the side walls, remove the back cover (2 or 4 screws), disconnect hoses from the pump and ensure all blockages are cleaned away, all coins, small socks and other stuff is removed. Also you might want to clean the pump itself as at this point you're more than half-way through.
1 out of 100 drain malfunctions appear due to pump motor or the main PWB, but I bet that you won't need to replace neither of those.
Please let me know if there's something more I can help you with
Good luck
Posted on Jun 22, 2009
I bought an older 842 washing machine. It has been sitting for awhile so I cleaned out the filter. At first I did not get the plug back in and water ran out and the inlet fault light came on.
Sounds like either the small filter at the inlet solenoid valve or the solenoid valve itself. Either way you are going to have to get inside the machine to get to the inlet valve.If no water is coming through the soap draw then it can really only be at the valve OR the inlet to the soapdraw is blocked (again - need to take off the top to look) Make sure power is disconnected before you do. The flashing red light after 30 seconds or so is just letting you know that the drum has not reached certain water level in the appropriate amount of time.
Good luck
Aug 28, 2015 | Miele Washing Machines
Hi I have a LG front loader washing machine after the was cycle is finished there is still washing powder on the draw and it's gone hard have clean the draw and filters
problem with the water pressor. its should be 5 bar.if its not some remaining detergent you can find end of the cycle.
Dec 15, 2013 | Washing Machines
How do i get to the impellar on the lg front load washer
Please check these links which could be helpful to your case.
Smelly washer
Jul 02, 2012 | Whirlpool Washing Machines
Washer does nothing
It sounds like a fault with the control module, it could be as simple as a broken solder joint or something more serious. The beat you can do is start investigating as see what you find.
Mar 10, 2012 | Hotpoint Washing Machines
Horible smell comingfromthe drum, took the filter out to clean it, now it is leaking, what can I do? ps smell still there, have tried 1 95o wash with no joy
For the pump try taking filter back out and putting back again for smell clean out the rubber door seal with soapy water after the door seal is clean clean the despencer draw fully by taking it out. When you washed the seal and draw get washing machine clean for local super market and do a 95oc wash it should smell nice now if not could be drains hope this helps.
Jul 29, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint wd62
Try taking the top off, power off obviously!! and remove the draw unit, there is a pipe that runs from there to the drum.... I found a sock in mine that was the problem !!
Feb 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Water leak the water seem to be comin up on it self out of the draw where you put the power
mabey the filter is cloged a little there is a small plastic tube from the drawer to the filter ,had the same problem cleaning the filter worked
Oct 04, 2008 | Washing Machines
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
