Question about Bosch AquaStar 125FXKIT-NG 125FX Natural Gas Tankless Water Heater w/ Hood
Bosch 16p gas, keeps going hot and cold
I have a bosch 16p which is about 8 years old.....for some reason it heats up for a few seconds the goes cold, i can not get constant hot water. any suggestions? easier just to call a plumber? do i need a new system?
As Duncan Vu suggested, its probably your diaphragm. The quality of them seems to have gone down hill in the past 10 or so years and you will probably get about 3 years out of them before they wear through. Piece of cake to change out. 1. TURN OFF THE GAS, 2. Turn Off The Water. 3. Disconnect the water pipes from the Diaphragm housing (don't lose the washers). 4 Two philips head screws lock the top of the diaphragm housing into the gas housing, loosen these and the diaphragm housing will drop out. 5. You can now carefully hold the diaphragm housing in a vice and undo the three large philips head screws that hold the diaphragm cover on, lift it off, pull out the old diaphragm and put in a new one. reverse the steps to get it back together and you should have constant hot water again for another few years. Please note this is just a rough guide and if the steps seem in any way difficult or not obvious don't try it. I'm not responsible for any damage you do to you or your house or yourself if you screw it up....
Posted on Mar 19, 2014
    New Friend:
I had the exact same problem, I called Bosch and they gave me a local contact (hot water repairer). I spoke to him and told him the problem and he identified the likely caused over the phone, he attended and replaced the diaphragm in the regulator - all fixed and back to normal endless HOT water.
Posted on Jun 25, 2013
  • Duncan Vu Jun 25, 2013
  • 332 Answers
Check the thermostat, you will probly need someone that has worked on the same kind of unit, they are not all the same {tankless} I would suggest a repairman,, there is a little bit much to explain how to do it over the internet,
Posted on Jun 23, 2009
I have a Heatslave 12/14 oil-fired combi boiler installed approx 8 years ago. A problem has just developed on the domestic hot water side. My local heating engineer has investigated but so far hasn't...
Symptoms sound like crossover might be part of problem:
Crossover is when cold water enters hot water line due to faulty plumbing part like check valve, mixing valve, or bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
Jun 12, 2011 | Bosch Water Heaters
I have a Bosch 250sx NG I hired a plumber to install. I have 3/4 water and 3/4 gas line to unit. When turned to hot the water is cooking, turned down it is great,,, almost. My water will turn cold for...
Before calling service technician, open following link for Bosch troubleshooting steps.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
If you are not getting error code, then problem could be somewhere in plumbing, as you suspect.
For example cross-over on single-handled faucet, or faulty check valve on re-circulation system, or sediment clog at elbow, or varied water-well pressure. Install in-line pressure tank.
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Be sure to read manual for yearly maintenance protocol.
Tankless must be maintained, and cannot be exposed to hardness in water greater than 11 grains, and should be de-limed each year. Expect maintenance, service, and potential repairs and parts for tankless to far exceed expected $1-8 monthly savings. All costs are energy.
All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Apr 22, 2011 | Bosch Water Heaters
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater. Problems with constant hot water. The heater turns ok but (i think) when i turn on the cold side the heater stops. at...
Possible flow sensor issue. Check to see if your water pressure fluctuates a lot or is fairly steady. These units are sensitive to the pressure. take care.
Feb 19, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
When you turn on hot water tap the boiler fires up hot water for a few seconds the water becomes cold the boiler flame goes out then fires up again. when the heating on the flames stays on then off then on...
To avoid having a flame in the absence of water flow, the device you mentioned, 'diaphragm,' detects if adequate water is flowing to avoid a dangerous condition. Check on the housing of it for an adjustment screw; it may have a dot of sealant on it since these normally can be adjusted. It sounds as if it is misjudging the quantity of water flowing through and causing the annoying cycling.
Dec 17, 2010 | Water Heaters
Hi i have installed a few bosch gas geysers at our lodge in mozambique.The problem is that the water gets hot when we turn the water on then the heat just shuts off and the water gets cold after a short...
The problem with all that type of water heater is that once the hot tap is turned on sufficient flow must be maintained through the water heater to keep the main gas burner alight. If the heat adjuster is turned up to high, then the person using the hot water will turn it down to a low rate which means the main burner will turn off and result in cold water. Try setting the heat control to the lowest setting that still gives hot enough water. If you have a thermometer adjust control for a temperature of around 50 to 55 degrees Celcius. You may have to fiddle with fine adjustments to get the temperature and flow rates to maintain a constant output of hot water. You may still have intermittent problems. If the heater only supplies baths or showers you could set the temperatuer even lower (45 to 50) to ensure that the hot tap is used more than the cold which will maintain flow and therefore heat.
Nov 22, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch AquaStar 125b ng suddenly goes cold during shower
Does it happen to any other fixture? If not, it's most likely your shower valve and not heater.
Sep 01, 2009 | Bosch AquaStar 2400ES-NG
Water will not stay hot
The cold main water pressure is too low to maintain a constant flow. Make sure you have no other appliences on, or your not comprimised by the lowering of pressure
Jul 23, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
Bosch hot water service 16p burner shuts down
a tankleess water heater doen's have a piliot? but check the vent outside make sure nothing is blocking it, if it detects the exhaust thru the cold air intake it will shut off and over heat, other then that it would have to be the control board
Jun 05, 2009 | Bosch & Tankless LP Hot Water Heater
Takes long time to heat then goes from hot to cold.
I know that this is a great answer but with out being there its hard to answer you call there tech support they are great, I have had to call they from jobs before they can help
Phone Support:
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
Feb 03, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch AquaStar 125FXKIT-NG 125FX Natural Gas Tankless Water Heater w/ Hood Logo
561 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
