Question about Cameras
Touch screen not working on sony hc 52 - Cameras
  • 296 Answers
Try to calibrate ur screen
Posted on Jun 22, 2009
Problems with color on 2005 Samsung 52 inch HDTV
Quite normal in many situations as signal is compressed with most cable and satellite systems, a fact of life.
Nov 29, 2012 | Samsung HC-P5241W 52" Rear Projection...
WHEN i SWITCH ON THE CAMCORDER IT SAYS SET CLOCK, BUT THE SCREEN DOES NOT MOVE ANS STAYS PUT IN THE YEAR. ITS A DCR-HC 40E
-set the year as first shown using or by touching the up or down arrow in the lcd screen then press ok to switch to month.
-do the same thing with the day( always use the up or down arrow located in the lcd screen to change the numbers then touch ok to confirm.
Jun 05, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
When I turn on my handycam sony DCR-HC 35,the touch-screen don't work!? What can I do about it?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Jan 05, 2011 | Sony DCR-HC35E Mini DV Digital Camcorder
Touch screen for Sony DCR HC 32 is not functioning, any suggestions please ?
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's a common problem as this cable is bend each time when we open the LCD screen, so the cable become faulty.Good luck
Sep 29, 2009 | Video Cameras
Sony hc-32 touch screen won't work
When touch switches become nonworking then mostly its cause of connecting flexible ribbon wires between LCD board and camcorder main board that got cracked so touch buttons signal does not go to camcorder system control. Need to replace that flexible wire by qualified camera tech.
Very rare cases I found touch buttons layer that is pasted and part of LCD becomes defective, do you see hard or deep scratch on LCD surface? if yes, then LCD screen will be replaced because touch button array is damaged.
Thanks.
Sep 16, 2009 | Sony DCR-HC32E DV Digital Camcorder
Sony DCR-HC 40E touch screen not working
hi, you must change the lance flap, its a problem of lance flap so just replace it and its a ruttin problem,
Aug 30, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Lcd screen not working on sony dcr hc 42e
the flex wire of the lcd monitor is already cut and already left is on the touch screen that why is functioning ...go the sony service for the replacing flex wire...or to the other service center for fixing the flex wire....
Nov 05, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
LCD flip out screen
I had purchased SONY DCR HC 42 in july 2005. now i am facing a problem with the LCD display. whenever i open LCD screen nothing comes on it. view finder is working fine. kindly help me out Pritu
Jul 22, 2007 | Sony Handycam DCR-HC42E Mini DV Digital...
Cameras Logo
88 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
