Question about Freezers
I needs parts that are discontinued for a chest freezer by Kenmore, model # 198.8131873. Parts needed: door magnet #28, plastic insert inside of door # 29 and plastic clip #7
  • 770 Answers
Contact Harry Belk, at Belks used appliances, your best bet. He will ship the parts to you and likely has what you need. If not he will be knowledgable about where you can find them and if generics exist.
704-864-4496
Posted on Jun 22, 2009
Chest type freezer Model # TCF1510EW00 Needs a gasket around the door. Where can I get one? Is a Whirlpool Estate chest freezer; serial # EWF1793518 with a date of 090604 stamped on the metal tag.
The part number for that gasket is 4346693 it could be purchased at your local appliance parts store or online at;
apdepot.com
searspartsdirect.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 14, 2011 | Whirlpool Freezers
Philco Freezer - replace/repair seal & plastic around top
Good day,
Unlikely you would be able to repair if the inner liner is coming apart.
A local appliance parts house may be able to supply universal gasket to fit to the machine but again, if the inner liner is bad it could prove to be fruitless.
Oddly enough, if you visit supermarkets you will see chest type freezers with no top at all.
Seems like a terrible loss, but it's not.
Cold air falls, hot air rises. When the freezer generates cold air it doesn't spill out the top. It settles into the bottom of the freezer, and stays there. Likewise, warm air rises and has no interest in going into the freezer cavity.
Bottom line. Very little loss.
If appearance doesn't matter, and you can get it close, you should be able to continue to use it.
Your choice, but I thought you would like to know the physics involved here and how it does or doesn't affect you.
Mar 28, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Trying to find parts for a Holiday brand chest freezer
Try on amazon, take a look here: Amazon com chest freezer parts. Wish you best of luck. Cheers
Dan
Feb 26, 2010 | Freezers
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Kenmore 12 Chest Freezer - Needs New Lid
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Nov 27, 2007 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Freezers Logo
110 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
