2003 Renault Kangoo Logo
N
NOREEN ELLIS Posted on May 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW DO YOU CHANGE FRONT INDICATOR BULB THANK YOU
HOW DO YOU CHANGE DRIVERS SIDE INDICATOR BULB ON A RENAULT KANGOO 2001 1.4 RXE PETROL Y REG THANK YOU ?
Darren Harris
Level 2:
New Friend:
  • Expert 77 Answers
  • Posted on Jul 02, 2014
Darren Harris
Expert
Level 2:
New Friend:
Answers
77
Questions
0
Helped
14621
Points
171
If I remember there's an access panel in wheel arch cover you have to turn wheel inward on which side it on
5 Related Answers
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Nov 23, 2008
SOURCE: Renault Megane key will not open doors
work it manually and it should work ...ie put the key in the door and open and lock the door 3 times slowly then jump in and try to start within 15 secs .if it doesnt work then be prepared to be fleeced and lay the golden egg at the dealers
Anonymous
  • Posted on Feb 05, 2009
SOURCE: renault kangoo 1.9 d immobiliser probims.{2001} model.
hold the central locking button down on the centre consul inside the van for more than 5 seconds the doors should lock Then unlock,then press the key fob within ten seconds the doors will lock and unlock again this will re- program the key code
good luck jk
Anonymous
  • 3006 Answers
  • Posted on Nov 01, 2009
SOURCE: renault kangoo indicators and hazard lights have
Most common cause is a failed indicator relay. Just swap it with a known good one to confirm whether it's faulty but ensure it's correctly rated for your Kangoo.
After that, the next most common causes are more expensive: the indicator switch and the hazard light switch.
Anonymous
  • 271 Answers
  • Posted on Dec 07, 2009
SOURCE: renault kangoo 1.4 petrol Auxiliary belt diagram
17d60e8.jpgGo ahead
Anonymous
  • 566 Answers
  • Posted on Jan 13, 2010
SOURCE: can you tell me the cam timing for mk 1 renault
the cambelt timing marks for clio 1.4 are = the crankshaft cog alignes withmark at 6 o/clock position at TDC No 1 cyl and the cam cog alignes with mark on cyl head at rear of cog at 12 o/clock position belt is fitted anti clockwise from crank then w/pump and then cam cog hope this helps ?
2answers
How do you fit a drivers side indicator bulb on a 2001 renault kangoo ?
open the hood locate the rear of the indicator , the bulb holder will turn anticlockwise about a quarter turn then will come out , fit the new bulb , push and twist , reverse for refitting, job done
How do i reset the service light on a 2001 renault megane 1.6 16v rxe privilege automatic hatchback
Good day my Renault M?gane hatchback I replaced battery now my stop light on cluster is on car won't start but imobilizer goes off please help
2answers
Renault Clio 1.2 Petrol T reg I have been having
It sounds as though the ground connection(s) to the rear lamps are suspect - this would seem a sensible place to begin along with ensuring the correct bulbs are fitted and the bulbholders and any internal lamp connections are in good order.
It is also worth checking the wires that pass from the body to the tailgate for internal breaks. It will be necessary to pull back the rubber boot.
If all is found good the trip to the auto electrician is likely...
Fuel gauge goes up when ignition is turned on, and then drops
CHECK ALL FUSE AND RELAY, MAKE SURE YOUR GETTING 12V AT THE BATTERY, ALSO CHECK THE ALTERNATOR, IT MAY NOT BE CHARGING PROPERLY.
Renault kangoo Trekka 1.9dci Rear fog light not working.
hiya put your headlights on and ignition then rear foglight/s they should now operate rear and front fogs usually only operate with head dipped lights on ? this is designed
Kangoo rxe 1.4 auto. the fan for the cooling system is not operating at all and causes overheat when stationary. any ideas on where to start checking why ? thank you
called the rac and the man spent ages checking it over . eventually finding a broken earth wire which he said was a factory fitted problem from new ! weird eh!
Top Renault Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Renault Expert? Answer questions, earn points and help others
