Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint drum removal
Anyone know how to get the drum out of this machine please as I have to replace the bearings which seems straight forward but cannot see how to remove the front to do so
  • Martin smith May 19, 2014
    Job now done just needed a few pointers but worked it out for myself hardest part was getting the pins out of drum struts boy they were tight rest was straight forward
    President:
  • 1,462 Answers
The whole of the tub and drum assembly has to be removed and split down. If you have never done this before, I don't fancy your chances of success. Sorry to be negative
Posted on May 19, 2014
SOURCE:
  • 139 Answers
SOURCE: changing bearing on hotpoint FEW12??
welll its a long job.
first remove the top
then the front control panel.
disconnect any wires connected to the circuit board.
then remove the front panel with the door intact. to do this you must unscrew the the screws in the top and bottom and remove the screws for the door inter lock as well as undue the door gasket from the panel.
Then you got to remove the concrete weights. and pull the pegs in the legs from the drum side.
Then you got to dissconect the drainage at the bottom of the drum from the pump
remove the wires from the solenoid and disconnect the pressure switch from the small plastic tube.
undue the tubing from the soap draw to the drum
remove the clips near the springs.
undue the front metal panel which the board was connected to and remove the drum
if you need anymore help dont be afraid to ask.
Posted on Dec 16, 2007
hards327
  • 30 Answers
SOURCE: Hotpoint WF740 Aquarius Plus Drum Seized.
hi the code will flash that because of the drum being seized in my opinion the bearings have seized to replace them you will need to remove the front of the machine disconnect all the wires from the drum not the machine there are two plastic pegs holding the suspension legs to the drum which you will need to remove. push the pins in at the backof the pegs and pull out the pegs,sorry you will need too remove the two concrete blocks top/bottom first, then remove the pegs lift out the drum remove the fixings around the drum with a t-30/t-40 bit,then split the drum now comes the tricky bit - AT THE BACK OF THE DRUM IS A 13MM BOLT UNDO THIS ONE TAKE OFF THE FLY WHEEL AND THEN REPLACE THE BOLT HIT THIS BOLT AS HARD AND AS CLEANLY AS YOU CAN WITH A LARGE HAMMER SO THE STAINLESS STEEL DRUM COMES OUT THEN YOU NEED TO GET THE OLD BEARINGS OUT THESE CAN BE A PIG SOMETIMES SO DONT GIVE UP THEN REPLACE WITH NEW ONE'S PUT BACK TOGETHER IN REVERSE ORDER.hope this helps if you can think you can do it it's not as bad as it looks ,good luck
Posted on May 15, 2008
  • 1028 Answers
SOURCE: Hotpoint bearing replacement
remove rear pulley and pull like crazy ..usually have to change rear shell bearing and seal are pressed in be sure to ck spindle on basket for scoring before reassembly if scored replace basket
Posted on Sep 27, 2008
  • 566 Answers
SOURCE: how do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Posted on Feb 26, 2009
barkencoa
  • 3463 Answers
SOURCE: How to I remove the drum from a Hotpoint WM64
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Posted on Sep 04, 2009
Testimonial: "Your solution answered my question, but left me with another. How to remove the bearings from the drum. "
Model no.zwf1432 w
If you don't have it, try this on line http://laundry.manualsonline.com/manuals/mfg/zanussi/zwf_1432_w.html?p=1
Apr 13, 2015 | Zanussi Washing Machines
Hotpoint wmf560 aquarius washing machine
BIG JOB !!! The whole machine has to be stripped down. Ie/ The complete bowl assy has to be removed from the machine, the outer bowl separated from the inner bowl, the main seal removed, and the bearings pressed or knocked out of the housing in the rear of the outer tub. If the bearings have failed , it would be almost certain that the drum shaft has worn and or been damaged. You will need a set of bearings, drum spider shaft assy, and main seal. If its an older machine, it may not be worth it.
Apr 13, 2015 | Washing Machines
Repair of drum bearing
Drum bearings can be a little tricky, depending on the your of machine. One thing I can tell you is you have to dismantle any machine to get to them.
Nov 07, 2014 | Washing Machines
Samsung front loader washing machine
Sounds very much like the drum bearings have failed. It is not a DIY job I'm afraid. Up to date washing machines are now impossible to actually replace bearings and only way to repair is to replace inner and outer drum assembly. This is a 1/2 a day job at the least to a professional. Older machines.....you can replace the bearings but this still involves removing the outer drum ou from under the washing machine, and the a very normal bearing removal and replacement procedure. Make sure the bearings are knocked in very straight and not on the skew. Good luck
Nov 24, 2013 | Washing Machines
Agitator off center
Possible that the drum agitator bearings are off track or worn out. Please check these links for support.
Check this link :http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlForreplacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 29, 2012 | Maytag Washing Machines
HOW I CAN REPLACE THE BEARING BALL IN A LG WM2277H WASHING MACHINE
http://136.166.4.200/contents/Laundry/WM1832/WM1832xx_Service_Manual.pdf seems to have the manual for a like machine. It does look pretty straight forward removal of the motor, but doesn't go any farther than that. So hopefully common sense in removing any retaining clips and slipping the bearings out withough removing the whole tub/basket assembly.
Sep 02, 2010 | LG WM2277 XL Front Load Stackable Washing...
How to replace bearings in hotpoint washing machine. Has anuone got a plan view of what I need to do.
Hello,It's fairly straight forward,not easy though.The facial comes off(take the dispenser out and remove the four screws), front of the machine comes off (3 screws at the bottom and 3 behind the facial,the outer tub front comes off.)The pulley on the rear comes off,the inner drum can be knocked through.This gives you access to the bearings and bearing seal,not the easiest to get out.A lot of the time the outer race is left behind from the front bearing and it's a nightmare to get out.Hotpoint use a special bearing tool,get yourself a spider and bearing kit as well as a new tub seal.
Thanks
May 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Loud noise as drum turns,gets louder as speed increases.
There is no doubt that the drum bearings have failed from your description.
The normal procedure is to replace the whole drum and tub assy as a complete unit, this makes it a fairly straight forward repair, though relatively expensive.
To strip it down and replace worn bearings, is a very involved repair, and not one I would recommenend.
If the washer is less than 5 years old, then you can get it done under the Hotpoint 5 year part guarantee, but you would have to contact Hotpoint about this.
Plz rate my solution.
Thankyou.
Jan 25, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wma37
Hello
Well to change the drum bearing on your machine is pretty straight forward if you have some sort of mechanical grasp but pretty much impossible if you dont..
the procedure is
first take of the top lid two screws either side and it comes off by lifting thefront end of the top and a slight push back and off ...
Then take out the soap draw and undue the 3 screws there.. remove the control panel by unclipping all the wires..
Then the front panel with door you have to remove the 3 screws at the top and 3 at the bottom undue the screws by the door lock and remove the ring around the door gasket and detach the gasket from the front panel.. then simply lift the panel upwards and it will come off..
the remove the rear panel..
Then undue the weights as it will make the job eaiser..
Then remove detach the rubber pipe leading int o the drum from the bottom of the soap draw..
then detach the wire from the solinoids at the back and unlip the little tube that is attache to the pressure switch don not remove the wires from the pressure swtich..
then at the rear of the machine behind a balck cover are the heater wires remove the cover and the wires. you will see at teh bottom of the machine that he wire are held to the drum via tie-clips remove cut all the clips as you will have to replace them after wards..
then remove the wires from the motor ..
then remove the pegs that hold the legs in place which connect to the drum..
then you know the metal panel which the control panel was connected to undue that now. and throw it ove complet with the wiring loom and pressure switch to the right hand side of the machine,,
now unclip the little white things on the top at the sides where thesprings sit and take out the drum...
detach the motor from the drum and remove the springs
The drum has 16 screws around it undue all theses they are star T-10 i think. undue all of them and split the drum open ...
undue the fly wheel and remove the inner drum ...
get your hammer out and knock out the bearing you might need some kind of small bolster or punch.. to remove these and if your bearings are damaged badly then your your probably end up with the outer cone stuck to the bearing shaft,,, be paitient clean it wd40 it and eventually is should come out.. now if you need anymore help then let me know
cheers vaccs../..
Jan 04, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
93 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
