Question about Panasonic Televison & Video
Panasonic DMR-E500 Cannot access the following 'Functions' 'Direct Navigator' 'Prog/Check' Recently it has taken longer & longer to go into any of these modes and now nothing. I get a message that looks like 'NAVIL' or maybe 'WAIT' not able to read properly. The recorder is connected to a Panasonic TV TH42PZ81B Other than the recent slow connection I have had no previous problem.
  • Gills Belle Jun 22, 2009
    Hi
    Thanks, that seems very clear, I feel I could do it myself, but I am in the UK and I have posted on the net a search for 'Capacitors' but none of them seem to look anything like the ones you show, any ideas for a new search?
    Thxs Gill
    I haven't tried it yet but it sounds good.
    President:
  • 1,952 Answers
It will be an internal portal problem
Posted on Jun 22, 2009
  • 10,515 Answers
This is due to DAMAGED CAPACITORS ( Blown Capacitors ).You need to solder the 2 capacitors. Once done, it would fix the issue.
The 2 capacitors more likely would be C1270 AND C1271.Two capacitors from radio shack and a $6 soldering kit made it better than new. Two capacitors from radio shack and a $6 soldering kit made it better than new.
If you send it for repair, the tech would cost you around 75 bucks.
Note :- check capacitors in power supply section.
The exploded view and the procedure would be :-
Start by removing the top cover of the unit.
Working from the back of the unit you'll see the hard drive on the left.
Panasonic DMR-E500
Remove the two screws indicated by the red circles in the picture above. Then slide the cover plate forward and remove.
Two cables are connected to the hard drive. Left side is power and the black ribbon is the data connector. Both come off pretty easily. After removing cables lift oPanasonic DMR-E500 Cannot access the following - 6befd35.jpgve. Here's what you get.
  • taran_2005
    taran_2005 Jun 22, 2009
    Remove the four screws indicated by the red circles in the picture
    above. Note the one at the top. (I missed this one for a few moments
    while putting it back together.) Remove drive mount.
    Viola! You now see the burned out capacitors. Also circled are the four
    screw holes you just removed screws from and a cable that must be
    disconnected. (see next pic)
    Gently pry up on the black plastic part of the cable mounted on the
    power board. You can see in this picture how I've just started to get
    it off a bit. You may have to pull on the latch in the center of the
    mounting. I did but I don't know if it was necessary.
    On the back of the unit remove one screw just above the power plug.
    Then rock and twist and hold your tongue just right to get the power
    supply board out.
    You'll see the capacitor numbers labeled on the circuit board on the front and...
    on the back. Use a soldering gun to melt the solder on these four spots
    rocking the capacitors out of the holes as you do so. Just don't get
    solder over to any adjacent circuits.
    You end up with nicely marked pos/neg info on the board.
    Get your new capacitors from Radio Shack or other electronics store.
    The ones suggested by DC are more heavy duty so they are bigger. I
    chose to lay them on their side so as to not raise the height of the
    board components. There is plenty of room to do so making my decision
    to do so a no brainer.
    I leave the leads on the capacitors long until the capacitors are positioned and soldered in good shape.
    Then clip the extra lead down to the solder with a wire cutter.
    Thats it. reverse the directions to re-assemble the unit.
    Hope the pictures helped. They always seem to help me prepare for such an adventure.
    Thanks for using 'Fixya".
How do you remove a recorded program from my panasonic DMR-BWT760 recorder
On handpiece, select Direct Navigator, scroll to title to delete, select Option button on handpiece, scroll to Delete Title and press.
Dec 23, 2017 | Panasonic Televison & Video
I have a Panasonic DMR-EH 50 DVD Recorder, I changed the code on the Remote from code 1 to code 3, now the Remote will not work. How do I reset the Remote so it works again.
here you go. Page 62 for Full Reset, and also Page 57 of the instructions. Copy and Paste from the PDF doesn't work, so you will have to visit yourself :>)
To return the channel settings
and clock to the factory preset
(No setting)
Press and hold on the
Manual
ftp://ftp.panasonic.com/dvdrecorder/om/dmr-eh50_en_om.pdf
Apr 24, 2017 | Panasonic Televison & Video
When i press direct navigator on my remote to get to the options it displays "NAVI". What does this mean?
NAVI on the front panel display simply means on-screen menu navigation - ideal for unfinalised DVDs so you can check the recorded contents - such as the football or a music program. It is generally a normal user function whenever a readable (DVD-RAM/DVD-R/DVD-RW) disc is inserted. Pressing [OPTION] button brings a popup menu offering you options such as PLAYBACK DELETE etc. for the appropriate discs. Once you press [DIRECT NAVIGATOR] or [RETURN] on remote, NAVI should disappear from the front display.
This image is an example for a Panasonic DMR-EZ47V VCR/DVD combo (which I own), but the basic principle is the same. It should not cause you any real concern, unless it doesn't allow you to access the contents of a DVD you recorded in it. I hope this helps somewhat.
Apr 16, 2011 | Panasonic DMR-ES10 DVD Recorder
While trying to save parts of a TV-programma I recorded on mij Panasonic DMR EH50 DVD-recorder I try to delete the parts that are'nt useful to me. The recorder gives the following message: Can not 'work'...
Highlight the recorded program on Direct Navigator then press the Sub Menu button on the remote, then select "Shorten Title". Press (Enter) at the start point and end point of the section you want to erase, then use the up/down button to select "Next". Then, select "Erase" to delete the unwanted sections. Repeat this process for all unwanted parts, then select "Exit" to return to Direct Navigator.
Nov 01, 2010 | Panasonic DMR-EH50 DVD Recorder
LOST MANUAL
Go to direct Navigator on remote or functions it will lead you into step by step directions for recording and programming the dvr remember you must hook up a digital tv tuner because the dvr is analog and will not record tv.
May 30, 2010 | Panasonic DMR-E85H DVD Recorder
We have a Panasonic DMR-EH50 DVD player/recorder. We recently moved house and following the move, the FUNCTIONS button on the remote no longer works. Everything else on the remote does. I've tried...
The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Apr 04, 2010 | Panasonic DMR-EH50 DVD Recorder
My panasonic dvd model DMR-55 won't turn on and the digital clock is not even working when I plug it in. How do I get the dvd in the machine out?
My Panasonic is stuck on self check when a new DVD is inserted?
It turns on and other functions are in-accessible during this self check
Any help greatfully appreciated.
Feb 15, 2010 | Panasonic DMR-E55 DVD Recorder
Everything has been working perfectly for 3 years or so/ done nothing different,use almost exclusively the HDD on my DMR-EH60, then suddenly the TV no longer responds to my commands. Unit goes off and on...
The DMR-EH60 has been working fine for a good five years then it started intermittedly loosing sound when using it as tuner for our display panel. Now there is not sound at all even recordings from TV onto the HDD. Any ideas?
Jul 19, 2009 | Panasonic DMR-EH60 DVD Recorder/HDD...
An unknown error??
EXT -L if I remember is extrnal line input let me check the manual and I will get back to you
Nov 07, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
FINALIZING ISSUE
Press FUNCTIONS button;  Select DISK INFORMATION; Select FINALIZE; YES; START; ENTER.
Jul 18, 2008 | Panasonic DMR-E50 DVD Recorder
Televison & Video Logo
148 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
