Question about LG LRM1260SW Microwave Oven
I accidentally covered a plate with foil in the microwave. there was Arcing (no fire) and now there is black marks etched where the foil touched the sides. The cavity seems unharmed though, it seems if I scrubbed hard enough they would actually come off. Can I still use it if I cant scrub the black marks off?
    President:
  • 1,185 Answers
Depends on how long the material was in contact with the walls.
It really is a **** it and see situation
Put a bowl of water in and run it for 3 minutes on full power.
If it does not arc then you have got away with it
I would be very cautious about using an abrasive to remove the marks
What you have got is little bits of metal from the tinfoil welded to the sides of your oven
If the oven is stainless steel then you might be able to pick them off with a paint scraper.
Check your user guide to see what the maker recommends that you use for cleaning the interior.
If you want to diminish the marks try using a drop of the ceramic hob cleaner or stainless steel cream cleaner
Posted on Jun 22, 2009
  • 770 Answers
Sometimes the arcing itself will cause black marks inside the oven. The places where the foil was melted, (touching), likely left small metal deposits, possibly now, impregnated in the surface. It is important to remove these if possible to avoid further arcing. Remove these then test to make sure the oven is functioning properly. If so, continue to use.
Why does my microwave arch at the wave guard
Typically most arcing in a microwave is caused by food splatter. A microwave cannot tell the difference between what is on a plate or on the wall or ceiling. Every food particle in a microwave will continue to cook until it turns to carbon and will attract the microwave energy and focus it to that spot and the unit will arc. Thorough cleaning of the entire microwave cooking cavity and removal of any burn or soot mark will commonly stop the arcing. If your microwave has a painted cavity, you can even use some very fine sand paper to remove any burn mark. Always cover what you are warming and really keep the inside of the microwave clean. If your wave guide cover is made out of the Mica board, and If it has gotten wet from cleaning or from splatter, it must be replaced. You can either order a new one or order a sheet of the mica board and cut out a new one yourself. If the microwave is arcing in the waveguide, generally the unit will need to be replaced. One quick test to see if the unit will work is to remove the bad cover and place a small container of water in the unit, run the machine of a minute or so and see if it still arcs. If it does, the arcing is in the waveguide area, if not it may have just been a problem with the cover. You can run the unit without the waveguide cover in place, it is only there to prevent splatter from getting into the waveguide, so removing it to test the unit is ok. If the area inside the wave guide shows signs of soot and arcing. You can try to wipe that out with some alcohol or lacquer thinner and then try it again. Good Luck.
May 15, 2014 | Magic Chef 1.6 Cu Ft Countertop Microwave...
My GE microwave is starting to arc, You can see the arcs on the plate (I believe it is the wave guide cover) on the right side interior. Burn marks are evident on teh plate. Is it the waveguide cover or...
Some units use a plastic or fiberglass cover over the wave guide where the microwaves are dumped into the oven cavity. If this cover gets coated with food/grease, or soaks up grease, it can arc, or catch fire. If unit is still operating properly otherwise, I would suggest replacing the cover. You need to inspect the wave guide, also, to make sure it is still intact, and there are no cracks in it that would allow microwave radiation to escape.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 17, 2014 | Maytag MMC5000 Microwave Oven
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
I have a new JVM1750 just installed yesterday. There was some arcing, in what looked like underneath, a white circular disc in the ceiling of the internal cavity. Have checked for foil - none inside the...
That is your stirrer cover.
Any arcing there is usually due to grease or food particles, so on a new oven that would be as mystery.
But any time you get arcing under it, it has to be removed and cleaned.
Oct 12, 2011 | GE Spacemaker JVM1750 Microwave Oven
I covered the plate with 'heavy duty aluminum foil' thinking it was safe for for microwave use, then I saw a sparkle inside while turning. I stopped it, took off the aluminum cover, turned the microwave...
The food is safe as long as the food has not got oxidized aluminium on it.
Microwave energy is very high and will melt metals!
As long as it is not arcing any more there should be no problem.
Jan 03, 2011 | LG Microwave Ovens
Fire inside oven during operation on right side metal plate
Arcing is caused by the build up of grease that is converted to carbon. Clean the baked on carbon from the oven cavity. If regular cleaning doesn't remove the carbon, sand it away and touch up with a similiar color paint.
Jun 21, 2010 | Thermador MBBS Microwave Oven
A bag containing sandwiches that were wrapped in foil was put in the microwave for ten seconds to warm them. Of course no one realized that the foil was in the bag. The bag caught fire and the microwave...
The arcing that caused the fire also caused the microwave generator be over loaded and sent stray voltage into the chassis. Microwaves MUST have the proper coating in the oven or aching will occur all the time. IF the coating is damaged and it can be damaged in areas that you cannot see, you will be money and heartache ahead if you replace the whole thing now.
Feb 23, 2018 | Maytag MMV5165 Stainless Steel 1000 Watts...
Arcing... can I still use the oven?
The microwave energy is not ionizing radiation, so the real risk is further arcing and possible fire.
The cavity will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Jun 04, 2009 | GE Profile Spacemaker Over-the-Range...
Clicking When Unit Starts
Q - When there is small amounts of food in the oven, arcing occurs right behind the plate where the wave guide comes into the oven. Sometimes it works well and sometimes you can't even put in a bag of popcorn. Any ideas? Could food have 'dripped' in here and be causing a microwave short?
A - Yes! Food splatter or drips can continue to cook and will carbon over creating sparks/arcs from the wave guide cover. Usually can clean up the food on and under the wave guide cover, if the oven liner has been damaged we usually lightly sand and touch up those marks with touch paint. Do not let it go for too long as damage to the magnetron end is possible as well :(   If the wave guide cover has been damaged, replace it!
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
LG LRM1260SW Microwave Oven Logo
183 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
