Question about IBM ThinkPad T20 2647 Notebook
My laptop wont switch on with or without the mains lead attached, it worked right up until 21/6/09 but the following morning there was nothing at all.holding down the power button for any period of time doesn't work,in fact it turns the power light off and the same when the power lead is attached but the green charging light is on when the lead is attached.Please help cos my little boy would be very happy if we could sort this problem out soon many thanks.
    Problem Solver:
  • 5 Answers
Just chande the battrey it will work
Posted on Jun 22, 2009
'95 VS800 I just got from someone that said he came out one morning, turned the key and nothing...no lights, no cranking, nothing. He them let it sit for the next year and I took it off his hands. New...
Have you checked the 30amp fuse located at the starter solenoide, follow the poss lead from the battery untill you come to the solenoide, here you will find a fuse under a plastic cover, if you have done this allready, its quite simple using a test lite at the ignition switch loom end do you have 12volts dc at the main feed from the battery? If yes check the output from the ignition switch when in the on position, secondly does this machine have an alarm imobiliser fitted?
Apr 26, 2011 | 1995 Suzuki VS 800 Intruder
Fuse intact in supply lead but Neff H5470NO appears 'dead' - nothing working and no indicator lights is there another fuse ?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 16, 2011 | Neff H5470 Microwave Oven
Worked yesterday, but this morning is totally dead - power at the outlet is fine. Is there a master fuse somewhere? Aprox 4 years old. Thanks,Pat.
Hope this helps.
Jan 18, 2011 | Emerson MW8626W Microwave Oven
How to access and find fuse in magic chef (installed under cabinet) microwave. No power to microwave (nothing working including light)
Hope this helps.
Jan 02, 2011 | Microwave Ovens
My xbox wont load up without a hard drive attached. It gives me a system error code about not having the hard drive attached and wont read that I have a memory card plugged in.
Thats right the hard drive contains the Brain program without that NOTHING will work, as it doesn't have it's instructions on the hard drive?? With NO hard drive NOTHING will ever work?
Mar 01, 2010 | Microsoft Xbox 360 Console
My henry just wont work? fuse changed and still not any life? what else could it be ? Thankyou /
could be one the following
faulty mains lead,
mains lead contacts on the cleaner,
on/off switch,
capictor,
wire off motor
Nov 05, 2009 | Vacuums
Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Apr 20, 2009 | Dell Precision M60 Notebook
My screen is blank and nothing is working
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the
Apple logo appears.
Mar 15, 2009 | Apple iPod nano
Not loading up to main screen
ok go to youtube and type" PS3 REPAIR/FIX" basicly what you do is put the ps3 on standby (the red light on) and then turn the main power off (the back switch) then hold the I/O button in the front (the on switch you use to put on standby) just hold it until it will go to standby then hold the I/O button again (the standby button) and then keep holding it until you hear one beep, then wait for two quick beeps. Then there should be a menu and select "Restore Defualt Settings". If it dosent work CONTACT SONY!
Mar 08, 2009 | Sony Playstation 3 (PS3) Console
IBM ThinkPad T20 2647 Notebook Logo
151 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
