Question about Philips DVDR3380/05 DVD Recorder
Not playing back on another machine
This player will record and playback just fine. However when I place the disk into another machine it sees the recorded disk as blank. Any ideas................
  • 476 Answers
Re: Not playing back on another machine
First of all, make sure you finalize the disc before playing on another machine.
If this is not the cause then the following should help:
There was a compatibility issue with this model. Philips released a software update for this model.
Follow this link:
Read and follow the instructions CAREFULLY.
Posted on Feb 16, 2008
0 characters
3 Points
I have recorded on a Verbatim DVD+RW disc on my Philips 3305 DVDR but it will not play back on my friend's Panasonic DMR-EX98VEB. My recorder will not finalise/make compatible the disc. Why?
Could be that the disk itself is incompatible with your friend's machine. Or your buddies machine may be starting to exhibit playback issues. Try another disk and see what happens.
Feb 07, 2016 | Panasonic DVD & Blu-Ray Players
Playback on recorded disk
The DVD has burned incorrectly and the data has likely corrupted somewhat to the point where the DVD player/writer can't read it. You may be able to watch it on your computer with a DVD drive. Try saving it to your computer, then erasing the disc and trying to record something short to it and play it back - if it plays back, it's likely to have been a recording problem, however, if you get the same problem, it may be a dodgy disc, a faulty DVD player/writer, or a format problem. Try this, in order left to right. Copy DVD to PC -> Erase DVD -> Record on DVD from TV -> Play back If plays back Erase DVD -> Continue as normal If not Buy DVD-RW (emphasis on the minus) -> Try using that If that works continue as normal, otherwise... Return the DVD player/writer under warranty for repair/replacement.
Sep 17, 2007 | iLO DVDR04
I have had my sony rdr-gx257 dvd recorder for about a year now, never been used. I have been recording gameplay from my ps3 with it since yesterday. I have recorded onto dvd-r disk and dvd+r disk however...
After ending recording, Finalize recorded dvd as option is available in recorder menu.
a Finalized dvd will playback in other dvd players.
Dec 30, 2010 | Sony RDR-GX257 Player
Can't play recorded DVD's(from philips 3505) on other dvd players
Hi I am Vortash It very much sounds like you are not finalizing your disks .. any dvd recorder that makes a disc from computer dvd's to free standing unit s work on the same software principle , however the programs do differ slightly and finalisation stanard izes the disc to run on any player, without it another recorder will either not recognize the disk or the language it is written in . Read that message at the end and you will see the option to finalize or it will say do you wish to be able to play this on another dvd or it will do it automatically if you set it to do so in the menu on some sets .
if your player isnt doing this it is not set to do so in the menu settings disks can be finalized at any time after recording providing they are not over filled as the finalization process will take up at least 10-12 mb some do it in more some might do it in less depending on the software hope this helps Regards vortash
May 17, 2009 | Philips DVDR3505/37 DVD Recorder
Playback problem
Check your dvd player specs. It may not read dvd-r disks. Hope this helps.
Jan 13, 2009 | Philips DVDR75 DVD Recorder
Records fine want play on any other dvd player
it's the format it was recorded in,your other dvd's can't read it.see if you can go into your recording menu and see what format it's recording should be ntsc.also is your other dvd players older models?
Dec 06, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Cyberhome DVR 1600 DVD
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
Philips DVDR615/69
Take, if good  batteris from the remote controller and recycel the unit, and by a better one. I have the  same problem, recordings will stay on the dvd only a short thime readable and later the disk is empty.
Sorry my english.
Sep 26, 2008 | Philips DVDR615 DVD Player
Cannot play dvd-r copies on other dvd players
Did you finalize the disk after recording? see manual for directions.
Jul 06, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Make edits Compatible not available with +RW media
They still need to be finalised before they will work on another machine.
Dec 28, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Philips DVDR3380/05 DVD Recorder Logo
100 people viewed this question
Top Philips DVD & Blu-Ray Players Experts
Level 1 Expert
rugby prop
Are you a Philips DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
