Question about Sony PlayStation® 3 (60 GB) Console
Playstation 3 has no surround sound on some games I play.
Got a playstation 3 set up for HD gaming Perfectly fine, with HDMI to HDTV and digital optical to Dolby digital Surround Sound. All works on playstation, have surround sound on everything and a couple of Ps3 games. My Problem is that certain games like Killzone 2, Red Faction Guerrilla and Starwars TFU have no Surround sound once game is started. Can you help solve my problem? I am not the only person that has this problem with killzone 2.
  • 4 more comments
  • cmridley Jun 22, 2009
    Panasonic SC-PT460 DVD Home Theatre Sound System, is that what you mean?
    Surround sound only works up to the point killzone 2 or starwars TFU starts loading. Whereas on Red Faction it works up to the point I load my saved game.
    Limited controls on my sound system, can't change to DTS or 2 channel, might be automatic unless it has a different name in which it doesn't work tried every button. tried bitstream on ps3 didn't work. PCM mix didn't either. What is DRC? Only have off/movie/music modes on dolby Digital button. It supports everything on the box.
    Is it possible that the games just don't support my sound system once they load past a certain stage?
    Thanks for manual. Read it, found the menu and all the settings on sound system, tried all outcomes but no difference. It works fine on the playstation just not on certain games. Got to be a problem with the games themselves because certain games work like LittleBigPlanet and resident Evil 5.
    Surely I wouldn't get any surround sound whatsoever on Playstation main menu if it was the settings?
    Updated system and played with Ps3 settings, still no good. Got to be a software problem with the games.
    Panasonic SC-PT460 DVD Home Theatre Sound System. Surround sound only works up to the point killzone 2 or starwars TFU starts loading. Whereas on Red Faction it works up to the point I load my saved game.
    Limited controls on my sound system, can't change DTS or 2 channel, might be automatic,tried every button. Tried bitstream and pcm on both ps3 and Sound system didn't work.It supports everything on the box.
    Read manual found the menu and all the settings on sound system, tried all outcomes but no difference. It works fine on the playstation just not on certain games. Got to be a problem with the games themselves because certain games work like LittleBigPlanet and resident Evil 5.
  • cmridley Jun 23, 2009
    Read all of the links, played around witgh settings again but no change. It works fine on littlebigplanet and resident evil 5, no idea why it doesn't on killzone 2, red faction guerrilla or force unleashed. makes no sense, tried all suggestions. Out of ideas myself.
  • 10,515 Answers
Point to be noted :- All ps3 games support surround sound.
Let me make sure you already have the right settings :-
From the PS3 main menu:
1. Settings->Sound Settings->Audio Output Settings
2. Change it from HDMI to Digital Out (Optical). I do NOT have optical hooked up on my PS3, so if you have it hooked up, you may want to unhook it.. probably shouldn't matter.
3. I left what was defaulted: "Linear PCM 2 Ch. 44.1 kHz" and 48kHz
4. Right on the D pad (X selects/unselects options) to move to the next screen.
5. A confirmation page, hit X to Enter, saving the changes.
6. Start up a game, you shouldn't hear any sound (as expected)
7. Exit the game, then go back to Audio Output Settings and switch back to HDMI. I selected "Automatic" for "method for setting the output format."
8. A confirmation page, hit X to Enter, saving the changes.
9. Start up a game, you should now hear audio with your game (once again).
REGARDING FEW GAMES, YES THERE IS AN ISSUE. This is due to Compatibilty factor.
Do you have your PS3 set to output audio in Bitstream, or Linear PCM?
I believe you must have "PCM". Go for "BITSTREAM", you would be able to listen to the sound on the above mentioned games.
The difference is like this.... Linear PCM, the PS3 will do the decoding, and send the audio already processed to the receiver. Then the receiver will just take that, and send it out to the speakers. Bitstream will send the audio UNTOUCHED to the receiver, allowing the receiver to do the decoding. Theoretically, there shouldn't be any sound quality difference between the two. However, the reason that one or the other should be used has a lot to do with the problem you are experiencing. Some receivers don't do well with a Linear PCM signal sent to them, some do.
The only difference is whether you have the PS3 do the decoding (PCM) or receiver (bitstream). There is no extra compression with bitstream, trust me. And no, optical will do 5.1 just fine. HDMI will do up to 7.1, so you are right on that mark. Like I said, it may just be a problem with your receiver not wanting to accept a PCM signal for some reason.
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 23, 2009
  • 495 Answers
Forum.blu-ray.com/showthread.php?t=40872
The above link will surely help you. Best of luck.. Do rate me..
Posted on Jun 22, 2009
  • Sony Master
  • 13,433 Answers
What is the brand and model of the receiver? your sound system?
  • 3 more comments
  • Ekse Jun 22, 2009
    Basically, if you swap to 2 channel mode the sound will work? if you go back to surround sound it stops working?
    basically a problem with the format the audio is coming in as.
    I looked over the receiver and it should work with the game. On(quick setup) audio menu of the receiver, turn it on DTS, try bitstream if that doesn't work try the pcm.
    also try the other settings, dolby digital (thats what its probably set to now) and mpeg.
    It should work with your equipment.
  • Ekse Jun 22, 2009
    user manual available here:
    http://safemanuals.com/user-guide-instru...
    You will need a pdf reader to open the file, if you don't have one or you can't open the document get one from here: http://get.adobe.com/reader/
  • Ekse Jun 22, 2009
    your sound system has all the features the console and the game would need.
    Seems like a settings problem, have a look into the user manual type in the search DTS untill you find the audio menu I was talking about.
  • Ekse Jun 22, 2009
    try updating the console to the latest available software:
    http://www.us.playstation.com/Support/Sy...
    also check the sound format / settings on your ps3 and try out the different possible settings.
  • Ekse Jun 22, 2009
    Then I'm out of ideas.
I am having issues with my RCA Scenium D52W135D (playstation 3 connection). Recently, I have been having a very specific problem with this combo. I have it connected using HDMI to a Pioneer receiver...
Had the same problem. With mine the other day you probably moved your Playstation 3 too another tv and set your 1080i,720,480 to high deaf on settings in Playstation. You have to change them back to automatic that TV says HDTV but it only plays Playstation 3 on 480 checked in settings of Playstation. Played mine for 4 years on that TV moved and got a 3d wifi then dad got him one And was going to trash that RCA but I told him I would take it for now too keep from buying another TV at this time got it in my new home wouldn't play video but it. would sound tried different cables but still now change. But remembered i changed all of my settings over when I got 3D TV. Playstation 3 hadn't been on know other TV. Since I owned it but that RCA now won't work then came to me last night and playing it on both TVs but you have to change the settings on it before moving it or you cant see the screen to fix it do that guarantee it will fix it. Like you said everything else works PS 1,PS 2,DVD, cable,but PS 3 won't its the settings in theme,and audio.
Nov 10, 2012 | RCA D52W135D 52 in. TV/DVD Combo
I connected a sony playstation 3 and there is no sound while playing games. The video works and I can play the game, but there is no sound. I returned the playstation 3 thinking it was the console but the...
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
Adjust the audio output on your playstation and the television depending upon how you're connecting it to the television for picture and sound.
For an hdmi cable between the television and the PS3 only then adjust the audio ouput to hdmi on the PS3.
You do not need to connect anything else between the television and the PS3 besides an hdmi cable.
If you are using the colored plug type component or composite cables then it is av.
If you are connecting with a fiber optic cable to a surround sound system then it is set to optical.
Depending on what television you are using you would also have to change the Playstation to 48khz/96khz
Jan 09, 2011 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Hdmi input for playstation 3: when i connect my playstation 3 to the hdmi on tv the menu section of the game does not show correctly. i have to guesss the controls to select to play the game then the game...
Try using a different HDMI port on the TV. It may be you are plugging it into a the DVI-HDMI port, which does not display FULL HD, or carry sound.
Hope this helps
TV_Doctors
Jan 03, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Surround sound on ps3
Most digital inputs are assignable, so go to set-up menu on your receiver and make sure the optical port (opt1 , opt2, etc.) is assigned to the input (vcr, aux, etc.) that you want switch to to listen to the PS3. You may also need to go into the PS3 settings menu and turn the optical to output the Dolby Digital signal. You have to do this with most DVD players, too.
Jun 13, 2010 | Sony Playstation 3 (PS3) Console
No sound from hdmi cable
Go to the Sound settings in PS3 and be sure it's listed as HDMI and not Audio Video Cables.
Output on TV may be set to surround sound system? Powerd On?
May 25, 2009 | Sony Playstation 3 (PS3) Console
No surround sound, when playing blue ray films using ps3
Im guessing you are using a HDMI cable,
HDMI cables struggle to carry audio...
you will need a componet cable, this is basicly the same quality, and all you do is plug the audio cable part into the surround sound system and done.
Hope this helps
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Games on Full HD
if you have a full hdtv then providing you set the playstation up in the settings menu to 1080p and use a hdmi cable then everything you play will be in hd (except ps1 and 2 games) but you can select to upscale these. all blu rays and ps3 games will be in full hd.
Dec 18, 2008 | Sony Playstation 3 (PS3) Console
PS3 Surround SOund
go to the audio settings, i'm not sure what it was it was called like linear pcm or something like that...it worked for em
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
Ps3 using digital optical and hdmi cables together
There is a conflict in the fact that HDMI gives you the digital surround sound without the need for the optical lead and when you allocate the optical for the sound thats when the conflict starts, you can only use one or the other.
Jul 31, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
