Question about IBM System x3650 Xeon E5355 QC 2.66GHz/8MBL2/2GB/Open Bay 2.5" SAS/SATA HS/Combo/GigNIC (7979CCU) Server
UPS wouldn't power up My IBM X3650 while still powering others
I have a UPS connected to 3 servers
1- IBM X3650
2- HP ProLine
3- a PC acting as a server
When power cutoff from the UPS the last 2 continue to work normally
But the IBM reboots as if the power was cutoff and back again.
Thanks
  • 428 Answers
Your ups seems not able to supply power to all the three. Check the reaction time specifications.
Posted on Jun 22, 2009
Led green flashing power amber
Amber lit when there is hardware fault within server. Open Light Path Diagnostic panel and see server part that's having amber.
Oct 21, 2013 | IBM System x3650 Server
IBMx3650 amber light appears , error indicates CPU
Most probably this would be Motherboard issue. Rare cases for processor fault. Easy to find out if server works on dual processor
Trouble shooting:
1: Perform Power Cycle (Turn off server, remove power cord from server and wait 15 min)
2: Try with minimum configuration (1 cpu, 2 ram )
(swap CPU if have dual)
3: Perform IMM update
If issue remains, replace motherboard and see if it solves issue.
Oct 21, 2013 | IBM x3650 Server
Ibm System x3650 M2 ethernet card driver
I want to download it free but i can't please guide or help me about it solution.
thanks: shahmahmood lalzada
Mar 27, 2013 | IBM System x3650 M2 7947 (79473AU) Server
I Have An IBM x3400 How do i test the smps using a voltometer
Since you haven't mentioned the type of server its unsure server has single type or dual type SMPS. This issue can due to SMPS as well Plannar (motherboard) issue. But as per post i really doubt you have bad motherboard since you see BMC and other LEDS on motherboard gets blinking..
You can troubleshoot motherboard issue this way. Press and hold server power button. Check if this makes server start. If it starts, then its confirmed you have bad motherboard.. You may also inspect whether motherboard has bulged capacitors inside..
Thanks
Oct 05, 2012 | IBM x3400 Server
I am attempting to upgrade an x3650 7979, currently running a duo core to a quad core. The machine turns on, the fans go into overdrive, but the machine won't run a post nor boot. I have looked at the...
Duo core motherboards will not support the bus speed or the power output to power on that processor. You need to upgrade the motherboard with the new processor.
Mar 05, 2011 | IBM x3650 Server
Dear experts; We have a HP R3000xr UPS, inetend to install the power management software on a server runs windows server 2008 R2 OS. Installed the power manager server software, the following messages...
Is the cable USB or SERIAL?
make sure serial port IRQ is enabled in BIOS
ALso make sure you are using x64 and not x32 drivers for UPS
ALso try getting a USB cable to connect to your UPS device
Feb 17, 2011 | HP R3000 UPS System
Hi, this morning we experienced power outage in our location, after 5 hours later power came back, but not our main server IBM System x32002. I checked the monitor and there is power. I check the green...
Depending on what caused the power outage, you may need to replace the power supply in the server. When outage happen and the power is restore. a power surge can destroy power supplies, especially if not connected to an UPS unit.
Good Luck
C2Solutions
Feb 17, 2011 | IBM System x3200 M2 Server
You should change to battery or switch to power outlet
This is typically caused by software that manages an uninterrupable power supply (aka UPS). Simply put, this is a battery that the server plugs into to so the server can run for a short time when there is a power outage.
UPS devices frequently come with software to communicate with the server so it knows when it is on battery. When the server is notified that it is on battery it will provide warning messages like the one you described. Some will even pass the notice to all computers connected to the server to make sure no work is lost.
One of the most popular programs is APC PowerChute. I would look for this program or other programs that have the words "UPS" and/or "power" in their name to find the cause.
I hope this helps.
Jun 25, 2009 | IBM eserver xSeries 205 8480
When i Connect the power cable from ups to the power inlet on the server i get some funny noise. I try to put the machine on, no response.Seems no power getting the machine.
Maybe I am reading this wrong but it sounds like you are connecting the equipment in the wrong sequence. The service is plugged into the back of the UPS unit and the UPS is plugged into a wall outlet. The UPS is a power conditioner/surge protector that keeps your server from being fried if a sudden power surge goes through and it act as a back-up power source if you lose power. Try this new connection sequence and see if you have better luck.
Jan 26, 2009 | Computers & Internet
IBM System x3650 Xeon E5355 QC 2.66GHz/8MBL2/2GB/Open Bay 2.5" SAS/SATA HS/Combo/GigNIC (7979CCU) Server Logo
249 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
