Question about Sony STR-DG520 Receiver
Problem occurs when using STRDG520 in 5.1 channel mode
Recently I bought a STRDG520 AV receiver. I am facing a noise problem when I use the system with 5 speakers enabled. Initially when I switch on the system and will get a very good effect from all the speakers but after 3 to 4 minutes I can hear the noise from the speakers which gradually increases and makes the sound very distorting and will be not able to hear any conversation / background music and will be only noise. Plz advice me what would have happend.
  • 49 Answers
Its may be because of over heating of main Audio Amp IC please check it and apply thermal compound between IC and Heat sink if required.
Posted on Aug 21, 2009
I have a HTR-3065 receiver and no sound in center speaker
Try changing surround modes - the center channel is not used in all modes. If that doesn;t work, check your speaker settingsw and make sure the center channel is not turned off
Feb 22, 2015 | Yamaha HTR-3065 5.1 Channel AV...
No signal to the satelite speakers
I don't know what you are trying to get the signal from? But yes you need to power the setup with the outputs from a av receiver.
Mar 26, 2014 | Monoprice 8247
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
In dolby digital mode i can not get any voice volume. All other sounds are ok
Assuming that you mean Dolby digital 5.1, confirm that you have a center channel properly connected and perform the following;
Using the remote, enter the menu on the receiver and navigate to the selection labeled "LEVEL." Toggle through the selections until you reach the "CENTER CHANNEL". You will be able to use the remote to increase the volume of that channel in .5dB increments.
Feb 01, 2011 | Denon AVR-589 Receiver
How do I put the GE remote xs stereo monitor into input mode without the remote?
A good universal remote to use with that monitor is the RCA RCRN04GR, available at WalMart. I recently bought a 25" GE Remote Monitor XS Stereo from a Days Inn that was replacing all of those monitors with Flat Screen TV's. When I got it home I found that it would not go to channel 4 which was default with my COX Digital Cable Box. Channel 3 is the default channel on the monitor, so I ran an AV cable from the cable box, disconected the coax and hooked up the AV cable to the back of the TV and that solved the problem. I hope that answer was helpful.
May 31, 2010 | GE Televison & Video
Have ajustments all screwed up
If you can’t resolve the issue yourself, try resetting
the AV receiver before contacting your Onkyo dealer.
To reset the AV receiver to its factory defaults,
turn it on and, while holding down the [VCR/DVR]
button, press the [ON/STANDBY] button. “Clear”
will appear on the display and the AV receiver will
enter Standby mode.
Note that resetting the AV receiver will delete your
radio presets and custom settings.
Feb 10, 2010 | Onkyo HT-S9100THX 7.1 Channel Receiver and...
Yamaha Htr-5560 Av Receiver ,will not turn on makes click-click noise only
had the same problem with a friend's 5560. it was a resistor on the rear center channel board, which is mounted right behind the middle of the heat sink. unhook the two ribbon type cables running to it from the board.
everything will work, except the rear center channel speaker. my friend never used the rear center channel anyway. in the meantime, he bought a new receiver, so i have an extra one for my workout room. woohoo. hope this helps.
Dec 12, 2008 | Televison & Video
Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Sep 07, 2008 | Yamaha RX-V2200 Receiver
No remote-
Have you bought a universal remote for the tv? That is what we had to do to get to av mode and when you do make sure you try the input button before settling with the first code that works. We stopped at the first code that changed the channels and still could not get into av mode. Finally I tried the rest of the codes and found the correct one. HOPE THIS HELPS
Aug 10, 2008 | Sanyo DS27820 27" TV
No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
Feb 01, 2007 | Sansui RZ-5300AV Receiver
Sony STR-DG520 Receiver Logo
171 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
