Here's the step by step on how I fixed this particular problem:
First, boot the computer into safe mode with command prompt. To do this, start the computer, and immediately begin pressing the F8 key at one second intervals. You may have to press several times until the boot menu comes up.
Use your arrow keys to choose Safe Mode with Command Prompt and press enter.
The computer will begin booting. Lots of weird looking white text will scroll by and then the computer will ask you to login or give you a box saying safe mode is running, etc.
Click Ok to finish loading. A black command window will appear with a c: prompt.
At that c: prompt, type chkdsk c:/r and press enter.
Check disk will start to run but then it will say:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
Type Y for yes, and press enter. Then reboot the computer into normal mode. Chkdsk will start when Windows begins loading again. Let all 5 phases run and don't use or turn off the computer. (The chkdsk process may take an hour or more to finish.)
Chkdsk finds any corrupted files that are causing the problem and fixes them. Read the results of each phase as it finishes. During the final phase, it will notify you if it finds any corrupted files.
When the Check Disk is done, it will finish loading Windows.
SOURCE: HP Pavillion ze5600 notebook won't boot up
All i can say is reinstall windows, or do the better thing and go with linux (i would use ubuntu, particularly the kubuntu variant: linux http://www.linux.com/welcome/ ubuntu http://www.ubuntu.com/ kubuntu http://www.kubuntu.org/
SOURCE: Hello! I've got a LG LW40 Express Laptop. Whenever
First, if you can run hard disk drive diagnostics, because many times a windows failure is based on the Hard Drive failing. If the Hard drive checks out, since you cannot access the Windows enviroment, you'll likely be re-installing Windows and loading drivers again. I hope your data is already backed up, otherwise it may be gone
SOURCE: black screen folowing options. safe mode etc. asus Eee pc 904hd
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
SOURCE: Asus Eee PC 1005HA - Windows won't Start
i have the exact same problem. those solutions cannot help me. i dont have any hardware installed or anything plugged into it besides the power cord. also it doesnt have a cd drive so i cant put that xp cd you were talking about. what else can we do to solve this problem. i cant get past that screen to do any of these solutions. please help
SOURCE: Unable to boot my acer laptop.
Hi Mike,
Thank you for contacting Fixya. This is Anil.
I understand that your computer is infected with Malware and now the computer is not booting to normal mode.
I can uderstand how frustrating this could be and I assure I will try be best to resolve this issue.
From the statement I understand that it may happen due to hardware failure, BIOS mismatch or due to static charge. Let us try the basic troubleshooting. Turn Off the Computer, remove all the devices attached to the computer, the power cable and battrey, now holdon the power button for 15 secs (make sure adpater and battery are uplugged) it will drain out all the static charge. Now, restart the computer and keep on tapping F2 (some computers "DEL or Delete" key), you will enter to BIOS setup utility, press F9 (click "Yes", if you are prompted) and then press F10 (Click "Yes", if you are prompted), it will restart the computer to Normal mode. If still it is not booting to normal mode, then we have to perform a full system recovery & it is a distructive process as you will loose all the datas on the computer. To do so, Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
Thank you
Regards,
Anil.B.R
