Question about Fellowes SB95C Cross-Cut Shredder
The blades do not turn - Fellowes SB95C Cross-Cut Shredder
  • Jay Blair
    Jay Blair May 11, 2010
    Do you hear any motor noise at all? Will it go in reverse?
  • valarie lethrud Apr 25, 2013
    there is motor noise but no movement in either direction
  • 328 Answers
Any motor noise at all? Any lights? Have you tried the basics? Clean the sensors with swabs and alcohol.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jun 22, 2009
I have a bosch jigsaw and the blade keeps slipping out of the roller blade guide after it runs normal for a few seconds. ive reset the blade and changed it.
Hi Rebecca, I hope this helps;
BLADE INSTALLATION
Set the blade orbit selector lever to position III.
Push blade change button downward as far as
it will go and turn the top handle three turns
counterclockwise (viewed from the top of the
tool).
Insert the blade into blade plunger at a 90°
angle to the cutting direction. With a slight
upward pressure, turn the blade teeth forward
(direction of cut) and guide the back of the
blade into the groove in the center of blade
roller guide. Pull gently down on the blade to
seat the blade tabs in the plunger.
With the blade in the proper position, turn top
handle clockwise until a noticeable "Click" sound
is heard, indicating that the blade is locked in
place.
Push blade change button upward to its
original position (flush with the top of the top
handle), and the saw is ready for use.
Removing the blade is essentially the reverse
of the installation procedure, however, take
note that once the blade change button is
loosened, gently push the blade upward to
release the blade tabs from the plunger.
Feb 13, 2017 | Bosch Saws
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
Changing blade scroll saw
Loosen the knob at the rear of the top arm - turn it counterclockwise several turns. The blade should now be loose. Push the "blade end" of the top arm down slightly with one hand while you unhook the top of the blade. Lower the blade a little to unhook it from the bottom arm.
Replace the blade. Hook it onto the lower arm first - you can look underneath to see what you're doing. The blade's teeth should point DOWNWARD - it's easy to accidentally install it the wrong way, so check that now. Again push down slightly on the end of the upper arm, then hook the top of the blade into the upper arm's blade holder. It should how stay in place, but loosely.
Now return to that tensioning knob at the top rear. Tighten it slowly until the blade is BARELY tight, not loose. Tighten the knob 1/2-turn to one full turn tighter to tension the blade.
Jul 24, 2014 | Craftsman 16" Variable Speed Scroll Saw
Motor buzzes, fan does not move, blade does not move, blade is clear of obstruction
Removing blade will not do it - there has to be an obstruction in the drive mechanism that prevents it from turning. Leave off till fixed lest you risk burning out the motor completely. Turn on AFTER you can turn the blade freely.
Sep 03, 2017 | Remington 3-Amp 17" Extended Reach...
Honda HR215 hits stump - still runs and cuts but engine vibrates when running IF the BLADE IS NOT TURNING.
you could have bent the blade or the crank look at the blade then remove the blade mount and spark plug turn on its side and turn the engine over and look for crankshaft runout
Apr 07, 2012 | Garden
Why isn't the center blade on a john deere LX178
Of course with everything off, reach under the deck and turn the center blade by hand. If:
1. the blade turns by itself and nothing else moves, you need to tighten the retaining bolt more.
2. the blade, retaining bolt and drive shaft turn, check to see if the pulley above it is turning.
a. If the pulley turns freely check that the drive belt is going around it to power the blade.
b. If the blade turns with the drive shaft and the pulley doesn't, check that the pulley is still properly connected to the blade shaft. Some have a key in them that can split, others just have a bolt on top holding them tightly on the shaft.
Jun 16, 2011 | John Deere Garden
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
I changed the blade, and now it won't start!
Did you replace the blade with a heavier blade, or an identical one? If the pull cord won't pull, it's usually either the blade or the blade shaft causing the problem. Try oiling the shaft and making sure nothing is obstructing the blade from turning.
If you have a pair of heavy gloves, try turning the blade by hand and see if it moves. Squirt some oil onto the shaft where it meets the mower and try turning it again.
May 25, 2010 | Craftsman 22 in Precision Cut Lawn Mower...
Blade wont tighten
Here are some directions on installing the blade to ensure the proper procedure has been followed when installing.
  1. Set the blade orbit selector lever to position III.
  2. Fit the supplied screwdriver into the top plunger hole and loosen the internal blade securing screw about 3 to 4 turns counterclockwise.
  3. Insert the blade into blade plunger at a 90° angle to the cutting direction. With a slight upward pressure, turn the blade teeth forward (direction of cut) and guide the back of the blade into the groove in the center of blade roller guide.
  4. Pull gently down on the blade to seat the blade tabs in the plunger.
  5. With the blade in the proper position, securely tighten the blade screw by turning the screwdriver clockwise.
I hope this helps. Please rate on how helpful the answer was. Good Luck and have a great weekend.
Apr 03, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
Fellowes SB95C Cross-Cut Shredder Logo
288 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
