Question about KDS RAD-5GS 15" Flat Panel LCD Monitor
I have a KDS 15" LCD monitor. It has not plug and on the specification plaque on the bottom says 12V 2Amp power source. I have a plug with an output of 12V 2000MA but both are female and the power supply has the negative polarity on the outter part of the plug. So does it matter what the polarity is on the monitor and is 2amps the same as 2000 milli amps? Assuming I can find an adapter.
  • 55 Answers
SOURCE: KDS K717s 17" LCD Monitor
The white screen tells me that the display cable (inside your monitor) may be unattached or broken.
The color bands if they are vertical or horizontal lines tell me that your display cable needs to be replaced.
So overall replace your display cable. If this doesn't entirely fix the problem your logic board (inside the monitor) needs to be replaced.
Posted on Mar 14, 2008
  • 1684 Answers
SOURCE: My KDS RAD-7 power supply calls for a 12v 4.16a
Yes, you an use a 5 amp power supply on the monitor. If you need one we carry them on our site at:
HTML clipboard www.ccl-la.com
I hope this helps you, if so please rate our solution.
Buddy
Corporate Computer
Posted on Jan 01, 2010
Testimonial: "Thank you for the answer. I have a 5amp one . What happened is that i ordered the wrong supply. I'll try it thank you."
budmrtn
  • 11361 Answers
SOURCE: What power supply do I use for my kds rad-7bk?
No! the current capacity way too low. check here:
http://shop.ebay.com/sis.html?_kw=KDS+RAD-5+LCD+Monitor+AC+Adapter
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 22, 2010
SOURCE: WE need the AC adapter
http://www.12vadapters.com/adapter/power-supply/12v/for-lcd-screens/hyundai-b70d-2.html
Posted on Dec 04, 2010
Monitor will not power up, removed monitor hooked
Confirm that it is not the cable, otherwise it does indeed sound like your monitor is dead.
Apr 07, 2010 | KDS Radius RAD-5 15 in. Flat Panel LCD...
My KDS RAD-7 power supply calls for a 12v 4.16a which blew out. Can i replace the power supply with a 12v 5a power supply or is that too much?
Buddy
Corporate Computer
Jan 01, 2010 | KDS Radius RAD-7 17" Flat Panel LCD...
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
KDS RAD-5 monitor set up
THE POWER SUPPLY PLUGS INTO A WIRE STICKING OUT OF THE END THAT PLUGS INTO THE COMPUTER
Apr 15, 2008 | KDS RAD-5GS 15" Flat Panel LCD Monitor
Replacement External Power Supply
So the old power supply doesn't have the output voltage, current and polarity noted on the label? What a ripoff! *grin* Did you look on the case near where it plugs into the monitor? Sometimes that will tell you the voltasge and polarity. Poliarity? Get that one wrong and the monitor could be cooked instantly! But it's usually positive. I found a completed eBay listing that had this info: "the power supply which the seller used to power up this Planar Flat Panel is inventoried as follows: ViewSonic 12V Power Adaptor Model # SYS1126-5012" I looked that one up, and it's listed as 12V at 4.17A. PC Hub has them for $28.62: http://www.pchub.com/uph/laptop/345-19804-2285/AC_Power_Adapter_5V-12V_Others_SYS1126-5012.html Good luck!
Jan 06, 2007 | Planar PL2010M 20" Flat Panel LCD Monitor
KDS RAD-5GS 15" Flat Panel LCD Monitor Logo
60 people viewed this question
Top KDS Computers & Internet Experts
Denise
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
