Remove plug spray a little fuel into the cylinder with a sprayer u have made from a used spray bottle from shower cleaner etc. That you have cleaned and dried. About 3 good sprays should do. Install plug and try to start it should run for at least a few seconds, if it does you need to disassemble and clean carburetor if it does not you need to check on off switch and if that is not problem you need to check coil.
SOURCE: Echo trimmer, replaced the spark plug, but trimmer
Possibly the gas has went bad, it doesn't take long for that small amount. Try fresh gas/mix but pull the plug and crank it several times to flush out the old gas. Clean the plug and try again. Note; the plugs foul quickly and easily.
SOURCE: my pull string came out and will not retract on my
the coiled rewind spring ends are bent back in a hook. the hook usually breaks so springdoes not wind up. some times you can re bend but steel is very brittle and keeks breaking and must be replaced
SOURCE: I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
The gas I added was fresh gas purchased that Saturday. The seafoam was add late sunday afternoon. the area were you see the gas is full. Do I need to prime again.
