SOURCE: When accelerating alternator light comes on.
Possible loose or worn alternator belt. Check the condition of the belt. If it's worn, replace it. If it's just loose, tighten it up.
SOURCE: Oldsmobile Draining Battery
You will need to check for battery voltage at the back of the alternator. The larger red wire.
SOURCE: battery draining with ignition off, clicking sound
Find the relay making the clicking noise by setting your finger on top lightly, then check map on under side of cover for identification.
SOURCE: I have a 39 ford 6 volt battery operated car. I
you need a voltage doubler circuit which feeds from your 6V DC system and converts it to AC and steps it up and converts it to 12V DC. This device might be difficult to find. OR use a 6Vdc power inverter and just use a 120volt AC fan if much easier to source out in your area.
You might want to try a 12VDC high speed fan and see if the 50% reduced speed is already sufficient for you.
SOURCE: 1998 jetta battery drains over night. pulled neg
Unhooke your altinator it has 6 diodes in it if one is bad it will drain the battery and still charge,unhook it and recheck I bet that is your problem,Thanks and I hope this helps
