Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I have a Whirlpool,Model# LSQ9549PG2.It will fill with water but will not agitate. It will spin and empty.I've replaced the Water level switch and Control Timer.It seems like the Water level switch trips and will not Reset.When I try to reset it will not go to a lower water level.
  • 1314 Answers
SOURCE: will fill water but agitator wont run.
you have a broken motor coupling if you want to tackle this your self then reply to this message and i will tell you how if you have to rate me to reply then give me 4boxes im not sure how this site works you can do it if you like to tinker
Posted on Jan 01, 2008
lenwest
  • 150 Answers
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Posted on Jan 31, 2009
aborcass
  • 2651 Answers
SOURCE: whirlpool washer wtw5200sq0 fills with water and
instead of timer soinds like a faulty lid switch, the unit not recognizing the door is closed so will only fill with water
Posted on Feb 23, 2009
  • 3741 Answers
SOURCE: Washer wont agitate.
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Posted on May 05, 2009
  • 47 Answers
SOURCE: Whirlpool top loading washing machine not finishing cycle
SOUNDS LIKE A PUMP HAS GONE BAD. REPLACE IT. IT WOULDN'T COST TOO MUCH.
Posted on May 14, 2009
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
Washer won't agitate with clothes in. Will agitate when empty with water
It's a whirlpool top load and 17 years old.
I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
Nov 26, 2012 | Whirlpool Washing Machines
Washer won't change gears from water fill to agitate
Hi and welcome to FidYa, I am Kelly,
If it does not agitate or spin suspect the lid switch. Listen for a microswitch click as the lid just opens or closes. No Click = bad lid switch.
If it spins then the lid switch is fine and there is a problem with the water level control pressure switch or possibly the control.
Since you did not include a model number this is my best guess for a 3.2 cu ft machine
MVWC300VW0
This lid switch is item 6 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5519632
The water level control switch is item 4 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5519632&diagram_id=28626536#d28626536
The timer item 7 of the above link can also cause this symptom. You must elimiate the water level control as a possible cause first. There is a FOLDED wiring diagram in the literature packet insde the top panel 3 x 5 envelope you can use to jumper the wires on the water level control switch. If the motor agitates then the water level switch is the problem. If it does not agitate it can be the timer or the motor. (More troubleshooting required via the wiring diagrams following power through the circuit to the motor.)
At this time I think you may just have a water level control switch problem. If you do end up replacing it... the wash tub must be empty or it will overflow when testing.
Thanks for choosing FixYa,
Kelly
Sep 15, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Beginning of wash cycle starts agitating instead of filling w/water.
the water pressure/level switch contacts are welded together,usually the load selector switch for the amount of water lets it fill to a determined water level and the water level creates pressure in a tube from the tub to this switch and stops water fill and starts the wash agitation cycle,replace this switch inside the control panel
Mar 19, 2011 | Whirlpool Washing Machines
Whirlpool model # LLR6144BQ1 water fills but will not go to wash cycle.
Hi and welcome to FixYa, I am Kelly.
This is usually caused by a failed lid switch that is item 9 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=256996
First off put the washer in the spin cycle. With the lid closed see if the washer will spin. No spin also = bad lid switch. If the washer spins but will not agitate then the problem is most likely the water level pressure switch or associated air tubing. (any air leaks and it will not stop filling)
Water level switch is item 12 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=256996&diagram_id=28209075#d28209075
We test these with NO WATER in the machine and after connecting an external hose with the lid closed with power on by orally passing air into the small air hose we connected. It will click and the washer must agitate. If it clicks and does not agitate... again it points to the lid switch. Disconnecting this water level switch hose with ater in the maching and then re-connecting the hose WILL result in the machine overflowing. Tub MUST be empty.
You check the lid switch as you just open or close the lid. You should hear an audible CLICK as the lid is barely off of its closed position and again as the lid is almost closed. NO CLICK = bad door switch.
These are the 2 most common reasons that will correct the symptom your experiencing more than 90 percent of the time. There is a remote possibility that there is a problem with the motor / motor clutch. Motor clutch problems are noted by odd noises when motor is running and it will not spin or agitate. If the motor will spin the machine but will not agitate the machine it can be a motor winding.
Kelly
Mar 13, 2011 | Whirlpool Washing Machines
We have a whirlpool LSR7233EZO. When I set the dial where it should fill with water no water runs in but the agitator runs. This happens on any of the load choices. From what I've been able to find out I...
Your problem sounds like a faulty water level switch,not your fill valve. With the machine empty at the beginning of your cycles, the switch should internally be in the "empty" position to energize your fill valve solenoid(s), then when the machine completes the filling to the level selected on your water level knob, the level switch repositions to the "full" position to energize your timer to advance the cycle. If the switch is stuck in the "full" position all the time, as soon as you pull your timer knob out to start any cycle, the machine already thinks it has filled to the desired level, and immediately energizes your timer to advance to the wash step and begin agitation, even though the tub is dry. I will refer you to the following link for a video showing you the fill/switch replacement procedure: http://www.youtube.com/watch?v=bIs9gX0YjxI&feature=related
I hope I've addressed your problem as described
kcomp1863
Jan 20, 2011 | Whirlpool Washing Machines
Washing Machine does not agitate
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Following is the Whirlpool installation and maintenance PDF on how top load, direct drive washers work with a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is the Whirlpool parts list for commercial top load, direct drive washers although the consumer washers are basically the same.
The problem seems to point to the Agitate Cams in the transmission that raise and lower the Agitate gear on the main transmission shaft. These are relatively inexpensive to replace.
I'd also check the splines on the main agitator shaft and the two pronged "washer" on top of it.
Oct 03, 2009 | Kenmore Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washer not filling
stuck pressure switch/water level switch also ckd for blocked or pinched hose to switch try taping water level switch possible stuck contact if this is case replace control wouldn't trust it not to do it again or worse overfill and fload
May 10, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
132 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
