Question about Motorola GT Radio Battery
Schelg the schelg sound stays on busy tone all the time but the radio transmitted
  • Motorola Master
  • 1,654 Answers
You either have a radio problem or a battery problem. Try switching the battery out of another radio into this one to see if the problem goes away. If not, you have a radio problem. (The Motorola Spirit GT is a non-repairable unit.) If the battery solves the problem, you can purchase a replacement battery online or through your local Motorola dealer. Part number HNN9720 or 53720A. Squelching is a normal sign of a failing battery.
Posted on Jun 22, 2009
I need to tune my baofeng gt-3 mk2 to the same frequency as my baofeng bf-888s I can hear the bf-888s with my gt-3 but cannot talk I've tried every website why cant i talk over it????
1. Make sure both radios are transmitting and receiving on the same frequency (no repeater offset).
2. Either turn off CTCSS tone or make sure both radios are set to the same tone on both Tx and Rx.
Jan 20, 2015 | Generic Walkie Talkie BAOFENG BF-888s Two...
Stop the sound of a Tone when Keying to Transmit..
That generally means that it's set to transmit on an invalid frequency.
Jul 26, 2013 | Motorola TalkAbout T5530 2-Way Radio
Radio will transmit and other radios receive and hear it. I will receive but will nor produce any sound. I have re-programmed it twice but to no avail. Please advise.
Your PL (aka private line, tone code, quiet call, interference eliminator) might be programmed differently between the radios. OR you have a radio needing repair.
Best regards.
Mar 07, 2011 | Motorola Mobility RDV2020 RDX Series On...
I have 2 Motorola P110 2 Ch Radios. One powers up and when I press the PTT button the red light comes on, so I think it works but the 2nd one when I press the PTT button the light is a lighter color of red...
There a a few things which could cause this:
1) You have the radio set to an unprogrammed channel.
2) You have a bad, low or defective battery. (Try switching batteries with the other unit and see if the problem goes away.)
3) Your radio needs repair.
4) Your radio has busy-channel-lock-out activated and you are trying to transmit on a frequency which has activity in your area.
Oct 01, 2009 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
What are some of the possible problems with transmitting a call tone?
As far as the functionality of the radio, there would be no problem with transmitting a call tone. Two things to consider would be the hesitation you would need to have before talking, when you press the PTT and await the call tone to happen on the other unit(s). And the sound factor on the other end. Some environments are not conducive to having a radio ring or beep before each message.
Jun 25, 2009 | Motorola Talkabout T5500 (7 Channels)...
Motorola T5100 Radio
Setting and Transmitting Call Tones
Your radio can transmit different call tones to other radios in your group so you can alert them that you want to talk.
To set a call tone:
1. With the radio on, press MENU 3 times. The current call tone setting flashes and displays.
2. Press + or - to change and hear the call tone.
3. Press MENU or PTT to set the new call tone or turn feature off.
http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf
Sep 11, 2008 | Motorola Talkabout T5100 (14 Channels)...
Ring tone thingy
To set a call tone:
Sep 07, 2008 | Motorola Talkabout T5420 (14 Channels)...
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
Radio Mic
Check the squelch on your radio thats not recieving. If there is a monitor button ( when pushed you will hear static) try pushing it.. then get someone to call you so you can check if you can hear them. On these radios you have 2 types of squelch....1 is called carrier squelch.... it basically opens when there is a strong enough signal. This lets you only hear strong signals and "squelch out" the distant ones and background static. The2nd. is "tone squelch" ... with your radio they are often called privacy tones. If you have 2 radios set with the same privacy tones you will only be able to hear each other... only radios that are transmitting with that privacy tone will be heard on your radio. Its a high frequency tone that can't be hear by the human ear that gets "embeded" with the transmitting signal. The recieving radio hears it and opens the squelch. So... if the radio thats rxing (recieving)your signal has its squelch set for just carrier squelch it will hear any signal thats strong enough to break the squech open.... basicaly any radio within a certain range. But if your radio (one with problem) has its squelch set for privacy tones you will not hear any other radios except the ones set with the same privacy tone.... the squelch will not open until it gets a tx signal with the right tone.... so if the txing (transmitting) radio is not using tone squelch but is using carrier squelch.... and the rxing radio is set for tone squelch... the rxing radio will not hear it. With tone (privacy tones/codes) squelch you need a tone to open the squelch and then the audio can be heard... with carrier squelch the squelch will open if ANY radio is within a certain range. Check the squelch setting on the problem radio... it could have a privacy tone set. Try pushing in the monitor button so you can hear static ( you want to hear everything including static) on both radios... tx on one radio at a time and listen if it can be heard on the other with the monitor button pushed. If you can't hear any audio when the broken one is transmitting then it COULD be the mic.... if you can hear both radios with the monitor button activated than the radios are txing and have tx audio and are working... if thats the case its the privacy tones that are the problem. Take care
Sep 12, 2007 | Garmin Rino 120 2-Way Radio
Radio Communications Logo
57 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
