Question about Canon Pixma MP500 All-In-One InkJet Printer
Colour management MP500
I am using Photoshop CS3 and a variety of papers. I want to turn off the colour mangagement system so that I can "profile" and standardise on one set of inks and a range of different papers.
I need to know how to turn off colour management and then instal the profile.
    President:
  • 2,306 Answers
The printer profiles are in the printer properties tab either in the control panel under printing preferences, or in the dialog box that pops up when you press print, under advanced options and preferences.
Posted on Jun 22, 2009
My Canon Pro9000 MarkII prints photos with a red tint
You probably haven't calibrated your monitor to show the correct colours, so in whatever photo programme you're using, you're setting the red tones too high. Test this by first not calibrating your monitor, but turning down all the red tone until it looks washed out. Print this and see if it's better. If so, set your monitor to a cooler colour temperature. If the result is no better, check your print dialogue settings to make sure you are using an appropriate colour profile. And, for example, if you're using Photoshop, tick 'let Photoshop manage colours' in the advanced profile settings box. Hope this helps. I doubt there's anything wrong with the printer.
Dec 29, 2012 | Canon Pixma Pro 9000 MARK II InkJet Photo...
Canon iP4500 colour management
Try this setting. This might be different but try to point some similar preferences and steps then you can give it a try.
Open Control Panel (I'm assuming that the OS is Windows XP) click on Printers and Faxes.
Right click the Canon iP4500
Click Properties in the drop down menu.
Click on the tab Color Management
There should be a list of color profiles if the drivers were installed properly.
They are-
(Generic)
(Matte Photo Paper)
(Photo Paper Pro)
(Photo Paper Pro Matte)
(Photo Paper Plus Glossy)
The last profile is the one you want. Just above you will see the choice of "Automatic" or "Manual". Click on Manual and this force the printer to use the highlighted profile for all printing jobs.
Now click on DEFAULT.
Go back to the main Properties page and click on the General tab.
Near the bottom you will see "Printing Preferences"
click on that.
You should now be in a Canon ip4500 Printing preferences window.
Look for Print Quality and click "Manual"
Click on "Set"
Click on "Diffusion" and just above that there is a slider that should be all the way to the right.
Click "OK" to save the settings.
Now just below you will see "Color Settings"
Click "Custom" and then "Set"
Everyone sees colors a little different but the following settings print a photo that folks I show them too really like the balance of.
Cyan 4
Magenta -12
Yellow 0
Black 0
Intensity Slider in the middle
Enable ICM not checked (disabled)
Print Type set to Photo (you might want to try the other settings here to see how the prints look to your eyes)
Brightness Normal
Click OK to save settings and return to the Main Menu.
If you now go under the Profiles tab you should see you new profile there.
You can give it a special name like "Canon Excellent Profile Settings" clip_image001.gifor some other easy to remember name. This is the profile you want to use when you print a photo.
That is it...simple eh?
Now the other important part is in PhotoShop/PS Elements. Open the program and then open any old photo.
Under File, scroll down to Print Preview and click
If not open, click on "Show More Options"
Bring up "Color Management" in the box just below the "Show More Options"
For "Source Space" click ""Document"
This setting depend on the profile you shoot in, either Adobe RGB or sRGB. You choose the one you use.
Below that there is a setting for "Print Space"
You want to match that to your source, whether Adobe RGB or sRGB.
For the "Intent" letting I choose Perceptual.
Then click "Use Black Point Compensation" and that is it. Ready to print
Aug 08, 2008 | Canon Pixma iP4500 InkJet Printer
I suspect this will be a tricky one! I am printing from a new iMac / CS5 setup. I am using OCP inks and Ilford paper. I am printing the same images to both machines. The print settings are identical....
hi Anthony, i spent a month trying to figure out a similar problem with an epson 2200. Now, the printers are different but not that much, and, the changes in paper and ink gave me "some" color issues but not as bad as what i was getting. your problem seems very similar. i run a PC so this is similar but not exactly the same. what i found was that a Magenta/ violet cast was due to double profiling. I could verify that i had the correct settings but i was wrong! I print from CS3 into the epson 2200. What i found was there is an error(no one is talking about) in the printer driver. You cannot shut off the color management completely! Assume this scenario, you are printing with CS3 applying your profile in CS3. Make the settings in CS3 as normal, then you are directed to the printer settings. Go to the print driver and make the selections for ICM Color, and select "no color". The KEY is to make sure you do this step LAST , make sure to click on the "apply" button, then "Close". Once you make the selection of "No Color" do NOT click on anything else. If you change screens in the print driver once you select "no color mgmt" the driver CHANGES your settings. ANY settings in the other pages in the print driver cause the driver to apply a printer profile, this effectively "double profiles" your photo print causing the magenta cast. None of this should happen if the driver was created correctly but there it is! It took a long time to test and verify but it is as i stated. Once i got it sorted out my photos are excellent ALL the time. Good luck, worm1855.
Nov 21, 2010 | Epson R800 InkJet Printer
I have a Samsung CLP-315 laser color printer. I'm trying to find out if there's a *.icc or *.icm color profile for it to use with Adobe Photoshop. Couldn't find anything yet via google or others. Would you...
I have just purchased a CLP 325 and have set it up to get excellent colour pictures using Adobe Photoshop and the icc profiles readily available.
Your current working icc profile could be either Adobe RGB (1998), sRGB, Profoto or another. I would suggest that for everyday work use sRGB, if you are a specialist use Adobe RGB (1998).
Firstly make these changes in Photoshop:
Edit / Assign Profile / ColourMatch RGB.
To print:
File / Print / printer profile should be Adobe RGB (1998)
Illustration attached
Aug 24, 2010 | Samsung CLP-315W Laser Color Printer
Epson 1400, Mac computer, paper profile all set up. Using CS4, I can't see how to disable colour management in the printer set-up window. If I choose photoshop in colour handling, it doesn't print...
Solved by a friend who told me that i needed an up-to date driver for my brand new Mac - why hadn't it been loaded a long time ago - this seems to have been a problem for quite a time, A vital bit of the printer menu was missing. Please get the Apple Mac to use the latest driver for this machine.
cardy
Nov 10, 2009 | Epson Stylus Photo 1400 Printer
Using the IP5000 and Canon Glossy Photo Paper am
Every time I have had problem have had to replace ink.
Sep 05, 2017 | Canon PIXMA iP5000 InkJet Photo Printer
Dark prints when printing from my Imac using Leopard
I was also having problems with my Epson scanner on my iMac. I read that the best way to solve Epson's problems is to (1) uninstall all Epson software from your HD, and (2) download the appropriate drivers from Epson and install them.
Note: The Epson R1800 has two drivers: the most recent is an update. So, you must first download and install the Printer Driver v6.12. When that's done, then download and install Printer Driver Update v1.02.
I did that and I still got dark prints. Then I got an inspiration. In the Print dialogue box, I changed my Printer Profile to the paper I was using, Epson Premium Luster Photo Paper, instead of using sRGB and/or Adobe RGB. Specifically, I used SPR1800 PrmLstr PhotoRPM.icc. The next test print was virtually spot on to what was displayed on the screen. I am now a VERY happy camper.
Please pass this info onto anyone else who can use it.
Tim Calderwood
Sep 11, 2008 | Epson Stylus Photo R1800 InkJet Printer
COLOUR ON W6400PG
What paper are you using? If the paper is glossy, try matte settings to get a more saturated print
Jun 07, 2008 | Canon imagePROGRAF W6400 InkJet Printer
Printer: Canon PIXMA MP610 Operating system: Mac OS 10.4 Problem: Printing 4x6 photos is excruciatingly slow from iPhoto and Photoshop CS3. I thought it may have been something to do wireless printing,...
When printing from programs like that, usually the "BEST" option is selected for the print quality.. Try going into the preferences and choosing a lower quality.
If that doesn't help, for Photoshop, you can "save for web and devices", choose PNG and then save to desktop, and use another program to print the file. Or when in the print dialogue, make sure "printer manages colour management"
Not too sure about Iphoto print settings, but there may be something in there.
Apr 11, 2008 | Office Equipment & Supplies
Epson 2400 printer prints dark and with slight colour cast
try these :
1. nozzle check
2. image set to RGB color (Photoshop)
3. check driver settings
4. try another file
5. try another application
6. ¨supported / recommended¨ epson paper & inks
7. another computer (to pin down where issue is happening)
8. all else fails - the printer needs service (better check your warranty status)
Jan 03, 2008 | Epson Stylus Photo R2400 InkJet Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
146 people viewed this question
old marine
old marine
