Question about Konica Minolta magicolor 2490MF Laser Printer
Hi I have a Konica Minolta 2490MF and when I try to print a document/s it will print the first page only then comes up with an error 'incorrect paper size (1LT)' the paper size is correct (A4) and the paper size setting is A4. If I take the paper out of the feeder and replace it again the error message dissapears, it prints 1 page then the error message comes up again. I've tried a different type of paper but nothing I do seems to fix the problem. Hope you can help Thanks Stephen
  • Ivan Minev
    Ivan Minev Feb 22, 2012
    I have the same problem and my KM2490MF is only Fax/copy without PC connected to it. I check all the settings an everything i set to A4
  • 1,555 Answers
Mr Stephen You have to check paper settings at 3 places first that you are putting correct paper size in correct tray and the paper supporter is touching the paper. Secondly your documents page setup paper size. Finally go to printer properties and under paper selection you will find letter size change it to a4 Thankyou for using free solutions at yafix-ratings from your side would be appriciated.
Posted on Jun 22, 2009
Error light flashes screen reads caution machine trouble than change to service call 101 h
Scanner motor malfunction, check the scanner lock switch, normal use when moving the machine so scanner does not break, or you have a bad scanner, which is located under the big glass with the very bright light that comes on when you scan or make a copy..
As for the paper check to ensure you have the correct media selected not metric but inch, check your driver setting also inch not mretric no A3 or A4 that metric
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 20, 2014 | Konica Minolta magicolor 2490MF Laser...
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Konica minolta size media error
i have a bizhub C350 and has this error code coming once power ON the error code C-12CC..please if any one has faced the problem i will appreciate your help....
Aug 14, 2012 | Konica Minolta magicolor 2490MF Laser...
Konica Minolta 2490mf . Have just put in compatible toner catrdges and printer is telling me YMCK toner incorrect can you help many thanks Steve
Perhaps clean the connections between the toner-chips and the printer.
As the are lokated below the toner cartridges in your printer the tend to get dirty
and cleaning them can make the difference...
If this does not help, try the old cartridges and see what message you get.
If that is a different one your cartridges doesn't match your printer and you should get replace ones.
Greetz, Robert.
Sep 06, 2011 | Konica Minolta magicolor 2490MF Laser...
My Konica Minolta magicolour 2500w won't print web pages any more
I believe it is a Windows problem and not a printer problem. Try to print from a different application, to see if it is working.
Jun 07, 2009 | Konica Minolta PagePro 1350W Laser Printer
KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
Feb 18, 2009 | Konica Minolta magicolor 2490MF Laser...
Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
NAND FLASH ROM ERROR - 2490MF
Konica before fixing the issue used to ship out the controller board.
Now a simple firmware upgrade will solve your issue
Aug 11, 2008 | Konica Minolta magicolor 2490MF Laser...
Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
May 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor  2490MF Laser Printer Logo
1,048 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
