Question about Microsoft OFFICE 2003 BASIC OEM ENGLISH MS (S550039701)
VBA and macros
How to write script in VBA which helps to creat a macros in excel.
As if now i dont know what is VBA and Macros and how it works.
Can you please help out with this regard.
  • zaw min oo
    zaw min oo Oct 14, 2010
    To understand VBA, you can download here and read it.
    Problem Solver:
  • 12 Answers
To understand VBA, you download HERE and read it.
Posted on Oct 14, 2010
I am using microsoft excel 2007, the code is not running, the macro was disabled.. How to enable the macro...?
From the excel help file
  1. Click the Microsoft Office Button o12filemenubutton_za10077102.gif, and then click Excel Options.
  2. Click Trust Center, click Trust Center Settings, and then click Macro Settings.
  3. Click the options that you want:
    • Disable all macros without notification Click this option if you don't trust macros. All macros in documents and security alerts about macros are disabled. If there are documents with unsigned macros that you do trust, you can put those documents into a trusted location. Documents in trusted locations are allowed to run without being checked by the Trust Center security system.
    • Disable all macros with notification This is the default setting. Click this option if you want macros to be disabled, but you want to get security alerts if there are macros present. This way, you can choose when to enable those macros on a case by case basis.
    • Disable all macros except digitally signed macros This setting is the same as the Disable all macros with notification option, except that if the macro is digitally signed by a trusted publisher, the macro can run if you have already trusted the publisher. If you have not trusted the publisher, you are notified. That way, you can choose to enable those signed macros or trust the publisher. All unsigned macros are disabled without notification.
    • Enable all macros (not recommended, potentially dangerous code can run) Click this option to allow all macros to run. This setting makes your computer vulnerable to potentially malicious code and is not recommended.
    • Trust access to the VBA project object model This setting is for developers and is used to deliberately lock out or allow programmatic access to the VBA object model from any Automation client. In other words, it provides a security option for code that is written to automate an Office program and programmatically manipulate the Microsoft Visual Basic for Applications (VBA) environment and object model. This is a per user and per application setting, and denies access by default. This security option makes it more difficult for unauthorized programs to build "self-replicating" code that can harm end-user systems. For any Automation client to be able to access the VBA object model programmatically, the user running the code must explicitly grant access. To turn on access, select the check box.
Jun 21, 2011 | Microsoft Office Professional 2007 Full...
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
Using Macros in Excel sheet Requires Programing.. or it can be done, as we do Vlookup and other formulas
Creating Macros does not require programming. The only suggestion I would make if you are new to macros - break down your task to very small sub tasks, in order to avoid confusion.
Jun 09, 2009 | Microsoft Excel for PC
Need a link
Macros are harder to understand than they are to create and use. Let me repeat "Macros are harder to understand than they are to create and use."
Here is the only understanding that you need. "they are used for repetive tasks" .
Now to the simple part of creating then using.
Get into your work and identify a task that you want to created macro for, Kapish? Just before you start on the task go into the macros screen and tell it to "create", then do your task. When through "push the stop button. Name the micro and save it. (the name may be the first step if so then give the darn thing a name, no big deal). The next time you are in the exact field where the identical task is going to be perforned you can call up the micro to run through the key strokes for you. Get ready for wildly unexpected results, with those understood you can go into the code and modify it. Or you can delete it and create anotherone that is cleaner. Keep doing this until you get the bugs out. By the way the once created micros leave a tag in the spreadsheet that alerts everyone that opens it to watch out for the dreaded micro you created.
Jun 20, 2008 | Microsoft Computers & Internet
Macro
Hi motilal
Follow these steps to create multiple macros
Click the Microsoft Office Button , and then click Excel Options.
In the Popular category, under Top options for working with Excel, select the Show Developer tab in the Ribbon check box, and then click OK.
Note The Ribbon is a component of the Microsoft Office Fluent user interface.
To set the security level temporarily to enable all macros, do the following: On the Developer tab, in the Code group, click Macro Security.
In the Macros Settings category, under Macro Settings, click Enable all macros (not recommended, potentially dangerous code can run), and then click OK.
Note To help prevent potentially dangerous code from running, we recommend that you return to any of the settings that disable all macros after you finish working with macros.
Open the workbook that contains the module that you want to copy and the workbook that you want to copy the module to.
On the Developer tab, in the Code group, click Visual Basic.
On the View menu, click Project Explorer .
Drag the module that you want to copy to the destination workbook.
Regards,
TheAssembler
May 06, 2008 | Microsoft Excel for PC
Office 2007 Standard - VBA not working
There is no indication that VBA should not work in all versions of Excel. There is a new file extension (xlsm), which is used to activate macros and allow usage. If you have, perhaps, opened and saved with incorrect extension (new is xlsx), VBA may be unavailable. Try to resave it with the changed extension. It seems likely that this is the issue (reference http://office.microsoft.com/en-us/excel/HP100141031033.aspx?pid=CH100648071033). Also, if you make sure your Save As option is set at xlsm, this should help to prevent problems. VBA should not be an issue in any version of Excel and custom functions ARE available (see http://office.microsoft.com/en-us/excel/HA102189961033.aspx?pid=CH100645021033). It should be as simple as changing the extension, and I would suggest changing the default save as option. If this helps, please rate "FixYa"! Thanks!
Apr 03, 2008 | Microsoft Office Standard for PC
Writing macros
Anirbanmj
Macros for Excel and the rest of the office suite are based on Visual Basic for Applications (VBA) which is a subset of VB programming language.
If your not familier with this language then i would suggest "Googling" VBA Introduction or similar and have a look at some introductory info. If you are ok with VB then you can record doing a task you want to do and then look at the code generated to see what it has created.
Feb 02, 2008 | Computers & Internet
One problem in the application of excel sheet
I can make out that
You are speaking about creating a macro to take data from one constant updated cell and to put that data into another cell or form sheet.
You will need to get precise help from a programmer on this.
If you want to see a little on macros just open a sheet and checkout the help section on macros.
Some macros can take many hours to write and test.Some make take months.
hope this helps.
Jan 30, 2008 | Microsoft Windows XP Home Edition
Macro on excel
Macros are a timesaving feature that allow you to record a sequence of actions that you do in excel, and replay them back later.
You give each macro a name, and you can invoke them later, and Excel will "do" whatever it is you did when you recorded the macro.
To record a new macro:
1) Open Excel
2) Go to Tools->Macros->Record New Macro...
3) Type in a name for your macro and hit OK
(A new toolbar will popup with a "stop" button on it. Excel is now recording everything you do)
4) Do something, like, for example, select some cells and make them bold.
5) Click the "stop" button.
Now your macro has been recorded! You can play it back later by:
1) Open Excel
2) Go to Tools->Macros->Macros...
3) Select your macro from the list
4) Click "Run"
The actions you performed earlier will now be executed.
Macros are written in Visual Basic for Applications, or "VBA". It is a programming language which uses the Excel Object Model to perform various actions. You can edit and create custom macros by writing the code manually in VBA. To do this:
1) Open Excel
2) Go to tools->macros->macros...
3) Select an already existing macro
4) Click "Edit"
(The visual basic editor will open, showing you the code for your macro)
At this point you are writing a program in Visual Basic. To learn how to edit macros, you need to learn visual basic, as well as the specific quirks related to excel macros in visual basic.
Recording a macro, and then using it as a template while you edit it is a common trick for making macros manually more quickly.
If you are not familiar with VB, I would not suggest attempting to edit your macros in any but the most simplest of ways. If you're brave, you can try to learn about editing macros in VBA here:
http://www.anthony-vba.kefra.com/
Jan 28, 2008 | Computers & Internet
Macro to be used in Excel
Instead of me teaching u. i would suggest u learn it by following the simple steps.
1. Click Tools > Macros > record
2. do some common operation like copying data, creating graphs, etc.
3. press alt+F11 to go to vb editor, to see ur macro recorded
4. study it ... u will learn easily
or
try the book 'Microsoft Excel Visual Basic Macros Examples' at http://www.add-ins.com/vbexamplestopics.htm
bye
have a nice day
Jan 26, 2008 | Computers & Internet
Computers & Internet Logo
204 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
