Question about Nokia N70 Cellular Phone
Network trouble I use my nokia N70 for connecting my pc to internet.I connect my phone through both bluetooth and usb.I connect to internet using one touch access.I had no problems at all in the past.But recently i have problem keeping my connection alive.I mean when i first connect to internet it stays alive for about some minutes,but then it stops.One touch access shows connected.The internet icon stays but the computer in the icon on the farther side stops glowing.Then i have to click on disconnect button on one touch access,then click on connect again.Sometimes it works.The connection stays on for lesser time as the above process continues.Also my mobile shows the sign that internet connection is on.But when i put my phone in offline and then put it back in general,phone connects to network again,then I again try to connect to internet,it works. Please tell me what is the problem. Any insight is appreciated. THANKS IN ADVANCE.
  • 1 more comment
  • downup007 Jun 22, 2009
    no i do not get any error messages.Infact,everything looks normal,except when i observe the network icon i realise that internet connection is gone
    I installed the latest version of PC suitever.7.1
    But i connects to internet through bluetooth and then immediately disconnects it.It keeps connection alive when connected through usb but then the earlier problem persists.Tell me what should I do.
    Thanks for the comment
  • downup007 Jun 23, 2009
    Hi.Thanks for the effort.To be very frank,I was so upset by the problem that I formatted my PC and my phone yesterday.None helped.But I will try on a different computer and let you know.
    I noticed one problem.Once the connection gets lost,nothing else helps.I have to restart my phone which works for sometime.This might provide a solution.
    Thanks.
  • 1,272 Answers
I believe this issue is with the PC Suite software. Try installing an updated version of PC Suite.
Rate it, if helpful.
Posted on Jun 22, 2009
  • Anand Gupta
    Anand Gupta Jun 23, 2009
    Did you try this on a diffrent computer?
  • Anand Gupta
    Anand Gupta Jun 24, 2009
    I had the same problem dear. Even I was forced to reboot the phone and sometimes the computer to regain internet access. I just resort to connect using data cable and avoid using bluetooth connection.
  • 1,555 Answers
Do you get generic host win 32 error
  • Aruna Singh
    Aruna Singh Jun 22, 2009
    which area are you in because at metros airtel stops services for those connections which are dormant for some time i.e. no network usage. so i'd suggest you go to start button run and type command
    in command prompt type ping www.yahoo.com -t
    this will keep your connection alive minimise the window and keep working
How to transfer music to N70 without using a card reader or bluetooth ? my card reader is missing ..
Good Day,
Transferring file to a PC from an N70 phone, can be done in three ways
1: via Bluetooth 2: via memory card (by the use of memory card reader) 3: via Nokia PC Suite using standard N70 (DKU-2) Cable chiefmecha_4.jpg
I guess you are left the last option, which is I am sure you have a cable for your phone. Because it is included in the box when you bought the phone.
But before you can actually connect your phone to your PC, even if you have the cable, you must install Nokia PC Suite first. Just go here and download the software. http://nds1.nokia.com/files/support/global/phones/software/Nokia_PC_Suite_eng_web.exe
After installing you can go and connect the cable to your N70 phone and connect to a USB port on your PC. The phone may ask you on its screen to choose what kind of connectivity you want, if you want to just transfer files, you may just choose Disk option or removable disk access, and access its MMC via the windows explorer just like a card reader.
Hope this helps you. Thank you for using Fixya.
Aug 09, 2011 | Nokia N70 Cellular Phone
Tip
How to use a mobile phone as modem.
Two methods are there to use your phone as modem
1)you can use your PC suit to use your phone as modem for You need
*USB cable or Bluetooth on your mobile
*PC suit software provide by phone manufacturer(ex:Nokia,Samsung,LG,Sony Ericsson).
To use your phone as modem
*install the PC suit softwareConnect your phone to PC via USB cable(I recommend you to use USB because it's faster)
*Open PC suit and select "Connect to internet"
*if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list now it works.
2)You can use Bluetooth technology to connect to internet (2 methods are there)
For this you need
*Bluetooth on your PC and phone
To connect(in windows OS)
*Click on Bluetooth symbol on task bar
*Select add device select from device which can be connected to your PC list(set your Bluetooth device to visible all mode)
*Add your device to your PC Add completion of the above...
*Again click on Bluetooth symbol on task bar
*Select "show all devices"
*now select your device(one click) at this time 4 options appears on top your devices list
*select connect using>access point
and 2nd method is
*Again click on bluetooth symbol on task bar
*Select "show all devices" *double click on your device
*select connect to internet from the dialog box which appears after selecting the your device
Above options are with respect to Window 7 and Windows related operating system.
Thank you...:)
ANY SUGGESTIONS?
on Jan 30, 2011 | Computers & Internet
HOW TO CONNECT N70 TO NOKIA HF-33W ? I HAVE FORGOT THE PASSCODE TO CONNECT THROUGH BLUETOOTH. PLEASE ASSIST
switch on your bluetooth headset . then go to settings on your phone.then click connectivity ->bluetooth-> pair device-> pair new device -> it search and ask passcode enter 0000 as pass code now it will connected still having trouble reply me
Jul 22, 2011 | Nokia N70 Cellular Phone
How can i download a music..and how can i connect to internet service or network.
To connect to the internet with your Nokia 7610 running symbian read the following link
http://web.singnet.com.sg/~kinston/Bluetooth%20Internet.htm
It's very detailed and should get your phone on the internet via bluetooth and connecting it to your computer.
As for downloading music you would need to download them via your computer, install the Nokia PC suite found here http://www.nokiausa.com/get-support-and-software/software/nokia-pc-suites/compatibility-and-download and connect your phone up either by bluetooth or usb kit to the computer and transfer your music over.
Mar 03, 2011 | Nokia 7610
How to do update my nokia n70 phone
for firmware update, check for available updates, check this link
http://www.nokia.co.in/get-support-and-software/download-software/device-software-update/can-i-update
or simply you can go to nokia care who can do for free under warranty.
to connect PC and mobile through bluetooth, you should have a bluetooth dongle or a bluetooth facility already in the PC, switch on the bluetooth, find the devices and enter password 0000, on select the device found in PC (mobile), refresh services, right click, select dial up networking, contact service provider for settings.
May 05, 2010 | Nokia N70 Cellular Phone
How can i connect my nokia n70 mobile to desktop via bluetooth.plz tell me what to install the software for that.write now im with windows xp2.plz help me
Done!!!, do you have bluetooth on your on you laptop if yes, find and download nokia ovi suite, ffrom the internet www.ovi.com when you are done doing this, install the nokia suite, and follow the instruction, its done as i said earlier.
regards,
you remember to vote for me it counts
Mar 27, 2010 | Nokia N70 Cellular Phone
I use my nokia N70 for connecting my pc to internet.I connect my phone through both bluetooth and usb.I connect to internet using one touch access.I had no problems at all in the past.But recently i have...
We want to change the properties for our connection to the internet. This is the adapter we want to share "from". Just right-click in the corresponding icon and select Properties.
The Bluetooth Network adapter was automatically created during the Bluetooth installation.
There's a bug in Windows 2000 before SP3 where changing the sharing option may change IP configurations in this adapter. To make sure you're safe, we will note the current configuration.
In the General tab select the Internet Protocol components and click Properties.
Write down all the information from the next dialog, and click Cancel.
Back in the Adapter properties, select the "Sharing" tab and tick "Enable Internet Connection Sharing for this connection".
Now, to configure the Bluetooth USB, right- click the Bluetooth icon in the system tray and select Advanced Configuration.
Change to the Local Services tab and double click "Network Access".
Change the type of service to "Allow other devices to acces the Internet/LAN via this computer".
The alternative to this option will allow your device to connect to your computer as part of a LAN, but will not have internet access.
Note the Configure Connection Sharing button: it'll open the configuration screens we've visited before. But some Bluetooth software will not have this button, hence I guided you through the other route .
Now, on your Pocket PC... Tap the Bluetooth icon the the status bar and select Bluetooth Manager.
You'll see your notebook or desktop here, and if it's out of range a question mark (like in the mobile icon in the picture).
Tap the icon corresponding to your computer or notebook.
If the computer does not show here, the devices are not paired! Go back and pair then.
Tap the Actions menu option.
Tap the "Connect to Network Access" option.
If all is ok, you'll see the message "Connected for Network Access" here !
Just start using your favorite programs... ICQ, Pocket Outlook, MSN Messenge, Pocket Internet Explorer .
Yes, visit the Geekzone mobile, or browse the internet from the sofa...
"Hmmm, what's on the movies tonight?"
If you tap the Bluetooth icon in the status bar again...
You'll see the computer or notebook is connected .
To disconnect, simply tap the connection icon in the status bar, and tap the Disconnect button.
And this is the result of disconnecting...
To check your connection from the desktop or notebook, double-click My Bluetooth Places, and open My Device.
The icon in green show which Bluetooth profile is in use right now. Right-click My Network Access, and select Properties to see its current status.
That's it!
Jun 22, 2009 | Nokia N70 Cellular Phone
Call from pc with use of my nokia n70
Hello there! thanks for using Fixya.com!
Unfortunately, we cannot use that feature especially as I know with Nokia N70 phone. You can only use bluetooth devices head sets or other supported devices via bluetooth. However, you may use your mobile as a modem and access thru GPRS and you may browse directly from your pc, just connect your phone with USB cable to your pc.
Here some details of the specifications, Here is the detail for this user guide manual: Nokia N70 Help Tutorial Useful shortcuts Clock Clock settings World clock Volume and loudspeaker control File manager View memory consumption Memory low—free memory Memory card tool Format a memory card Make calls Voice calls Make a conference call Speed dial a phone number Voice dialing Video calls Video sharing Video sharing requirements Settings Share live video and video clips Accept an invitation Answer or reject a call Answer or reject a video call Call waiting (network service) Options during a voice call Options during a video call Log Recent calls Call duration Packet data Monitor all communication events Personalise your device Profiles—set tones Offline profile Transfer content from another device Change the look of your device Active standby mode Contacts (Phonebook) Save names and numbers Default numbers and addresses Copy contacts SIM directory and other SIM services Add ringing tones for contacts
for more info, check this site http://www.ebookmanual.net/nokia-n70-user-guide.html
Feb 15, 2009 | Nokia N70 Cellular Phone
How can i connect my internet with my n70 to my laptop
check whether u install ur pc suite properly or not.follow these steps.
1)connect ur data cable to ur phone and laptop .
2)a icon shows connecting of ur phone
3)click pc suite icon on ur laptop .the click connect to internet.click on settings change ur operator according to ur sim card.
Apr 27, 2008 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
157 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
