Question about Canon PIXMA iP1800 InkJet Photo Printer
The same problem with my ip1800
Please help me fix my printer which happens to just feed and feed papers continuously until nothing else was left and then nothing was printed on my paper...i guess the roller feeder has loosen
    Problem Solver:
  • 10 Answers
Hi There, if you go onto the top of the page on this website and type in manula for canon ip1800 it will bring up the manual and it will show you how to fix it.
Posted on Jun 24, 2009
Paper Shooting Out
Please have a Check on the below mentioned Points and follow the steps:
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
Good Luck!!!!!!
Mar 28, 2013 | Lexmark X4650 All-In-One InkJet Printer
My Canon IP1800 worked fine until I had to replace the ink. I changed the cartridges and since then it has not printed. It will not feed the paper in the printer to do anything. I have pushed the feed...
These are the steps:
1. Turn On iP1800
2. Push and Hold Resume button about 2 minutes
3. Release Resume button
4. Printer back to normal again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 03, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
X8350 InkJet Printer: my LEXMARK x8350 CONTINUALLY GRABS MORE THAN ONE S...
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." This is essential. Then plug the printer back in and follow these steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously.) Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
your's tech expert
Jeeth
May 17, 2010 | Lexmark X8350 InkJet Printer
Pper jams
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer grabes paper at an angle every time i try to print a page,never has done this before, am using same kind of paper, just keep's going in sidways,thank's rr
Please follow the steps given below to perform the self-test:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let me know.
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using?
Have you ever used this type or brand of paper before and if so what were the results?
Once we have this information we will try to fix the unit through email support.
Apr 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
I just purchased a new lexmark x3550 all in one printer and i began the installation,and when the allignment portion of the installation came the paper keep jamming tried again and the same thing happened....
Most of the Lexmark printers (including the Z- and X- series) pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
1. Press the “Settings” button once. The screen with read “Settings: Maintenance”.
2. Press the check button once. The screen with read “Maintenance: Ink Levels”.
3. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
4. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 10, 2009 | Office Equipment & Supplies
I have just purchased ink cartridge 830 black for canon ip 1800 but the lights are blinking orange please tell me why this is happening
I received this response from canon.com. Hope it helps you.
If the paper feed rollers become dirty, they may not be able to properly
feed paper due to the feed roller's slippage. If paper does not feed
correctly, perform the following to clean the paper feed rollers:
1. Open the Printer properties.
For Windows Vista
a. Click / Select 'Start' from the bottom left of the Windows screen,
'Control Panel', 'Hardware and Sound', and then click on 'Printers'.
Note: If you are in 'Classic' view, Click 'Printers' directly from the
'Control Panel'.
b. Click your right mouse button on the listing for your printer, and
then select 'Preferences' from the menu that appears.
For Windows XP Home Edition
'Control Panel,' 'Printers and Other Hardware,' and 'Printers and
Faxes.'
For Windows XP Professional Edition
a. Click 'Start' from the bottom left of the Windows screen, and
'Printers and Faxes.'
For Windows 2000
and 'Settings,' then 'Printers.'
then select 'Properties' from the menu that appears.
2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
3. Remove all sheets of paper from the auto sheet feeder.
4. Confirm the following message, and click 'OK'.
Note: Clicking 'OK' will activate the paper feed rollers 30 times. This
activation will take about 90 seconds. Do not perform other operations
until this operation has finished.
5. Confirm the following message, and click 'OK'.
6. After the continuous paper feeding operations in step 5 have
finished, load three sheets of plain paper and click 'OK'.
7. Confirm the following message, and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
8. Click 'OK'.
Roller Cleaning is completed.
If the issue continues to persist, try fanning the paper before
reseating in the automatic sheet feeder.
Follow these steps to fan the paper in the Auto Sheet Feeder(ASF):
1. Remove all documents from the ASF.
2. Check for any obstructions.
3. Fan out the sheets of paper so that they do not stick together.
4. Align the edges of the paper.
5. Insert the document stack, face up, into the ASF until you hear a
beep.
6. Adjust the document guides to the width of the document.
If fanning the paper does not help resolve the issue then the iP1800
special toll-free number for email customers with
unresolved issues and speak to a technician* by dialing 1-866-261-9362,
Monday - Friday 10:00 a.m. - 10:00 p.m.
Dec 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
The ink absorber is full... for the canon PIXMA iP1800
My printer is not printing for feed paper. It tells me that it has a paper jam, but there is no paper in the printer. Please advise
Dec 05, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printer says it is jammed
unplug printer from wall for 12 secs and plug back in
Jan 15, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Help!!!!
Hello, This is happening to my printer, too. Did you ever resolve this problem? Should I just chuck the printer against a wall and call it a day? Thanks, -Kathryn
Jun 06, 2006 | Dell 922 All-In-One InkJet Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
172 people viewed this question
old marine
old marine
