Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
No power or reset button
Hp pavillion will not power up. have replaced power adapter and still no result. Looked for reset button, can't find
  • 4 more comments
  • Nussi Nov 19, 2007
    Have got the same problem! My HP Pavilion Zd7168 dont come up again after crashing during bootup. Curios about is that many button lights still burn when plugged in, although the main power button stays without any reaction at all.
  • Anonymous Nov 20, 2007
    zv5000 wll not power up
  • ct-clayton Dec 24, 2007
    Got that on one here. Seems the entire cover above the keyboard is warped and the power-button doesn't make it all the way to the switch on the mobo. With a bit of pressure in the warped cover, the travel of the switch is enough to hit the switch.
    It's not my laptop, but I'd guess it was dropped, or the heat got to it. I don't see anythin UNDER the cover preventing a tighter fit. There are ONLY two screws that hold that cover on and not one near the switch
  • chickb Feb 24, 2008
    it turns on in boot up mode but wont let us do n e thing when option is selected nor will it let us do n e thing when f10 is pressed
  • kulet Mar 04, 2008
    hp pavilion zd7000 is not working, no function, and no boot up?
  • Anonymous Apr 04, 2008
    This is an office laptop, and the battery (old) was run dead. On plugging in, nothing happened beyond a quick blink of all lights, then total darkness. Stripped it all apart, plugged it in, and the on AC light can on. Snapped the battery back in, and the battery light can on. Still nothing when powered up beyond a quick blink. After a while of being on charge, the battery (lightning bolt) light goes out. When the power switch is pushed, the power light comes on, and it all goes dead.
    Re the warped case, there 6 screws that hold that piece of plastic in. Two on the back of the hinge covers, and four in the bottom. Then, it snaps out with some prying. Reverse to reinstall.
It's most likely your internal female dc power jack. you have to take apart the computer and replace the power jack. If you search online you can find others who have done this.
Posted on Mar 30, 2008
JUST PASSING ON USEFUL YET IRRITATING ADVICE I FREQUENTLY GET FROM WHAT I CALL TEKKIES WITH NO, I REPEAT NO SENSE OF HUMOR -- RTDM OR BETTER YET RTFM...NOW I CAN BE THE ONE TO LOL LOL LOL
Posted on Mar 21, 2008
Button wire is probably loose.
Posted on Dec 13, 2007
HP Pavillion dv6700 - won't power up
Hi have you tried to power up without battery?
Feb 16, 2013 | HP Pavilion Computers & Internet
Replaced power adapter but computer will not turn on.
Unplug power. Take the battery out. Press the power button. Wait a couple. Insert the power cord. See if it boots.
Dec 22, 2012 | HP Pavillion NB200UA dv4-1225dx Notebook...
HP Pavillion dv9700 does not power on
It would seem that the power button is faulty, usually, this is because one or more of the four solder connections by which the switch is attached to the printed circuit has become detached, sometimes caused by pressing it too hard. Rectifying this is quite an intricate job requiring a lot of disassembly and skilled soldering. If you are in any doubt take it to a professional.
Apr 07, 2017 | Computers & Internet
The light goes on, it seems to start...then light goes off and then nothing. Optiarc DVD RW AD-7560A ATA Device HP Pavillion Vista
Remove the dc battery, and unplug the dc adapter.You will hold or press the power button for 40 seconds.Now you will get positive result,when you plug the adapter to your laptop and the Battery also.Almost 80% laptop can solve for this problem through the proceses.
Hope it help you.
Dec 31, 2010 | HP Computers & Internet
Power suppy ok but computer won't turn on
Try doing a power reset. Remove battery and power adapter, wait for 10-20 seconds then put the battery and adapter back in then turn the computer on. You can also try to remove the battery and just plug it in on the power outlet.
Jun 24, 2010 | HP Pavillion ZV6000 Notebook
''My HP Pavillion ZE5300 Laptop Doensn't Come On At All!''=v.v=
when you press the power button, does any light flash for 1 second?
remove the memory, hard disk, cd writer from the laptop. then try to switch on again. do it using the power adapter.
if it doesnt come on then its an internal problem. you will have to open the laptop case and remove all parts for test
good luck
Oct 06, 2009 | Computers & Internet
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavillion ZV6000 AC Adapter
there is battery problem dear so replace your battery u will get result..
Jan 15, 2008 | HP Pavillion ZV6000 Notebook
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
1,675 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
