Question about Coleman Powermate Premium Plus 6250W Portable Generator
Runs on choke only
Motor will only run with choke on only. As soon as you switch the lever over to run, the engine dies as if you put the choke on.
If you put a rag over the front of the carb intact the engine runs a lot better
Float is not sticking and needle valve has been checked
I live in florida so low temp. not the problem.
  • 77 Answers
High speed jet is varnished, by restricting airflow your forcing the engine to draw more fuel through a partially clogged jet. will not hurt the motor, but it will worsen the fuel consumption until you clean the high speed jet. if i was you once i had it apart i would go ahead and clean the entire carb. generators are bad about doing this because they get used so sparatically
Posted on Jun 23, 2009
    Habit-Forming:
  • 17 Answers
Well sticking float is not the problem. Most likely the carb is clogged up. WHat you have is a lack of the proper fuel flow. I suggest you remove the carb and take out needle screw and look inside for jet. Remove jet with proper sized screwdriver and clean. Blow it all out and reinstall jet and set screw to 1 1/2 turns open for starters.
Posted on Jun 25, 2009
2 Suggested Answers
protek480
  • 1723 Answers
SOURCE: Coleman 6250 Generator
Check the air filter.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 26, 2009
Automatic choke will not shut off once the engine is running so engine dies. Could it be a spring is missing ?
There is a diaphram that the link connects to the choke. It is between the carb and the gas tank, and runs by the vacuum from the engine. B&S engines have to rev up for the choke to open all the way.
Sep 20, 2014 | Cub Cadet Garden
04 trail buck 500 cranks and runs with choke on
check for intake manifold leaks
Sep 01, 2014 | Motorcycles
Small gas engine dies when choke full open
I have attached a diagnostic sheet to help you determine what is wrong.
Jan 21, 2014 | Weedeater 2 Speed Gas Blower FL1500LE ()
5.5hp honda engine dies when choke is open
There should be a fuel adjustment screw, it's probably getting too much gas.
Dec 18, 2012 | Motorcycles
I have a 1985 honda goldwing gl 1200 aspencade i can start the bike it runs fine as soon as it get warm the oil light in dash comes on and motor shuts off i have change oil and filter and the oil pressure...
Hi Most likely your engine shut off first then the light goes on as soon as the engine oil pressure dropped sounds like you have a carb problem and the motorcycle is running on the choke circuit. then it dies after the choke is turned off.
Oct 24, 2012 | Motorcycles
Motor will start on choke setting and then it immediately dies when moving the choke lever to the run position. Cleaned carb, new plug new air cleaner and checked all linkages. the motor has new oil and...
You say you cleaned the carb. If you did that by spraying cleaner in through the choke, that's good, but it doesn't get to the root of the problem. The problem is getting the gas into the carb. Try this. drain the gas. Put a small amount of carb cleaner and gas in the tank (about 1:1) Start it up, but don't run it dry. Let it sit for an hour. Then start it up and run the tank dry. Then try just a little gas to see if that fixed it. If not, repeat. Good luck Al K
Dec 23, 2010 | Honda Garden
Jun 22, 2009 | Coleman Powermate Premium Plus 6250W...
Engine dies when shift into gear.
This sounds like the kick stand switch is bad or not making full contact.
Please take time to rate this a fixya
May 11, 2009 | 1999 Honda GL 1500 SE Gold Wing
Coleman Powermate Premium Plus 6250W Portable Generator Logo
968 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
