Question about Xerox Phaser 8500/DN Printer
The printer makes a terrible noise during warming up
I 've tried to take out the maintenance kit but I cannot take the maintenance kit out. Something hold it in. What can I do??? Pls help!
  • letta667 Jun 22, 2009
    I managed to take out the maintenance kit and it looks ok. But It seems to have printing problem. There is a paper jum (on tray 2). It grips the paper and it doesn't print it. And it makes a terrible noise (it 's very different noise than the noise of start up). Also the display panel seems to have a problem. It's black or it's written like a mirror.
  • 212 Answers
For a start: these machines are quite noisy at startup, so this may be normal. do you have problems printing? because if you don't, it's not worth trying to fix something that isn't broken. if the printer tells you the maintenance kit needs replacement, you can open the side panel, and feel a little lever at the bottom side of the maintenance kit (yellow-ish drawer). you need to push this lever upwards, while pulling out the maintenance kit.
Posted on Jun 22, 2009
Have a 6kg hoover tumble dryer making noises when on sounds like something trappped under drum
it sounds like your bearing are gone you can buy a bearing kit its not an easy job but if your a handy man or woman it can be done
Jul 29, 2014 | Hoover VHC391 T-80 Dryer
Installed maintenance kit, t644 lexmark, now it makes knocking\clicking noise while printing. HELP
If you are experiencing excessive noise and vibration, there might be something wrong the Main Drive Assembly and it might need to be repaired. Please call the Lexmark Technical Support Hotline for Laser printers.
Jul 06, 2012 | Lexmark T644 Laser Printer
Making noise like its printing but nothing comes onto the paper
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jan 21, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
Epson C900 paper crumples when printing
Any idea how many pages have gone through it? There's a duty cycle total on the printer. If you've exceeded 50% of the maintenance kit duty cycle, it may be time for a kit replacement. Otherwise, it could be something as simple as paper with too high moisture content. Clean the rubber rollers and pickups with Windex or Glass Plus on a lint free cloth. This may get you a few more pages of printing if it's time for a kit.
Jun 18, 2011 | Epson Office Equipment & Supplies
Xerox 8560 died after installing new maintenance kit.
The error is caused by the printhead not being able to tilt, the maintenance kit (oil roller) is driven round by the drum and has no physical connection to the tilt mechanism. Having said that I did once have a machine that had waste wax loose in the machine and when the customer replaced the maintenance kit the loose wax was pushed into the tilt drive gears which are located on the inside frame left hand side, right behind the oil roller. The wax jams the gears making a noise like a machine gun and tilt error 07,010 was the result.
Oct 21, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Error 07,010.43:29827
That code can be caused, ( normally) by 4 different things, maybe 5.
The noise you are hearing is from the maintenance kit. It moves up and down to clean and prepair the drum for a print.
1. Take the maintenance kit out and look in the opening with a flashlight. See if there is ink built up in that back side of the printer under the maintenance kit. Normallyh it will be yellow ink in that area. If so you will have to remove the scanner and document feeder, then the left cover, you may also have to remove the right side for the front cover to release the left cover.
About mid way back toward the bottom of the frame there will be where you can clean that ink out. While your at it, and waht could also be the problem, is a stainless steel pivot block. avout 1 inch square will be contaminated with ink also, clean it well.
2. The maintenance plate, the black piece that lifts the maintenance kit, may be warpted or broken, You can see is when you remove the maintenance kit.
3. The process Drive motor assembly may be mis timed. It is on the right frame toward the front. It has 2 timing holes, which you can put paper clips into, to align the upper and lower gear train, and also the arrow on the bottom metal plate must align with the arrow on the gear.
4. The print block referenced earlier may be causing the print head to bind, but rarely does that cause a noise, I add that because you may be hearing the X-Y axis motor and since it is faulting out, you may really just notice it more. But the block would more likly cause an 07,010,45 not a 43.
5 The print head wiper may be tacked to the print head.
Let me know if you need some more help..
Aug 28, 2008 | Xerox Phaser 8500/DN Printer
8500 Phaser error 07 010 43: 6975
6975 I know of nothing that references.
I honestly don't know where you could get a manual. Other then try googling "the parts drop" and calling them. Talk to Britt.
Normally that print block is sticky or the cleaning blade is stuck to the print head causing that error.
Aug 07, 2008 | Xerox Phaser 8500/DN Printer
Can't put maintenance kit in
You can remove the left, as looking from the front, side cover and manually crank down that white cam that moves the kit up and down.
It is opreated by a clutch. Removing that clutch makes it easier to lower.
Left hand side, looking from tehe front. Just do some observation to determine what you need to move. Should not be a problem.
Feb 05, 2008 | Xerox Phaser 8400 Laser Printer
MAGICOLOR 2400W WARMUP CYCLE
probably, it need a little maintance, maybe some part needs to be replaced. so if you still have a warraty, use it. because there can be many problems, what makes noise.
good luck
Jan 13, 2008 | Konica Minolta magicolor 2400 Laser...
Device maintenance issue
Check with a torch for a jam, small paper or foreign matter, use a torch, check very carefully and make sure you check paper feeder, and near carriage.
Apr 02, 2007 | HP Photosmart 3310 Printer
Xerox Phaser  8500/DN Printer Logo
287 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
