Question about HP OfficeJet d145 InkJet Printer
Get the following error message: Scanner Failure Power off then on again. I have done that but it keeps accouring,
  • 212 Answers
It is possible that the scanner has been locked. look for a twisting button with a lock-symbol next to it and make sure it's in the unlocked position. if this is done, restart the printer. if the problem is still there, the printer may have to be repaired in an authorised repair centre.
Posted on Jun 22, 2009
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
The error message reads: "Scanner failure. Turn power off the on again." When I do that, it just gives the same error message again.
You have a bad scanner unit. Getting it repaired will cost as much as buying a new machine.
Oct 16, 2009 | HP 190 Copier
It means that the printer is having problems powering the scanner, either the light source is not working or the belt drive or gears are jammed. It is a self diagnosis that is not passing. That is the reason for your problem.
Jun 21, 2009 | HP OfficeJet d145 InkJet Printer
I keep getting a scanner failure error
Let's try this. Turn power off, unplug the cord from the surge strip or wall socket. Leave unplugged for about 30 minutes, then plug back in and turn on. Hopefully this will fix your problem. Good luck.
Mar 19, 2009 | HP OfficeJet 7130 All-In-One Printer
Scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
CLICK HERE==>> DOCUMENT
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
adonscott
Jul 19, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner FailureTurn power off then on again Message Window pops up continuously
Below is the document that i want you to follow.
CLICK HERE ===>> DOCUMENT
Pleae let me know the result after performing the steps.
thank you so much.
adonscott
Jun 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Error message
Unfortunately, if an HP scanner quits functioning, the whole unit is dead. You may want to unplug the printer from its power source and USB cable for about 5 minutes, plug them all back in and then retry. Sometimes, a scanner job can get stuck in the spooler and cause the whole thing to stop working until the job is done (even though there isn't a job to do). I had this issue once and this worked.
Jan 20, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Scanner Failure Message keeps popping up
Here it is all over, with all the steps.
1.Unplug power cable from printer.
2.Hold Cancel and Enter. OR you could Hold Cancel and Black Copy Button. Whichever is easier
3.Then plug back in the power cable, while still holding those 2 buttons.
4.It should turn on, lights blink, then it should say FULL RESET on the little screen thingy .
5.Let go of the buttons, and hopefully, it fixed your problem.
Nov 29, 2007 | HP PSC 750 All-In-One InkJet Printer
HP 7140xi scanner failure error
Please click on the web link given below and perform the steps as given in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00787271&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
For further information contact HP chat support, its free of cost.
CLick on the web link to chat with HP technician.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Have a great day!
Oct 13, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet d145 InkJet Printer Logo
254 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
