SOURCE: headlights and highbeams switches
After reading your post, I am pretty sure the headlight switch is at fault. What happens when you turn the headlight switch to on and then actuate the high beam switch? If both low and high elements light up, I think that would be the headlight switch itself as the culprit. I don't have access to the wiring diagram you need, as that would answer your question end the guesswork on my part.
SOURCE: all interior and exterior lights work except headlights...
BAD HEADLIGHT CONTROL SWITCH,REPLACE IT BEFORE IT MELTS YOUR DASH,THEY GET VERY HOT WHEN THEY FAIL
