Question about HP Officejet 5610 All-In-One InkJet Printer
Catridge stuck because of wrong catridge
I have inserted (by mistake) color catridge in B/W and B/W catridge in color slot and now I couldn't take it out. Please suggest me what to do...
  • 102 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab84
Posted on Jul 17, 2009
  • 212 Answers
It is advised to have this done by an authorised technician. this person may be able to remove the cartridges without damaging the printer.
Posted on Jun 22, 2009
Put new black and color cartridges, will not print only black lines or when I use color, just color lines, I am only using copying not hooked up with computor , juststand alone copying
Maybe the printer need to clean a slot for a catridge. Because that printer stuck with old tint in the head for a printer therefore it need clean the heads.
Nov 27, 2010 | Lexmark X5150 All-In-One InkJet Printer
Replaced the ink. black works colored does not.
Normally, new catridge has a thin layer close the output of the ink. See that thing. If it close, pull it over, Or.
May be the catridge is not suitable with the printer.
May be the the catridge is quite old and the ink is dry, if it is refill catridge, put several drop of hot water in it.
Hope this may help.
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
Printer will not print colors
Printer not print colors. possible reasons....
  1. your color catridge may be empty.
  2. Your color Catridge may be jam.
  3. your color catridge may not be properly installed.
Thanks
Aug 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Replaced color cartiage, now only one color prints, red? Help
Try to check the level of your ink in your color catridge maybe is running low or empty then if its empty then remove the catridge then replace another color catridge full of ink then run your printer again. If you successfully installed new ink catridge then it will automatically reset the level of your ink monitor to full.
Jun 16, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
HP photosmart 7960 gives message Cartridge Service station is stuck. Cannot see a jam or obstruction...any suggestions?
Unplug the Power Supply from the Printer.......
Remove both the Catridges from the Printer.........
Just Move the Catridge Carrier which Holds the Catridge Back and Forth for about 20 Times.........
Insert the Catridges back to the Printer.........
Turn the Printer On...........
Good Luck.............
Apr 04, 2009 | HP PhotoSmart 7960 InkJet Printer
Trying to insert new ink catridges
I think it will do the trick for you try this.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Mar 31, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark 5400 Printer does not use the photo cartridge
First of all as this Catridges are Non Intelligent they will not be able to show u the exact Ink level on the catridge then too if thats really happening this Solution below will fix it: In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the Photo on the left........ Good Luck
Jan 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Ink cartridge
The message seems to be saying that you have two black cartridges installed and therefore one of the colors is missing. Is that possible?
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon i560 --No color!
see you removed the seal of catridge nozzel like stiker of catridge and also check whethre your pring mode is color not a grayscal. bye
Sep 03, 2007 | Canon BubbleJet i560 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
56 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
