Question about Riso RZ220 Duplicator
How much would I pay for 2 x drums for a RZ200? Thanks
  • 81 Answers
You can probably find them on ebay for about 3-4 hundred each.. new from riso they are very expensive..
Posted on Jul 07, 2009
Riso rz200ep error code d-13---9
http://printcopy.info/?l=en&mod=erc&brand=Riso&model=RZ200&code=D13-9
The link above states:
Code
D13-9
Description
The rear cover is opened (serviceman safety switch is OFF).
Riso RZ200 Error Codes
Mar 26, 2018 | Office Equipment & Supplies
Can a red drum for an RZ200 be converted to a black drum.
I am am currently not familiar with this model yet. But I have done such a procedure on other models already.
Please consider how to remove the unwanted colored ink. Do you want to dismantle and clean the whole drum mechanism? Or do it by printing several hundred (tousand) prints with high inkage? (You might discover some nice color effects.)
Some questions for you to make it clear: Does the black ink bottle fit in the color drum? Yes? Continue! Compare the PCB (unscrew the plastic housing) of a black drum with a color drum? Identical? Continue! Set DIP switches on PCB like the black drum. You are ready to use black ink!
Apr 27, 2011 | Riso Office Equipment & Supplies
RISO RZ200
if show ERROR CODE D22-542 means the board in the drum have some problemif show D04-534 means you are using not original ink, but just press restart key is ok.
Apr 13, 2009 | Riso RZ220 Duplicator
Kyocera 1810 drum replacement
First, what kind of technical background do you have? Also when replacing the drum you should replace the drum blade. Most of the drum/blade kits do not come with padding powder anymore so you will need the padding powder also -- if you do not use the padding powder you will get drum blade jitter and trash the brand new drum!!!!
TO replace the drum you will need to remove the toner cart., 1-2 covers, the dev. unit (developer) and then the drum unit. You will then have to take the drum unit apart to remove the old drum and blade. *****NOTE***** DO NOT TOUCH THE DRUM SURFACE OR THE MYLAR (RUBBER PART) OF THE BLADE WITH YOUR SKIN!!!!!! The oil from your skin will damage the drum and could damage the blade, again -- then they would be trashed.
I would spend the money to have a trainer tech. come out and replace/ rebuild your photo conductive unit for you. It would be money well spent.
Oct 29, 2008 | Kyocera KM-1510 Copier
Re: Lavamat 72630, 6 yrs old Very loud noise from drum movement, has increased over last ten washes. When machine is stopped, on rotating drum we note it is catching on something. Nothing rattling, don't...
Hiya admin47..... to be a litle more certain diagnosing your problem, please can you do the following.
1. with the washer empty.. ie the drum... please rotate the drum by hand at any speed you can get... without moving the drum sideways/backwards. Listen for any peculiar noises.
2. Then move the drum backwards at the bottom of the door ( dont force).. then let the drum housing go.. swinging by its own movement, again listen for any strange noises.
3. Do the same pushing the drum from the inside to the outer casing..again dont force.. let go listening again...
Please post me the results
Regards Faggly
Mar 18, 2008 | Washing Machines
83 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
