Question about Limit HC40 System
HC 40 LIMIT sound system
Hi I've jsut been given a Limit HC40 system free from a friend, who couldn't get it working with a new TV system. (he's not the best with this sort of thing)
Before I fiddle with it I was wondering if you have any info on this system.
a. Are they reliable?
b. Is it likely to work with a new flat screen HD 42" tv.?
c. Is it worth taking to a repairer to check it out?
many thanks
Phil Am\os
FIXED>>>>I took it to a local repair centre.
Posted on Jun 23, 2009
Hc ppm
I would google vehicle exhaust gases & do some studying
Given it is a 1992-- 22 year old vehicle & don't know how old
the motor is !
159 is HC & a lot of unburnt fuel
NO may be an egr issue along with overheating
Best study the gases & what is required to address them
You could go with the spark plugs,wires,synthetic oil, new air filter,
check out the egr system,pcv system & vacuum leaks,thermostat,
oxygen sensor,clean maf sensor
I'm NOT saying throw parts at it,I'm saying check it out & do some
testing, to find some problems
You have to take out a lot of fuel & bring down your misfire counts,
engine temp etc
I would guess after your best efforts ,you need to replace the
exhaust converter,I would, unless it is only 5 years old or newer
Apr 02, 2014 | 1992 Mitsubishi 3000GT
Pilot light won't stay lit after releasing when lighting gas fryer
This symptom indicates something wrong with the millivolt system. Start by checking the wires from the thermopile to the gas valve, insuring they are all tight and in place. Check the hi limit thermostat, if you have an ohm meter it should read .1 or .2 across it. With you meter set to dc millivolts, and flame present on the pilot, read across the thermocouple wires (red and white) to see the millivolts generated, with the thermostat off and the gas valve in pilot position you should get approx 600 millivolt plus minus 50. The pilot will have to be on for a minute or so to get maximum millivolts. If the millivolts are correct, hi-limit closed, and all wiring is connected, you likely have a faulty gas valve. If the hi limit reads more than .1 or .2 replace the limit, if you are not getting the millivolts from the thermopile, replace it.
Apr 05, 2013 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
My ELCOT TV ask password, TV screen showing Limit Set, Limit Lock ON ask Password.
May 10, 2011 | Televison & Video
FAILED EMISSIONS
possible but could be head gasket or valves , or worn rings and is by passing the pistons going straight out the end ...or maby settings are wrong ? try carb cleaner and inspect visually air-filter etc.
Aug 26, 2009 | 1986 Ford Mustang
How to set up
All speaker connect to sub.
fr= front right
fl = front left
rr=rear right
rl= rear left
cen= centre
DVD outputs connect to sub inputs
Mar 30, 2009 | Limit HC40 System
Wont pass emission ''hc to high" !
1993 DODGE CARAVAN 3.0 HCPPM LIMIT 144 READING 172 NO PPM LIMIT 965 READING 1024
Jan 21, 2009 | 2000 Saturn Ls 4dr Sedan
High CO emissions
run the fault codes and look for problem heated oxygen sensor ( HO2S) in the exhaust manifold , or problem oxygen sensor (O2S) after the cat converter, problem EGR system or problem cat converter
Apr 05, 2017 | 1995-1997 Chevy Suburban Ignition Starter...
Deep shut down
your themostat is either bad or your hi limit is bad if the oil gets too hot the hi limit will shut everything down for safety or if the oil temp is good it is the limit control shutting everything down when if should not first thing to check to see if the in the tank matches up to the knob if so change the hi limit it if not change the thermostat
Nov 13, 2008 | Cecilware FMS-40 Deep Fryer
Hi-limit trips,
jump the hi limit by connecting the two wires in the back of the limit control after 45 minutes with the fryer on and does not go off the limit is bad and should be changed we have aLL THE PARTS IF NEEDED ASK FIXYA TO CONTACT ME
Oct 24, 2008 | Cecilware FMS-40 Deep Fryer
How to use pass through with Sony DCR HC 40 and Mac iMovie?
If it will work, the only tip is to leave the tape out of the Sony when trying passthrough.
Sep 13, 2005 | Sony Handycam DCR-HC40 Mini DV Digital...
Limit HC40 System Logo
255 people viewed this question
Top Limit Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Limit Audio Player and Recorder Expert? Answer questions, earn points and help others
